Question about Kenmore 24 in. 16039 Built-in Dishwasher
Kenmore gas oven broiler.
S/N 91130469791.Oven works, broiler will not ignite. I plug igniter into wall socket & it will glow. Mounted in oven it won't get hot. Any help would be appreciated.
Limoloo
    Sergeant:
    Champion:
  • 338 Answers
Sounds like the relat for the ignitor isnt closing on the control board. take the back panel off and turn the broil on then on the control board test the broil tab to ground. (it should be labled.) you should have 120 coming out of the control. if you do not replace the control.
Posted on Nov 29, 2008
Oven,broiler won't light
The igniter is the most commonly defective part for a gas oven that won't turn on. The igniter has two main functions. First, the igniter draws electrical current through the oven safety valve to open it. Second, the igniter gets hot enough to glow and ignite the gas in the burner assembly. If the igniter gets weak, it will fail to open the safety valve correctly. If the valve does not open, the oven will not heat. To determine if the igniter is defective, observe the igniter when the oven is on. If the igniter glows for more than 90 seconds without igniting the gas flame, this indicates that the igniter is too weak to open the valve. If the igniter is weak, replace it. If the igniter does not glow at all, use a multimeter to test the igniter for continuity. If the igniter does not have continuity, replace it.
Kenmore Oven Won Turn on
Jan 20, 2016 | Kenmore Kitchen Ranges
KENMORE GAS STOVE OVEN , how to check if power is coming to the ignitor
The oven burner igniter
commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
Sep 07, 2014 | Kenmore 24 in. Gas Self-Clean Single Wall...
Kenmore gas oven; range&broiler work, not bake cycle-bad ignitor?
Well there are other parts that control the igniter,but if you can remove the igniter and look for any cracks.Most are hard to find so you may need a magnifying glass.Any crack no matter how small will keep it from glowing.The gas will not flow until the photo senser has detected the igniter glowing for several seconds.You can get a parts breakdown at SearsPartsDirect.com.Well hope this helps.
Feb 02, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
My kenmore gas oven won't heat. I turn to dial to temp i want can smell gas building up in oven and can see a glow in bottom of oven but will not ignite. Sometimes if I turn on a cooking eye I can then...
When the bake igniter becomes weak or burns out, your oven would not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
-- defective thermostat
-- defective selector switch
-- defective gas safety valve
-- defective gas valve coils
Oct 22, 2009 | Whirlpool SB160PEE Gas Single Oven
The lower oven ignighter does not glow
I had the same problem and swapped the oven igniter with the broiler igniter and the oven now works. This proved the oven igniter itself was the fault, now I have to replace the broiler igniter with a new one(which is much easier to get to).
FYI: An igniter may glow red and still not allow the oven to work. The igniter has to draw a certain amount of electrical current for the main gas valve to open.
Jul 20, 2009 | GE JGRP17 Gas Single Oven
My Kenmore oven wont ignite. The broiler works
The problem is your bake ignitor. The following link explains:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
The bake and broil oven features each have their own separate igniters and operate independently of one another. That explains why the broiler still works. They are, however, fed from the same gas source. So...the logical conclusion would be to replace your bake igniter (the no glowing is usually a dead give-away).
Replacements can be purchased on line at searspartsdirect.com, appliancepartspros.com, pcappliancerepair.com, or repairclinic.com. Prices can vary amongst sites, so shop around for the best price. The sites I provided to you, I found, tend to offer the best service and prices.
If you have questions along the way, or require addtional service, please let me know. I hope you find this information helpful.
Feb 28, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore gas range model# 362.72321 Oven will not ignite (sometimes)
Range Oven Temperature Sensor Part Number WB20K0004 Sears PartsDirect
This will be why the oven acts up. The broiler doesn't rely as much on this as the bake part does. Replace this and it should fix your problem.
Jun 14, 2017 | Ovens
Oven/Broiler Igniters for KitchenAid range KGST307
Oven bake ignites usually have lifetime 5-7 years. If igniter glows but gas not came in - replace igniter. Same with broil igniter.
Dec 09, 2008 | Ovens
Oven won't light
The igniter needs to be replaced. I had the exact same thing happen to my oven. The igniter would glow, but after tested, it did not have enough amperage to actually ignite the gas, so the gas kept running with no ignition
Jun 23, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Broiler Works/Oven Doesn't
Jrzy, even though you can see the bake igniter glowing, that doesn't mean it's good. Igniters actually get weak (unlike a light bulb that simply burns out). It's hooked up in series to a safety valve (the valve that allows main gas into the oven) which actually reads the amps flowing through the igniter. If the igniter is weak and the amps are too low, the valve won't open up. Replace your igniter and you'll be cookin' with gas again. Tip---> before you unscrew your old igniter, put a little liquid dish soap on the threads for lubrication. This'll ensure it comes out with no problems.
Sep 14, 2007 | Kenmore 30464 / 30465 / 30469 Gas Single...
Kenmore 24 in. 16039 Built-in Dishwasher Logo
99 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
