Question about Acer Aspire 3610 Notebook
Acer aspire 3610 shuts down while trying to boot
I have an Acer Aspire 3610, that will not boot (Windows XP Home)- I get a blue splash screne saying that the "video driver failed to initialize" and the system will be shut down to prevent damage. I tried to restore the system to the factory defults, using the eRecovery, and recovery disks that I purchased from Acer. and the system still shuts down. I also tried to install a new hard drive, but all I got was a blue splash screne saying "no operating system found" then the unit shut down. I had been getting a blue splash screne for about a week before this happened saying that "one of your disks needed to be checked for consistancy", the disk checker would then run, find no problems and the unit would boot, but it often shut down when I was on the internet. I would restart the unit. the disk checker would run, then the unit would boot again. Any ideas, anyone?
Acer aspire one nav50 how to install windows on new hard drive
To install windows on a hard drive you have to boot from a CD with windows XP on, after which it will ask you to press a button.
After which you can follow the setup instructions in windows XP.
Mar 01, 2012 | Acer Aspire One PC Notebook
I installed the Windows 7 Home Premium upgrade (store bought) and now my Acer Aspire 5735 gets blue screens, shuts itself down, and random programs get the "**** has stopped working" message.
you shouldn't of installed it because if you would of ran the windows 7 compatibility thing that is on the disc, it would say that your computer is incompatible. You should buy another copy of windows xp and install that.
Jun 16, 2010 | Acer Aspire 5735 Notebook
I have the acer aspire 5532 and windows error recevery keeps coming up please advice. It makes a weird noise and a blue screen pops up that says a problem has occured......
You will have to do a repair of your windows installation. You need to boot on your Windows DVD and do a "Repair" install. OR if you have System Recovery in the PC then you should try that first. Also you could try booting up in SAFE mode, press F8 before it boots, and when, if? it boots to desktop you could either troubleshoot, or restore your system to another time using system restore.
Jan 27, 2010 | Acer Aspire 3610 Notebook
Acer aspire 5920 laptop is not shutting down.
Try to shut down it trough it frm shortcuts keys given on laptop or you can even re-install windows (if u hav no important data in tht laptop).
May 07, 2009 | Acer Aspire 5920 Notebook PC
Windows Xp Sp3 installtion problem with Acer Aspire M1641 Desktop, there is a problem with installion of windows Xp in Acer Aspire M1641 Desktop. A blue screen is appearing. Saying that use CHKDSK /F...
http://komku.blogspot.com/2009/01/aspire-m1641-m3641-m5641-windows-xp-and.html
read down in comments for link on how to use Nlite and adding raid driver that will solve your problem
Mar 15, 2009 | Acer Aspire M1641-U1521A PC Desktop
Factory settings?
Try this, if you are running xp i know it will work.
Start menu> All programs>Accessories>system tools>System restore.
This will restore your computer to factory and you won't loose any data. If you want to start fresh with nothing installed, install windows with the cd and choose fresh installation and follow the direcions.
Jan 22, 2009 | Acer Aspire 3610 Notebook
I connot wifi connection on acer aspire 3610 in windows xp
1. check that the ipo address is set to automatic - not assigned
2. try pinging the router - you may be connected but the dns server may be an issue
Nov 18, 2008 | Acer Aspire 3610 Notebook
Acer aspire 3610 not booting pass flash screen
you can reinstall os with ur xp.
with xp disk in drive at startup do you get option to boot from cd.
if not go into bios at startup and enable cd boot in boot options as first;save and exit;restart.
I assume you know how to install windows(xp)
Mar 03, 2008 | Acer Aspire 3610 Notebook
Wireless network
If it is an internal card you should be able to obtain them from Acers website. If it is an external go to that vendor and extract the files from them!
Nov 21, 2007 | Acer Aspire 3610 Notebook
Acer Aspire 3610 Notebook Logo
332 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
