Question about LG WM-1485FHD Front Load Washer
Washer the product in question is a lg wm-1458fhd washer. the washer does not take the fabric softner into the drum on normal wash cycle,but stays in the drawer. i have cleanrd out the drawer thoroughly,including the compartment. i am quite acompetent diy'er! can anyone help?
  • cindya Nov 04, 2007
    I have an LG washer, also..model number WM2016CW. When the washing cycle starts, the water goes through the fabric softener drawer first..wondering IF its supposed to do that?? Says in the owners manual, the fabric softener will 'add' at the last rinse cycle..I don't think this is quite right..anyone else have this issue before I call the mechanic?
I managed to solve this problem on my own on the lg washer,
the fabric softener drawer/compartment had to be comletely stripped and thoroughly,cleaned, ideally with a pressure washer. This did the trick perfectly!
Posted on Jan 02, 2008
FASULT CODE C L
Water is coming up in fabric softner cup during rinse time front loader
this is normal
water should go thru the softner and into the drum when the machine rinses to introduce the softner to the drum
Dec 05, 2014 | Kenmore Elite 45986 Front Load Washer
Tip
If you are experiencing greasy marks on your cloths, let me ask a question. Are...
90% of greasy marks on cloths is due to scum build in the outer bowl of your machine...top loaders being the most vulnerable. prevention is better than cure. At least one hot wash a week on high level. If your machine is an early model one or two with a good bleach subject to manufacturers instruction...bleach is very cost effective and works well.
on Apr 10, 2008 | Bosch WFMC 3200 Front Load Washer
My LG WM2487H has water in the detergent cup at the end of the wash. It has happened twice now.
This is normal.
All LG washers use a siphon system to dispense soap, bleach and fabric softner.
Some times water will remain in the cups depending on the cycle used.
Jan 20, 2010 | LG WM2487H Front Load Washer
OIl stains on clothes with front loading LG washer
ftr loader washers do not have any oil, my guess would be you are using fabric softner . that can stain clothes. dilute with water, they are very concentraded. or your dispenser may not be working properly and not releasing softner at the proper time.i would run a clean cycle through it. meaning set on a hot wash- regular cycle no clothes and run wirth bleach in bleach disenser. do this every other month to keep washer clean hope this helps. make sure its not happening in the dryer , the dryer has frt and rear seals that go bad and start leaving marks on clothes and catching them in beteween the tub.
Sep 16, 2009 | LG WM-2032H Front Load Washer
Fabric softener does not drain out of dispenser
Hi. Remove dispenser and thoroughly clean, are you sure you have cold water going into dispenser?
Nov 25, 2008 | LG WM-2277HW Front Load Washer
Lg wm2277h has low water level
The water level is very low on front load machines. (Below the bottom of the door) While the washer is running, push and hold the "spin speed" and "soil level" buttons at the time. Display should be between 230 and 255.(normal) If you do this while the machine is filling, you will see the numbers change. This machine only uses about 12 gallons of water for an entire cycle, vs. about 45 for some top loading machines. THIS IS NORMAL ! The machine will adjust the amount of water based on the type and volume of clothes in your washer. On a large load, you will see wet clothes, but no water sloshing around. PS. Because the machine uses so little water, make sure you use only one tablespoon of HE detergent (and only one teaspoon of fabric softner if you use it). This is very important.
If this info was helpful, please rate it as a "FixYa". Thanks.
Oct 01, 2008 | LG WM-2277HW Front Load Washer
Fabric pulls on gentle cycle
Check the inside of the drum to see if there is any loose vanes.  Then check the holes in the drum itself to see if there is any protruding metal shavings that is causing the problem.  There should be no rough edges at all.  It sounds like the drum is the problem.
Apr 15, 2008 | LG WM-1832C Front Load Washer
Fabric softener always left in tray
hi there are you using concentrated softner if so water is down as some softners are to thick to go through the dispenser also give the whole drawer a soak in hot soapy water incase there are any blockages.
hope this is of some help
Nov 11, 2007 | LG WM-1480FHD Front Load Washer
LG WM-1485FHD Front Load Washer Logo
171 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
