Question about Epson Stylus CX6400 All-In-One InkJet Printer
My printer will not print. The ! and setup light is on.
  • 96 Answers
Check to make sure all lids doors are provperly closed
Posted on Nov 29, 2008
Usb light link
HP LaserJet 1022 is a "host-based" printer so it must be connected to a PC. Load the driver on PC first and connect the USB cable when software tells you to do so.
Will not work on a Linksys print server.
LaserJet 1022N & LaserJet 1022NW have "special" HP print servers that can support HP host based printers.
Nov 27, 2013 | Linksys Wireless-G WPS54GU2 Print Server
Unable to communicate thru WiFi to print
A solid green Wi-Fi light indicates that it is connected to a wireless network. An orange light indicates that it is not connected to a network.
Another way to determine if your printer is connected to your network is to print the wireless network setup page. From the printer operator panel, press the Setup button (wrench icon) > Network Setup > Print Setup Page. Your printer will then print the network settings. Check the SSID, signal strength, or trouble code.
A quick fix to this problem (especially if your printer was working fine before with your wireless network) can be achieved by resetting the printer and/or rebooting the PC.
Oct 20, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
I can't get my Macbook setup to use the Lexmark x6650. I used the install disc and the wifi light on the printer is green, but I still cannot figure out how to setup my Macbook to print to is...
Print the network settings page to identify if your printer is connected to your wireless network:
1. Press Setup on the printer operator panel.
2. Press the right or left arrow button until Network Setup is displayed, press OK.
3. Press OK at Print Setup Page.
4. Press OK when prompted to Load Paper.
5. Press OK. The network settings page will now print.
Check the Network Card Status, SSID, Trouble Code, TCP/IP Address. SSID should be the name of your wireless network. Otherwise, you may need to reset the printer's wireless network settings.
How to reset network settings:
1. Press Setup.
3. Press the right or left arrow button until Reset Network Adapter Defaults is displayed, press OK.
4. Press the right or left arrow button to display Yes, pressOK.
Once the Wi-Fi light turns on to solid orange, run the Lexmark Wireless Setup Assistant on your Mac.
Sep 21, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
Cannot get the wireless connection to work on the printer. The USB cable is connected to the back of the PCU. I've installed and uninstalled twice and nothing. It did work when I first got it and...
Here are some guidelines to identify and fix your wireless communication issue:
  • What is the status of the Wi-Fi light on the printer? Green light means that it's connected to a wireless network while Orange light means it's not connected to a network.
  • Try to print the printer's wireless network settings to determine if it's connected to your own wireless network. On the printer operator panel, touch the Setup button > Network Setup > Print Setup Page. Your printer will then print the its wireless network information page. Ensure that the printer is connected to your network by checking the Network Card Status, Wireless SSID, Quality or Trouble Code.
  • If printer is not connected to your network, you may need to reset your printer's wireless network settings. On the printer operator panel, press Setup button > Network Setup > Reset Network Settings. The Wi-Fi light on the printer will momentarily turn off then back on to solid orange. You can then run the Wireless Setup Utility application on your computer to reconfigure the printer to connect to your wireless network. On your computer, launch the Lexmark Printer Home application > go to Settings tab > Wireless Setup Utility. Please follow the instructions on your computer screen.
If you still need assistance, please contact Lexmark Technical Support Center for additional assistance.
Aug 21, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
I think I accidently cleared my wireless wifi on my printer.... the wifi light is orange instead of green so not connecting
Try to print the network settings page to determine if your printer is still connected to your wireless network or not. On the printer operator panel, press the Setup button -> Network Setup -> Print Setup Page. Check the SSID if the printer is still registered to your wireless network. If not, you may need to reset your printer's wireless network adapter. Press Setup -> Network Setup -> Reset Network Adapter. The wifi light on your printer will then momentarily turn off. Once it turns on solid orange again, you may reconfigure your printer to connect to your wireless network.
If your printer is still registered to your wireless network, then it could be just a slight communication problem. Try to unplug and replug your printer into the power outlet to reset it. Doing this usually fixes minor communication issues.
May 03, 2011 | Lexmark X4690 Wireless InkJet Printer
My lexmark x4650 printer is connected to the wifi, but the orange light is blinking. And nothing is able to print. When I look at the printers activity it shows the document that im trying to print but...
When you installed your printer, you had to install the software on your PC. So go to your PC's start menu, go to Programs, select Lexmark software, select Tools and then select Wifi Configuration Utility. It will open a window which will give you step by step instruction on re-configuring your wifi settings. When you are doing this, make sure your printer is connected to your PC via the USB cable.
Apr 07, 2011 | Lexmark X4650 InkJet Printer
How to turn on wifi
Configuring the optional internal wireless print server
If you purchased the optional internal wireless print server after your printer was already set up, follow these steps:
1 Install the internal wireless print server into the printer. For more information, see "Installing an optional internal
wireless print server" in the "Setting up the printer" chapter.
2 Click Start Programs or All Programs Lexmark 3500-4500 Series.
3 Click Wireless Setup.
4 Click Start.
5 Follow the instructions on the computer screen.
6 Click Finish to complete the installation.
Also here is the link to the setup guide and user manual
click here
configuring the wireless is in the setup guide
Oct 18, 2010 | Lexmark X3550 All-In-One Printer
Hp deskjet 3940 will NOT print
printer is om light is on not blinking and not printing
Feb 19, 2009 | HP DeskJet 3940 InkJet Photo Printer
Mac Address
Hello Tydabuan,
Please perform the following to be able to print a network setup (configuration) page.
1. When the Ready/Data light is on solid, press and release Continue to print a menu
settings page and a network setup page.
In the Network Setup Page itself, you can find the MAC address of the printer.
thx
Oct 09, 2008 | Office Equipment & Supplies
Zonet ZPS1001 can't detect Konica Minolta Magicolor 2400W
Persever. Change your usb points, and at the last resort get the cord from your old printer and use this type of connection. Go slowly thorugh the disc step by step and make sure you delete any previous installations of the print file in the control panel.
Oct 28, 2007 | Zonet 1-Port USB 2.0 10/100 Mbps Print...
Epson Stylus CX6400 All-In-One InkJet Printer Logo
29 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
