Question about Whirlpool Washing Machines
Whirlpool Washing Machine does not spin in certain cycles
I have a Whirlpool Washing Machine Model # LA9480XWN2. When my wife is washing clothes, the spin cycle is not working in Permanent Press and Knit cycles. I am trying to find out if this is caused by the Timer?
  • 121 Answers
Yes the timer can cause that but it could be the moter but more likely the timer
Posted on Nov 29, 2008
Is Whirlpool AWT 5108 only a washing machine or a washing machine with dryer?
Washing machine usually have different wash cycles you can chose from. The washing machine should go into a spin mode to get most of the water out of the cloths at the end of the wash cycle. You might try another wash cycle on the washer and see if the washer goes into spin mode and gets most of the water out. If it goes into spin mode on one cycle and not another my experience has been it is the timer which is part of the switch where you chose which wash cycle you want.. My experience is only working on my washers and driers of the last 40 years. I have washed cloths with what ever cycle worked till I could change timer.
Nov 19, 2017 | Whirlpool Washing Machines
How do i get to the bottom of a failure to spin clothes i a whirlpool washing machine model awm320 which is an 800 spin model
Is the machine draining properly?
Have you checked the filter on the pump? What happens when it gets to the spin part of the cycle?
Is it knocking?
Does it go through wash cycle properly?
W
Nov 23, 2014 | Washing Machines
What will cause my Whirlpool washing machine to set on low speed spin cycle?
The machine uses automatic load sensors to balance the load and when you put something in the machine that is big, like a comforter, it knows that it cannot balance that item. So with a front loader it wont spin at high speed because it would be off balance and either damage the machine or the machine would "walk" because of the off balance motion.
Apr 28, 2014 | Whirlpool Washing Machines
Whirlpool washing machine make loud noise after spin cycle quits. Noise continues until cycle winds down. Sounds like a machine gun being fired
Hello,have to tell you that most noises from a washing machine occur during the spin cycle. If you hear loud thumping noise during the spin, the load of cloth may have become unbalanced. Stop the washer and redistribute the cloths, then restart the machine. Repeat these steps if necessary.
Thanks
Jun 04, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whilpool washers drains but when done spinning puts water bk out
If you have a selection for extra rinces deselect it and try. If not almost certainly your timer is faulty.
Jan 24, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine works, but wont do spin cycle- clothes sopping wet but clean
first off check to make sure its spinning at all. although the waters draining is it really spinning? are the clothes stuck to the side walls as if they had??if so i would tip machine back and look on floor and around the inside of cabinet approx 12 in. from ground level looking for oil,( transmission oil) . if present youll need a new transmission and clutch assy
Mar 04, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Washing Machine is going to explode(shakes and shimmies)
put your level on the machine Adjust the legs so when you push down on any corner there is no rocking - easy
Nov 07, 2007 | Whirlpool LSQ9600L Top Load Washer
check that the machine ramps up to spin speed reasonably and distributes the clothes- ie doesn't spring straight up to spin speed. if this is ok then the fault may well be the shock absorbers located at the bottom of the machine and going from base to tub. check also that the counterweights are intact
May 09, 2007 | Whirlpool LSN2000LW Washer
Washing Machines Logo
132 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
