Question about Lexmark X2500 All-In-One Printer
Paper feeds into printer uneven
My printer feed the paper in crooked, I think one of the feed wheels is not working. The paper does not feed entirely in when printing. Is it possible to change the rubber on the feed in rollers?
  • 193 Answers
Check for anything obstructing the path of the paper..usually something very tiny! and clean the rollers with toothbrush & water.
Posted on Nov 29, 2008
Paper is pulled through crooked printing is not straight. how doyou clean the rollers?
This can be caused by several factors. It could be that there's something(like small foreign objects in the paper feed area) causing the paper to get crooked. It can also be caused by improperly adjusted paper guide or the paper is not in good condition.
Paper Feed Rollers Are Rolling But the Paper Is Not Feeding
How the Accu-feed Paper System Works
Mar 23, 2011 | Lexmark X75 All-In-One InkJet Printer
The printer keeps saying that there is a paper jam when there is not.. Also some times when it trys to print it will jam and the page will be torn down the middle.
Check the machine carefully, sometins a small sliver of paper is caught in a critical place in the printer and will give the paper jam message. If you paper is being torn it is most likely due to an uneven feed caused by feed wheels that are slipping on one side while the other side still feeds normally. Clean all the feed wheels in the paper path with a Q tip soaked in Isopropil Alcohol. Also make sure that your paper guides are set to the correct widths.
Jan 21, 2011 | Lexmark Office Equipment & Supplies
Paper is loading crooked and causing a jam
Sounds like there is something that has fallen into the paper feed path. Shutdown printer, unplug power from back of printer, and remove paper. With a flashlight, inspect the area around the paper feed roller for any debris (one time I found a penny lodged on the left side of the roller) that might have fell inside path and for damage to rubber wheels. Ink can build up on rubber wheels causing the paper to misalign. This can be cleaned off with q-tips and 91% Isopropal Alcohol or Dilute. If debris is found and cleaned then reload paper into feed path, make sure paper guide tab is in position against paper source. Plug printer power back in, turn on printer and push the paper feed button. If that doesn't fix problem the only other solution is the replace the paper feed roller or buy another printer. Let me know if this fixes the problem or if you find another issue. Have a Nice Day!
Jun 06, 2010 | HP Photosmart C6380 All-In-One InkJet...
Paper feeds crooked then jams?Used less paper different paper it just pulls the paper in unevenly the jams. Help
Check feed roller for contamination, fan the paper to seperate sheets and then make sure that you are using paper of the following standard:
Paper Type Thickness Weight Single sheets
(plain paper) 0.003 to 0.004 inch
(0.08 to 0.11 mm) 17 to 24 lb
(64 to 90 g/m²)
Make sure you are using paper supports and feed guides.
Apr 09, 2010 | Epson Stylus CX9400 Photo Printer
There are lines in the photos I print I've changed all of the cartridges
You may want try to cleaning the paper feed wheels. A dirty feeding machanism will cause uneven feeding speed and leave gaps on the print.
Dec 15, 2009 | Canon PIXMA MP980 All-In-One InkJet...
Paper jam! paper begins to feed then goes crooked
Please do all the things that you can do before you consider buying a new printer. You can take your printer into a service repair center or computer repair center in your place. If there is nothing that they can do then you can take an option of buying a new one.
Nov 28, 2009 | Lexmark X4530 InkJet Printer
Paper feed crooked or all at once
? More than likely, something is jamming the paper feed tray... Take a look and clean it out. It is also not entirely uncommon for the printer to have a problem with gap space between the "feed" roller and the actual mechanism that prints. If it has never worked properly, then your best bet would be to bring it back... I have run into similar problems and the new printer worked fine in most cases... Also check if you can adjust a slider to fit the page tighter...
Oct 05, 2009 | Dell 922 All-In-One InkJet Printer
Paper ALWAYS feed crooked.
Defective rollers or you have something stuck in a corner...look carefully or try cleaning the rollers with robbing alchool (remouves grease)
Feb 27, 2009 | Dell 924 All-in-One InkJet Printer
Samsung SCX-4200 manual feed prints crooked
You need to change the pick up rollers for your printer if it pulling the paper unevenly... but first check to see that the paper size adjuster on the tray i self is set to your paper likeness.....adjust to the correct paper size if not...
Please don't forget to vote!
Cheers!
Nov 13, 2008 | Samsung SCX 4200 All-In-One Laser Printer
Lexmark X2500 All-In-One Printer Logo
545 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
