Question about Sony CDX-L400X CD Player
Writing on screen very very faint
The LCD screen isn't readable. You can see the the writing on the screen very very faintly, but it's not coming up in its usual **bright red** font. Is this a problem with the removable front or the main body of the radio?
  • sweavo Dec 22, 2007
    Hey all, I have the same problem but I decided to get the soldering iron out and take a look. Behind the LED panel there are two bulbs. Anyone know what voltage these are or what a suitable replacement part is? Thanks
  • Anonymous Oct 26, 2008
    Same problem here, thanx for the fix:)
    i didnt however simply bridge it, i put a 5 ohm resistor in place, just like the other bulb was (i checked).
    thanx a lot,
    Thomas
Thanks duncan, the knowledge that this was just lightbulbs was enough for me to hack a fix for my own unit. The result is not perfect but it's functional. If you have a small amount of soldering skill and a very basic grasp of electronics then this hack is very easy:
The problem is that there are two lightbulbs behind the LCD screen that illuminate a piece of translucent plastic. The bulbs are connected in series, so if one blows they both go out. My fix involves simply connecting a piece of wire across the blown bulb thus allowing power to reach the good bulb. In theory this alters the electrical properties of the circuit and may end up in death of the other bulb or worse damage. I've had about an hour's use out of my unit since doing this with no ill effects (it came with a car I just bought so I don't mind too much if it dies).
You only need the front panel. Unscrew the four screws on the back of the front panel and prise it apart. It's best to do this with the silver side down as there's a bunch of bits of plastic for the buttons that will fall out all over your bench if you hold it the other way.
To do the investigation I removed the LCD panel but this is not necessary for this fix. Look at the picture:
(On the pic, the LCD and bulbs are removed, so yours will differ a little from here).
The bulbs are wired at ba and bc. Connect your multitester across ba and check the resistance. If it's infinity, that's the blown bulb. If it's less (e.g. about 5 ohms) then that bulb's fine. Do the same across bc. Then, on whichever is blown, get a small piece of wire and solder it across. For a final check, connect the tester across A-C on the front panel connector (that's the top left and bottom right pins). If you see infinity, you either fixed the wrong bulb or didn't make a good connection.
Obviously, don't get solder on any other parts of the circuitboard or you're creating new circuits!
Posted on Dec 23, 2007
    Novelist:
    Champion:
  • 219 Answers
More than likely you have burned out the tiny little light bulb that is soldered into the circuit board behind the display to provide a back light for the display. This is not a bulb that is consumer replacable. You will need to go to a repair shop. Good luck.
Posted on Jan 16, 2007
The bulbs are 6 v 100 mA, i do have 20 in the house
Posted on Oct 05, 2008
SOURCE:
Black screen
Does anything ever show up on the screen at ANY point? If you shine a bright light at the screen when the computer is turned on can you see a faint image or writing?
Jan 05, 2014 | Toshiba satellite c660
White Screen, Video is readable but faint
Any time there is a distortion in the picture/graphics on the screen, this is an indication of a defective LCD display. LCD displays can fail even if the screen isn't cracked. It sounds like the graphics are washed out. More info on defective LCD displays can be found here:
http://www.sharc.net/gps_LCD_repair.htm
Nov 07, 2013 | Garmin nuvi GPS
While in use screen went black, but you can see writing but is very faint
most likely your LCD CCFL bulb went out... they are relatively cheap to fix and any reputable repair store could fix it for you... you simply order a new bulb and in less than an hour in most cases your system is repaired.
Jul 14, 2012 | HP Pavilion G60-235DX notebook
Averatec e1200 laptop i think it caught a virus but now when it comes on you cant see the screen can see writing very faint if you shine a light on it...is there a something in the screen that could be...
Hold the delete button when you turn it on and see if it loads BIOS up. If the screen displays the BIOS OK then you can change the boot sequence to CD/DVD or USB first and do a fresh windows installation. You could also try holding F8 at bootup and try loading safe mode. If this doesn't help it could be a problem with your screen or the wiring going to the screen. Possibly also a problem with the graphics card.
Nov 23, 2017 | Averatec Computers & Internet
Got 2 faint white lines on screen on philips 42 lcd ambilight
Sounds like plasma burn in. I'm fairly positive this TV has a white out burn in removal in the menu somewhere. Look for it. It should be a program that makes colored static all over the screen or a white scrolling bar followed by black fading into white again. Run it for an hour or so. If that doesn't fix it, there's not much else you can do.
Jan 05, 2009 | Philips 42PF9630A 42 in. Plasma Television
Cant read front display contrast too low?
Call ,1-800-835-6100. Have your serial number ready etc. Procede through the prompts. There is a known problem with that display and Xerox will replace it for you. They will send you one and it is real easy to replace.
Nov 15, 2008 | Xerox Phaser 8500/DN Printer
Lcd screen faint display works ok with external monitor. model argo c
Could be the backlight of the laptop. When the laptop is running try tilting the screen back and forward till you notice what may be your OS...
If so your gonna have to contact a local repairer for your laptop brand...
Oct 13, 2008 | Computers & Internet
Motorola L2 display problem
you need to take the phone and have the LCD replaced
Jul 16, 2008 | Motorola Mobility RAZR V3
Screen come on but very very faint
first reset ur phone then if it dont work open the lcd portion and pres the jack. ur lcd should work. reply me
Jun 05, 2008 | Motorola Mobility RAZR V3
Compaq presario 900 lcd not working, shows faint image
out put connection from the video card to the LCD monitor is loose or malfunctioning. check the connection that leaves the video card to the monitor, ensure its secure and clean, if still not working then its either the video card or the cable connecting to the LCD.
Dec 11, 2007 | Computers & Internet
Sony CDX-L400X CD Player Logo
338 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Dalynn Turner
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
