Question about Canon PIXMA MP800R All-In-One InkJet Printer
CD Printing Hi I have a MP800R printer bought in the uk, i have the printer tray for CDs but I cannot get it to print, the tray loads and then rejects saying there is no tray, can you help please. Thanks Mark
  • 628 Answers
The CD may be bad. Just go to Canon's web site and download the software.
Posted on Dec 01, 2008
Can not print direct to cd dvd
  1. Find a printer that prints directly on a CD; this is becoming a popular feature and these printers are getting more affordable.
  2. Step 2 Buy some printable media. Printable media is a bit harder to find and a bit more expensive but you need a special surface that will absorb the ink. They will be marketed as "inkjet printable" discs. Look for them online or at your electronics store.
  3. Step 3 Set up your printer for CD-R printing. Chances are your printer can print on paper and CDs, so you'll have to let your printer know what you are up to. In your printer properties, select CD or DVD as your media type. You can do this from the print dialog right before you print.
  4. Step 4 Clean the rollers. You can do this by running a clean sheet of paper through the printer without printing anything. Load up several sheets of paper and press the cancel button to feed it through. Do this a couple times.
  5. Step 5 Pull out the tray. This may be a separate part of your printer or built-in. Read the manual and learn how to pull it out properly before you go yanking at random and breaking things.
  6. Step 6 Place the CD in the tray. Make sure there is no dust or paper scraps on the tray and place the CD on the tray so it lies flat and the printable side is facing up. For smaller CDs, place the adapter first and then put the CD down.
  7. Step 7 Insert the CD tray into the printer. If the tray was attached to the printer, put it back where it came from. For separate trays you may need to wait until you are ready to print and load it into the manual feed.
  8. Step 8 Design your label. Your printer will have come with label designing software. Take some time. Make it pretty.
  9. Step 9 Print. Double check your print settings and print directly onto your CD. Choose "File" then "Print" and click "Okay." If you are loading manually, now is the time. Manual loading slots are usually on the back.
  10. Step 10 Allow your CD to dry. It is recommended to let it sit for 24 hours. There is a lot of ink on there and you do not want to ruin it with smudges.
May 10, 2010 | HP Photosmart Premium C309A All-In-One...
Can I use printable cd on this printer?
No, this model haven't CD tray for printing on CD.
Oct 07, 2009 | HP Photosmart 2710 All-In-One InkJet...
I bought Verbatim ''White inkjet printable'' dvd disks. How does one load them into a printer, and which printers can use them?
You will need a printer with a cd tray that holds on to the disk while its printing,
My print tray moves backwards and forwards past the printer head as it applies micro dots of ink to build a finished image,
I have a Cannon i8 65,prints straight onto the surface of the disk,awesome photo quality prints on the disk,
Versatile with print various formats and media types too,Glossy,Matte,DVD,CDs,etc
Great prints and a sturdy machine too...
Hope this helps,MISTERDJ
Aug 02, 2009 | Verbatim Electronics - Others
Canon MP810-CD-R Tray loading-printing problem
I read on another site that you must wait until prompted on the screen to put the tray into position. Opening the inner door and loading the tray before asked to and then pressing OK was the key to fixing the problem on the MP830.
It's the simple things that always get you into trouble, I guess.
Oct 02, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Epson stylus r1800 problem with printing on cd/dvd
Try this :
Disconnect the printer from the computer.
Turn it off & make sure the CD/DVD tray is closed then turn it back on.
Here's generic instruction for you:
If you are receiving an error pertaining to the CD TRAY NOT BEING INSERTED CORRECTLY, please do the following:
Recommendations:
-Don't force the CD/DVD tray into the printer.
-Make sure your printer is powered on, and the output tray is in the upper position.
-Please ensure there is at least 3 inches of space behind the printer, or the CD tray may eject.
Included, are the correct CD/DVD loading instructions. Please follow the instructions below:
CD/DVD LOADING:
1. Ensure the printer is powered on. Remove any paper from the sheet feeder.
2. Push in the paper support extension on the printer, and close the paper support.
3. Push in the output tray extensions, but leave the tray open.
4. Lift the output tray. Place one hand on the top of the printer, and pull up on the output tray until it stops. Lay the tray down in the upper position.
5. Place the CD or DVD into the CD TRAY with the white (or printable) side facing up. Note: To print on small 8cm CDs, please place the small CD ring on the tray first, then place the CD inside the ring.
6. Slide the tray into the tray guides located in the output tray. Push in the guide until the arrow on the tray matches up to the arrow on the tray guide.
7. Press the PAPER button to load the CD/DVD into the printing position. The CD is correctly loaded when the printer's POWER button stops flashing.
General tips for CD and DVD printing:
-Burn data/video/images onto CDs or DVDs before attempting to print on them.
-Do not use thermal-printable or regular CDs or DVDs in the printer.
-Moisture or fingerprints on the printable surface of the CD may cause marks or smearing to appear after printing.
-All printable inkjet media is different. Some surfaces will absorb ink better than others. If output appears banded, faded, or streaky, print a Nozzle Check pattern to confirm that all colors of ink are printing completely. If the ink does not completely dry or smears after 24 hours curing time, you may need to use the Epson Print CD tools to adjust (lower) the print density.
-The only supported resolution for CD/DVD printing is 1440 dpi (aka "Photo")
-Borderless printing and printing on the "inner circle" (plastic around central hole) of CDs is not supported.
-Do not use the "print preview" feature provided by the Epson printer driver as it will only show the image on a blank field and does not offer a clear indicator of where the image will print.
-The Epson Print CD software works best with JPG images and may not import some TIFF images.
Sep 26, 2008 | Epson Stylus Photo R1800 InkJet Printer
Printing CDs using the CD tray - now won't work
sometimes those cd label print papers are too thick..and need to fed in one at a time
Feb 25, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Epsom Stylus Photo R300
Yes I had a similar problem and in fact returned my printer for a replacement. You need clearance as the CD tray emerges some 2.5 to 3 inches behind the printer. If the tray hits an obstacle it is unable to correctly line up for printing and the trat is rejected
Dec 24, 2007 | Epson Stylus Photo R300 InkJet Printer
Canon PIXMA MP800R All-In-One InkJet Printer Logo
78 people viewed this question
old marine
old marine
