Question about Wharfedale Atlantic 500 Main / Stereo Speaker
Speaker s500 speaker only works when you push cone slightly into magnet
    Problem Solver:
  • 5 Answers
Quit doung that immediately because you will burn out the amp ic ...replace the speaker pal..
Posted on Jan 17, 2007
SOURCE:
Sounds good just crackles in the speakers
Car speaker crackles because of dust or loose metal debris getting into the magnet structure. Just try pushing the cone of the speaker down with your finger if you hear scraping sound you have magnetic debris in your voice coil gap. Is is very difficult to get this out because your speaker magnet is very powerful. But all the same try blowing air with a vacuum cleaner , might dislodge the particle if you are lucky.
Jul 26, 2011 | Pioneer PD-F905 101-Disc CD Changer
One speaker no sound
I just want to confirm that the solution on another page from francis 8 works perfectly ( http://www.fixya.com/support/t3709832-speakers_stopped_working_cannot ). We have two sets of Creatures in our offices, one had been shelved (by someone less persevering than me) due to this problem years ago and my set started this trouble a few days ago. Troubleshot everything, every cable, setting, combination, spare speakers etc - nothing worked. Opening the offending speaker and pulling back the metal weight behind the speaker cone was the solution for BOTH of our units.
Big smiles all around :-)
Note - When you've opened the plastic shell and loosened the speaker from its mounting, the the big round metal piece/magnet sits within the actual speaker 'cage', slightly behind the speaker cone. It's tight but movable and can be pulled all the way back as far as it can go inside it's housing, away from the speaker cone.
Not sure why it gets pulled forward, but it isn't fixed in position and so could clearly get bumped by dropping the speaker or a reasonable impact of some sort. Once bumped forward it would severely limit cone movement and therefore volume.
May 07, 2010 | JBL CREATURE II Computer Speakers
How do u disassemble the jl 12w7, the cone is stuck
if the cone is stuck, it is possible because the voice coil over-heated. There is really no way to disassemble the speaker without re-coning it. The thing you can do is manipulate the cone with your fingers gently, and it might release. Be careful. hope this helps.
Mar 27, 2010 | Jl Audio 12W7 Car Subwoofer
Sub-woofer driver rattle/buzz.
Bad news! It sounds like the coil is rubbing inside the magnet of the speaker! There's no cure, when the cone is warped it it knackers it up. Had the same problem some years ago with a Wharfedale speaker. Someone told me you can hit it on the part where the cone joins the magnet -with a hammer!
Anyway it didn't make a bit of difference! And the speaker was chucked.
Feb 09, 2010 | Polk Audio PSW150 Speaker
My speakers stopped working. Cannot increase the volume, have to put ear very close to hear a faint sounds
I fixed a similar problem I was having. It requires a little work.
Take out the four screws from under the broken speaker. Carefully remove the cover, separating the speaker from the base. The two are wired together so don't pull them apart with force. Then remove the single screw, which is much larger the the previous four, and separate the speaker from the top cover.
If you chose you can remove the wires from the speaker, they just snap on, but its not required.
What I found is the speaker issue is not with the wire or the power, but the speaker it's self. On the back there is a big round metal piece. On my speaker that piece was pushed towards the front of the speaker. When I looked at the good speaker, that big piece was all the way back. So I simply pulled it back and presto, instant fix!
I hope this works for you.
Dec 25, 2009 | JBL CREATURE II Computer Speakers
My basslink worked great, son blew fuse, replaced, now sounds lik
If the speaker has been overdriven, it may have damaged the cone surround or damaged the speaker coil, causing it to 'rub' inside the magnet. To check for rubbing, you need to move the speaker cone backwards and forwards by hand and listen where the speaker coil/cone goes into the magnet. It should be silent if ok. If you can heara rubbing or grating noise, then the speaker is damaged. If the output driver on the amp is damaged it can give a distorted sound, which could easily happen if it tries to provide too much current.
Nov 04, 2009 | Infinity BassLink II Car Subwoofer
I have a 12 inch ORION HCCA dvc, 4ohm sub. My
Halving the impedance will draw twice the current. You could technically get a 3 Db more power since the peak voltage will remain the same. BUT if the magnet structure is not intended to use that cone design, the magnet difference MAY not give you 2 ohms.
In fact, if the designed magnetic flux were smaller, you could wind up with a 1 ohm speaker.
trying to get that much power is really kind of silly as even 50 watts with efficient speakers will exceed safe levels of sound that will not cause damage to your ears.
As you push an amp up in power, usually distortion will increase as well.
Oct 26, 2009 | Orion HCCA 12D Car Speaker
The magnets came lose is there a repair place that can realign and attach my magnets
flip the speaker upside down n it should b a hole thats where the screw is a woffer is nothig but a cone n a magnet
Jun 01, 2009 | Kicker CompVX CVX104 Subwoofer - 10" Dual...
Speaker repair
Contact MMats Pro Audio at 561-842-0600. They can re-cone it for you, or sell you the re-cone kit. If that does not work for you, contact MWA Speaker Parts in Tuscon - 520-647-7193. They can sell you a re-cone kit, or they can direct you to a speaker repair center near you. A third option would be to contact Sundown Audio in Troutman, NC. They may be able to re-cone it for you.
Apr 18, 2009 | Mmats Juggernaut 15'' Car Subwoofer
Speaker disassembly
is the cone damaged..you cannot seperate the cone from the magent without damaging the speaker..what do you mean by stabilize the speaker cone ?
Mar 05, 2008 | JVC TH-M505 System
Wharfedale Atlantic 500 Main / Stereo Speaker Logo
126 people viewed this question
Top Wharfedale Audio Players & Recorders Experts
Joaquim Martins
 Grubhead
Grubhead
Are you a Wharfedale Audio Player and Recorder Expert? Answer questions, earn points and help others
