Question about Whirlpool Royal A-909 Bathtub
I want to change the brass colored suction, jets....
I want to find out how hard it is to change the brass colored suction, jets, controls...in my Royal tub. And where I can find the replacement parts
    Genius:
  • 1,605 Answers
Call whirlpool or go to local bath and kitchen shop or local plumbing store. they should be able to give a price and tell you how to change all of the items.
Posted on Dec 04, 2008
The main jet fell out when I took the float bowl off to clean. Its a 21hp briggs & Stratton Where does main jet go?
Hi I I used to repair mowers I have never come across a main jet falling out. U mention U took the float of the only thing that can fall of is the needle that controls the flow of petrol ..to replace it the pointy end sits in the brass seat some needles have a rubber end this end sits in the brass seat then U CAN fit the float.hope this helps
Mar 05, 2016 | Garden
Troy bilt 2550 max psi 2.3gpm pressure washer don't want to kick over
sounds like dirty carb jet. most pressure washers sit for long periods of time and many have the jet in the bottom of bowl where dirt and grime collect. depending on the model the bottom screw holding on the carb bowl is the jet. clamp or turn off the fuel to carb, unscrew the bolt out of the bottom of the bowl and look for a hole down the center and hole on either side under the bolt head. most likely these are plugged. you can take a strand out of a piece of #12 guage electrical wire and somewhat clean the holes well enough to shoot carb cleaner through them. once you clean out the hole going down to the holes going across and clean inside of bowl you can reassemble and should start. in the case of the jet being screwed into the carb assembly just look for a brass screw and unscrew it.and clean it. all jets are made of brass so look for a gold colored screw with flat blade tip screwdriver slot. if its plugged with dirt or old gas you found your problem.
Sep 20, 2011 | Troy-Bilt Garden
I have a jacuzzi tub in my master bath, and it has started surging through the jets in about an 8 second interval. Also I have started noticing a little bit of water leaking from under the side of the tub....
Surging is caused when the pump doesn't have enough water to push to the jets. this is usually a problem caused by air being drawn into the suction of the pump.
take a look at the jet(s) facing the suction cover.
I have seen cases where the water with the air mixed in causing bubbles gets sucked into the suction of the tub and causes the surging because the pump is pulling in too much air.
try rotating the nozzle of the jet facing the suction away from it. point it another way. turn the air control knob closed and see if that is the problem.
the only other issue that could cause this 'surging' problem is a leak in the suction line and could be the source of the water you see under the tub.
Aug 18, 2011 | Home
The pump surges where's the impeller
if your pump is surging then you do not have enough water in the bathtub or you have a jet that is blowing air into the suction fitting. this happens a lot when a jet faces the suction and the air control is wide open. the suction pulls in too much air and causes the pump cavitation (surging). Try pointing the jet opposite the suction cover upwards and see if that doesn't solve the problem.
Feb 16, 2011 | Maax Pearl By CS60wh Pearl CS60 in White
Wiring instructions for a two switch
If I understand correctly, you have a dual switch with one switch stacked above the other.
If this is not correct, add a comment and I will help further.
On each side of the switch are screws with different colors.
The brass screws show in photo above.
Sometimes these screws are dark-colored.
The brass screws are connected by a brass plate so both screws are the same thing.
Your black hot wire from breaker goes to the brass screws.
On the other side of the switch are two independent silver-colored screws.
If the screws on other side of switch are dark-colored, then the screws on opposite side are brass and not silver colored.
Your black wires going to Load (fan, light, motor) go to each of these screws.
Each switch receives the same power source through the brass-colored screws on one side of switch, but on the other side of the switch, each wire is independent as each switch controls a different Load.
Nov 04, 2010 | Cooper Lighting Lighted Switch
Pump cycles like crazy!!
Sometimes a new tank the blatter will be kinda sealed to the sides of the tank.the amount of air in the tank s/b equal to the cut in pressure of the pressure switch.(40 lb) that would be (60 lb) cut out if you messed with the little screw on the pressure switch you have a problem.there must be the 20 psi of differance between start and stop.
May 13, 2010 | Flotec Corrosion Resistant Shallow Well...
My 69 E type runs badly.. Can anyone please advise the initial setting of the jet assembly ? The carbs are Stromberg 175 CD2SE Do I screw in the brass assembly all the way,into the bottom of the float...
the way i used to set these up i presume the mixture adjustment is @the bottom of the float chamber and not through the damper top using a special tool. either way the first thing to do is replace the diaphrams then set the jet heights if from underside models get them level with the top of the jet holder then lower the jets about 1 and half turns if the adjustment is on the needle in the suction chamber its the same procedure for the needles from the pistons get the needles lower from the lower face of the pistons then get engine hot and adjust the mixture on the carbs by the same amounts lower the jets or higher the needles whatever model of carbs you have to richen or other way to weaken you can test by lifting the piston in the vac chamber slightly if to weak the engine will slow to rich it will speed up. the ideal is very little change on all carbs. make sur the ignition timing is correct before you start
Nov 02, 2017 | 2006 Jaguar XK-Series
How to Change White Water Whirlpool Tub Jet Hardware
First step is to remove the old hardware so you have something to compare it to. THere are two types/sizes of tub faucets on the market for deck mounted applications. If yours is mounted on the tub deck then it is a deck mounted application.
The faucet spread (distance between the threaded nipples on the bottom of the faucet) is going to be something close to 8" or it will be of variable distance. If the two handles and the spout are connected via hose then they are of variable length.
Bring the old faucet into the hardware store and compare it so you know you are getting the correct one. It is not hard but also not fun to have to adjust the holes in the tub deck to accommodate a different size.
AS for the suction.....I am assuming that you are referring to the inlet part o the pumping system and all of the equipment behind the tub. I always recommend that you use parts from the same manufacturer. It is extremely helpful to call them with all of the numbers you have to get a list of acceptable replacement parts.
Hope this helps.
Apr 27, 2009 | Home
Hot tub jets stopped working
yes my jacuzzi uses air on the suction side to make bubbles. you must have clogged it. how long is tube can you slide a rod in there to check if its blocked?
Apr 16, 2009 | Maax Calla 6042 Bathtub - 101058-000
Change the jetting on a crf 250r 2007
I think its your jet thats needs unblocking or replaceing, That in-side your carb and aint too hard to clean. Take off ur carb and unscrew the bottom end off it. This is where the float is be careful not loose the float or bend any pins which you will see .there should be a brass pipe that travells through the carb and a small pin hole gap through it , it may be blocked use a small pin to unblock it or red-ex in ur petrol can help
Jan 22, 2009 | Honda CRF 250 R Motorcycles
Whirlpool Royal A-909  Bathtub Logo
867 people viewed this question
Top Whirlpool Home Experts
Craig Butler
Craig Butler
john h
Mike
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
