Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
The fridge just keeps running, it?s been two day already
Hi. My fridge just keeps running even though everything is cold inside as it was before. Tried to unplug it and turn it on again, did not help. Any suggestions? Thanks
  • eugeneg13 Nov 29, 2008
    Ok, here’s the thing. Before it was working for about half an hour and turning off for at least an hour and everything was nice and cold inside. Now it just keeps running. Can it be thermostat? Fridge is about two years old… That thing is eating my energy bill now:)
    Sergeant:
    Champion:
  • 311 Answers
Doubt anything is wrong here- let it run. These run 80% of the time anyway. I cannot see your reply due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Posted on Nov 29, 2008
Hi, my refrigerator Panasonic NR-B320T non stop running, both vegetable and freezer sections are GETTING FREEZED even though the temperature are set at 1 (cold not at 3, the coldest).
check your user hand book as most fridge settings work the lower the number the colder the setting
so 1 is around 1-3 degrees , 3 is 4-6 degrees, 4 is 7-10 degrees
it is the freezer that works 1 is minus 5 and 5 is minus 20 degrees
it would explain why everything is freezing up
it would also explain the non stop running as the fridge is battling to keep the low setting
Nov 23, 2016 | Panasonic Refrigerators
Freezer is not cold enough, even though the control panel says that the temperature is where it should be.
pull the panels inside and check the fan usually in a fridge freezer the fan cacks out or is full of ice clean it out and clean the overflow tube if fridge is cold enough then it is the freezer fan
Jun 07, 2015 | Samsung RF323TEDBSR 31.6 Cu. Ft. French...
Fridge Ices Up Even on the Warmest Setting (Freezer Working Fine)
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
If it runs then that cold control is the problem.
Sep 15, 2017 | Refrigerators
Fridge not cold enough and freezer too cold
check the fan to see if it is running.
Sep 20, 2012 | Whirlpool Refrigerators
GE TBX23 will not get cold. It has not been run in a year. Any ideas?
the obvious things to check is the temp gauge inside the fridge. is it turned up far enough? if so, then the gas inside the fridge is no longer useable. meaning you cant use the fridge anymore and a replacement is required.
even though the fridge has not been used in over a year, the gas inside acts just like battery does, if a battery does not get used for so long, the power still runs out and eventually the battery looses its charge, the gas in a firdge acts the very same way
Jul 17, 2012 | GE Refrigerators
Miele fridge too cold
Hi I have the same problem...did you find the solution?
Jul 18, 2009 | Refrigerators
GE fridge GSH22KGMA not getting cold
you need to replace the gasket on the unit . its letting in too much moisture.. the drain line may also be clogged up and holding water in the drain pan. take a piece of wire and clear the drain then poutr hot water and baking soda down it witrh a turkey baster.
Apr 05, 2009 | Refrigerators
Servis Fridge not cold enough
Hi ruthcart1,
I'm Harvey the Master Plumber.
Your problem is: You have a free standing fridge freezer from Servis (silver) and the fridge doesn't seem to be as cold as it should be. The freezer is absolutely fine just the fridge even though you have adjusted the thermometer inside.YouI've had it maybe 3/4 years.
You're still under warranty. Modification now voids the warranty. I would call warranty repair. This should be their headache not yours.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 10, 2008 | Refrigerators
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
194 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
