Sony red warning light flashes 8 times - Televison & Video
  • 1 more comment
  • stupot100390 Nov 29, 2008
    UNIT WONT POWER ON AND THE RED LIGHT FLASHED 8 TIMES
    MODEL KE42MR
    THANKS
  • madman1515 Jan 25, 2009
    My 2 year old Sony kds-60a2000 will not power up... the Red power lcd flashes 4 times.
    the first time this happened about a year ago, I (VERRRRRRRY CAREFULLY!!!) disassembled the cooling fan and vacuumed the dust out of the back vents and fan housing, reassembled the tv and it worked fine for a year. This happened again a couple last week and I went through the same routine of removing the rear panel and cleaning behind, around and inside (AGAIN, VERRRRRRRY CAREFULLY)... same routine with fan housing too. Reassembled and powered up. TV again worked; however, this time it would not power up the next morning and the 4 red flashes were back on the power indicator.
    Appears to be a dust / cooling problem, but unsure now.
    Have not been able to bring myself to pay a tech 100's of dollars for this problem after having just spent $370.00 a little over a year ago to have the lamp replaced 10 days after the factory warranty expired... and again purchasing a replacement lamp 2 months ago on E-Bay for $100.00 to replace the ($370.00 / 11 month old) SONY bulb yet again.
    Set is filled with problems.... think someone else summed it up well with "It's a Money Pit."
    Instead of a "hole in the water one pours money into...!" (i.e. BOAT)
    This set is a "hole in the living room one pours money into..." (i.e. SONY)
    If someone knows how to fix without service tech $$$ please let us know!
    Thanks!
  • Any Guy
    Any Guy May 11, 2010
    Could you provide the model number?
  • 320 Answers
The most likely failure is either the G1 or G2 power supply boards, but it will take a qualified technician who is familiar with this set to narrow down which one is bad. Basically you are looking at a power supply fault, either a component in the power supply has failed or something is loading the power supply down causing the fault.
Posted on Nov 29, 2008
Sony Bravia KDL-46W3000 - Shuts off after 30 sec followed up with 6 red blinks.Last 3 days back cover off has been working fine. What board should I be replacing?
Sony Bravia TV kdl- red blinking led light error codes ...
? 10:28
https://www.youtube.com/watch?v=0KGysXbxnaU
Mar 28, 2015 - Uploaded by Tampatec
Sony Bravia LCD TV KDL models red blinking led light error codes & possible ... with perfect picture, no warning signs and it just shuts off. is it that quick? ... with the following problem: I connect the power grid lights Standby red light. ... the title before deleting, it is very fast after that flashes Standby 6 times.Missing: 46w3000 ‎30
Nov 18, 2015 | Sony BRAVIA KDL-46W3000 Television
How do fix my 5 inch sony the light flashes 8 times
Prior to this were you getting a bright red, green, or blue screen with trace lines?
Apr 03, 2012 | Sony KP-57WS500 57" Rear Projection...
13 red standby flashing lights -- turns on, then turns off
Are you sure about the 13 flashes. Error code only goes to 8 flashes.
Apr 25, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
SONY KV-32FS120 LIGHT FLASHING
Same problem with me. I unplugged for 36 hours and it solved the problem
Mar 28, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony wega kdf-50e2000 standdby light blinks 8 times
8 BLINKS B -10.5 IS OVER VOLTAGE (B-BOARD) If your a novice call Sony or a Sony authorized service center.
Mar 25, 2009 | Sony KDF-50E2000 50" HDTV
Sony 5 projection tv kp-51ws510 no pic, light flashs 8 times
I have the same model TV and have had that same problem (*8 flashes) The FLYBACK TRANSFORMER on the D circut board is the most likely cause and will need replaced) the part is around $70.00 USD!
Please rate my response
THANK YOU!
Jan 22, 2009 | Sony KP-51WS510 51" Rear Projection...
No sound or screen
8 time flash shows problem with T8005 (flyback transformer, horizontal transistor) in D board. Service manual says ...
High voltage error 8 times • T8005 is faulty. (D board)
bye
Sep 07, 2008 | Sony KP-51HW40 51" Rear Projection...
Powers on then right back of light flashes 8 times
i have a sony wide screen projection tv KP-51WS500 Red stand by light on flashs no picture
Mar 10, 2008 | Sony KP-51WS500 51" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
