When washing , the drum spins but the water is still in the washer. When we first learned of the problem we smelled something like burned rubber but the belt was fine and it would drain some times. I did some trouble shooting and it is not the drain hose not the belt that turns the bottom of the drum or the switch.
  • solidsilver Dec 18, 2008
    water stays in drum, then machine starts to spin. wont empty out at all.
  • 121 Answers
Need brand and model
Posted on Nov 29, 2008
Maytag legacy series washer
The drive motor which spins the drum is connected to the drum by a rubber belt. Sounds like the belt is burned through. Make sure you can spin the inside tub by hand to verify that the tub can turn freely before you replace the belt. The hum is from the drive motor just spinning freely.
Sep 02, 2016 | Maytag Legacy Series Top Load Washer
Burning plastic smell from washer dryer combo
You have something between inner and outer tub remove top cover smell coming from air vents of outer tub then that is were it is
fun job its has to come all apart
Jun 28, 2016 | LG WM3987HW Front Load Washer / Dryer
Washer wont spin, smells like burning rubber
The burning rubber smell is coming from the belt which goes around the drum and is driven by the motor. The belt has probably stretched and is now slipping. It will need to be replaced.
Jul 13, 2011 | Washing Machines
The washine machine finished it's cycle but there was smoke coming out of the drum and a burning rubber smell
The usual cause of smoke coming out of drum is that the heater element has come on or stayed on with no water in the drum
Try it on a spin cycle only, if smoke still comes out of drum, then could be a faulty pump, or main motor is burning.
Jan 20, 2010 | Baumatic BTWM4 Front Load Washer
There was a rubber smell, now washer won't spin.
It is possible that the bearings supporting the drum have seized
Was the machine noisy before it stopped?
If there is tension on the belts and the drum is locked then the motor will spin and burn the belts.
Aug 18, 2009 | GE WBSE3120B Top Load Washer
Washing machine spins slowly and smells of burning rubber
The belt could be worn and will be slipping on the pullys, as it spins up the rubber , rubs against the pullys and that is what creats the burning rubber smell, the belt needs replacing.
regards jonno
Apr 21, 2009 | GE WBSR3140DW Top Load Washer
Kenmore Elite washer, model # 22942101 Spin cycle not working. The water drained out but the drum does not spin. It smells as if something burned out.
If the water drained out, then it sounds like the motor is still good.
I would check if the brake were failed in some manner since you smelled something, and if that is OK, then it's probably a failed gearbox.
Jan 27, 2009 | Kenmore 24032\24036 Top Load Washer
My kenmore 70 series will not spin water out
Sounds like the tranny is possibly shot. The motor spins backwards to extract, and if the tranny is bound up the belt may spin and burn.
Jan 24, 2009 | Kenmore 22422 Top Load Washer
Dryer drum wont turn- burning rubber smell
could be a stuck gear box. burning rubber smell is coming from the belt sliding .
or the belt is just loose and can not turn the drum to spin it.
tnx 4 using fixya,
drcool
Oct 11, 2008 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
