Question about Pioneer VSX-D557
Remote control directions
I have a Pioneer ( CU-VSX135) remote control and I am trying to program it to my T.V. and my DVD player.
5 Suggested Answers
  • 44 Answers
SOURCE: remote control
http://www.manualsparadise.com/ReWrite-SPFM-G.B.M36833567
check the link!
Posted on Jan 21, 2008
SOURCE: pioneer pro-1009w, pro99, pro119, cu-sd100, sdp579s, remote axd1425 & instructions
I have an extra remote for this set if you're interested. Shoot me an email at: ericpjohnston at yahoo.es
Posted on Nov 10, 2008
marc_uhrey
  • 72 Answers
SOURCE: Remote Control will not work
I had a similar problem with a remote that failed. If you have a camcorder or digital camera that you can operate in video mode, you can point the remote toward the camera, press buttons on the remote, and see the infrared flashing through the camera. See the video below:
http://www.youtube.com/watch?v=tlTIrVQjaY8
If you have a working remote for some other device, try it first so you know what to expect. If the Pioneer Remote doesn't show activity, it must be replaced. If it does, the problem may be in the DVD player.
Posted on Jul 14, 2011
gopakumarg43
  • 69887 Answers
SOURCE: Is there a universal remote that will work with a Pioneer DV 400 DVD player?
For more details type in this site name "Electro-help" (DO NOT copy and paste the site name from here. It may lead you to wrong place) to search box of your search engine [not in the address bar of your browser], and press "Enter". It is an electronic equipments service help site.
Note the position of hyphen in between words in site name. The site will appear as it is in web; subtitled as Service help to electronic home entertainment equipments.
Pull up older posts.
You can locate this site, either at the bottom part of first search page, or at the top of second.
Detailed descriptions are there to help you.
Posted on Jun 07, 2012
  • 49 Answers
SOURCE: I have second hand Pioneer VSX-D710S ,its remote is pioneer cu-vsa030, remote had no " loudness " button , so how can i open " loudness
On the reciever,
Posted on Dec 03, 2012
Program a JVC remote to operate a SONY CD/DVD Player (DVP-NC85H)
Becuase this model IS a DVD player, the remote controller will not allow another of the same type. This remote can be programmed to control a TV, Cable Box, DBS tuner, and VCR. It will not control VHS or another DVD player
Sep 18, 2014 | JVC Remote Control RM-STHD5J p/n:RMSTHD5J
I have a pioneer usx-405 reciever for a PDf407. It used to work just fine but recently whenever I power it on in keeps flashing "muting". I looked it up online and a forum said I need a remote...
You mean Vsx 405, right? Model numbers are senseless enough without typos.
Are you saying you DON'T have a remote? How did you ever set it up? There are several CU-VSX105 remotes available on eBay, one at $9.99 and expiring in a few minutes (17:12 PDT). If you get this in time you could snipe it at the last 10 seconds.
http://cgi.ebay.com/Pioneer-CU-VSX105-Remote-Control-Receiver-/170642335146?pt=LH_DefaultDomain_0&hash=item27bb1365aa
Many a Pioneer receiver will come up MUTING if it powered down Muting. It's not clear if you have been experiencing unwanted shut-downs. Unwanted Muting or any other command could well originate with an unintended remote control source. Mask the receiver so it can't see other I/R sources.
May 21, 2011 | Pioneer VSX-405 Receiver
Cannot program dvd player. unit does not fully answer commands from remote.
To program the DVD player's remote control to operate your TV, follow these steps:
  1. Turn on the TV, and then aim the DVD player’s remote control at the TV.
  2. Press and hold the [TV Power] button on the DVD player's remote control.
  3. While holding the [TV Power] button, use the number buttons on the remote to enter the two digit code assigned to your brand of TV.
Note 1: If your DVD player's remote control can be programmed to operate a TV, the TV brand codes will be listed in your owner's manual. If you don't have your owner's manual available, click here to go to the download center and download a copy.
Note 2: Many TV brands have more than one code. If the first code does not work, try the next available code.
  1. If the TV turns off, the code worked correctly and your remote control is now programmed. If the TV stays on, repeat steps 1 through 3 with a different code listed for your brand of TV.
Note: If none of the codes listed allows your DVD player's remote to control your TV, then the remote is not compatible with your specific model.
Let us know if you want something more else please accept the suggestion.
Thank You for contacting Fixya.com
Jun 11, 2010 | Audio Players & Recorders
I need to program my pionner sx-315 reciever in my directv remote control
I can help you with your Pioneer Receiver & DirecTV remote control.
This is a list of all the Pioneer Receiver control codes for DIrecTV remote controls:
31023, 30150, 30244, 30289,
30531, 30630, 30801, 31123,
31343, 31384, & 31935.
There are so many codes to try for Pioneer Receiver and DirecTV, you might want to go ahead and do a DirecTV Remote Control Code Search.
I hope that helps.
_________________________________________
DirecTV Remote Control Code List Download
DirecTV Remote Control Manual Download
DirecTV Remote Control Code Entry
DirecTV Remote Control Onscreen Setup
May 25, 2010 | Pioneer SX-315
I lost the remote to a pioneer receiver xv-dv131 and I just can't get it programmed into my Cox universal remote...any ideas?
I used a logitech harmony with my dvd player (same model) when i lost the original remote and had no problems.
Feb 07, 2010 | Pioneer VSX-07TX Receiver
Problems with Sharp Blu Ray Player "copy protected signal"
Possible solution: You set up your remote to run your amp from the TV control, using the AQUOS Link. Even though your amp is out of the loop, it's still recognized by the TV. You might have to reset the TV back to default and run the AQUOS Link again.
Apr 19, 2009 | Pioneer VSX-D514 Receiver
Pioneer receiver sx-315
With persistence, I was able to program the Universal Remote Control provided with the cable box to control my new used Pioneer SX-315 receiver. I now can control the tv volume, cable box, auxiliary stereo receiver with speaker system with one remote. Thank goodness I did not have to resort to buying a Pioneer remote control.
I was able to program another previously unused universal remote which I purchased several years ago. However, since the other remote control did not list the Vizio TV. That brand is too new for the remote.
Dec 06, 2008 | Pioneer SX-315
HDMI Compatibility
It sounds to me like you have a HDMI Control issue. It sounds like the DVD player wants to control the receiver. Try turning off hdmi control on the TV, reciever, and the dvd player in their setup menus.
Let me know if this helped,
Joe
Oct 03, 2007 | Pioneer VSX-81TXV Receiver
119 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Dennis McCollum
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
