Question about Thermador Kitchen Ranges
My thermador gas cooktop has suddenly started to show a lot of yellow flame rather than blue flame. Research leads me to believe that the gas and air mixture needs to be adjusted. Is this something I can do myself? If so, where is the air baffle adjustment located?
  • mftokc Nov 29, 2008
    The burners are described as being "sealed" and they are covered with a star shaped burner cover that distributes the flame. All of the holes on the covers are clean and open. Each of the four burners started burning yellow at the same time. Any thoughts?
  • 121 Answers
The burner should never need re adjusted it may need cleaned
Posted on Nov 29, 2008
Yellow flame
The problem is with the orifice leading to the burner. If it is not centred then you will get yellow flame. Or you are impeding the flow out of the burner and it is not mixing properley. I would pull the burners apart and make sure everything is clear and the orifice is centred.
Apr 14, 2014 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
One of the 4 burners has a LARGE, YELLOW flame (right rear burner). It just started today. Other 3 have a BLUE flame. Using Propane Gas Is this a fuel/air mixture problem, and if so, how do I fix...
The yellow flame suggest incomplete combustion is taking place and on a flueless appliance Otis very dangerous, check for dirt/greese that has accumulated aroroud the gas jets ( this will dercrease air available at the primary airport) if this is clean then your gas jet may be worn and become larger allowing more gas than air as they mix, in this case you will have to replace the gas injectors
Jul 12, 2011 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
I am using propane for my cooktop but all my pots and pans have been turning burnt black soot on the bottoms. It's ruining all my other dishes now from the dishwasher spreading it all over, We tried...
You don't have the right Gas to Air ratio..... Not enough air to the burners or you are running to low of gas pressure for propane... Propane takes a smaller orfice or operate than Natural Gas.....
You should have 10" of WC for Propane operation..
You will need a manometer to check it.
The flame should be a blue color with no yellow in it. There should be air shutters right at the orfice to each burners. You will have to play with the adjustment to get the best blue flame with no yellow in the flame.... Hope this helps.....
May 17, 2011 | Jenn-Air JGD8130 Gas Cooktop
Looks like the flame burnt the stainless on my cooktop. Only had it 2 months and now there are 2 blue stains on it :(
I have the same issue - front left burner - two blue burn stains. Have you found any solution to this yet? major bummer.
Mar 05, 2011 | Thermador 37 in. SGSX365 Gas Cooktop
I have a new gas hob which is making the bottom of my pans black like soot?
You must have an improper air/gas ratio. To adjust the shutters you simply open or close them a hair till you get a beautiful blue flame. Improper flame is yellow, good flame is blue. 9916a1c.jpgThis gas conversion training manual shows where to adjust
Apr 22, 2010 | Cooktops
How do I know if the appliance store actually changed my cooktop to LP with a conversion kit? I'm beginning to wonder because I found a conversion kit in a box of supplies...it's been a year since they...
You should have voiced your concerns long ago with the store you purchased it from. But if they did not convert it, you would have large, yellow flames.Proper burner flames will have no yellow in them. They should be only a blue flame.
Jan 10, 2010 | Thermador PGR366 Gas Kitchen Range
Installing thermador cooktop do you need a 1/2'' gap between bottom of cooktop and below exterior cabinet?
Yes, the air gap is to make sure that too much heat does not transfer down to the wood below... and start a fire... believe it or not air is a great insulator...
heatman101
Oct 22, 2009 | Thermador SGS36GS Gas Cooktop
Soot deposits from my brand new downdraft jenn-air gas cooktop
Is this on LP or Natural gas? If LP was it converted to LP? In any event,The air shutter must be adjusted on the gas burner tube. You need more air. The valve orifice may also need adjusting.
Sep 28, 2009 | Jenn-Air JGD8345 Gas Cooktop
Creda 4 burner, converted to LP
Your flame is perfect if it's just the very tip that is yellow or white. All burners should be adjusted this way, on highest flame.
Mar 13, 2008 | Jenn-Air 36 in. CCG2523 Gas Cooktop
Kitchen Ranges Logo
285 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
