Question about Mpio HD-400 MP3 Player
Frozen screen/ can't turn it off
I have a MPIO HD400/ Solid and i had it connected to my buddy's computer to get a couple songs off him and afterwards when i attempted to listen to my player, the screen froze up on me and i can't turn it off. And i've been waiting for the battery to die and then start from sctratch and charge it over again and it still hasn't died and it's been like 3 days. Goin' bonker's over here!!! Help and suggestions please!!!
  • Anonymous Dec 28, 2007
    I have the same issue. I tried the Reset button but it does not do anything. The screen is on, and I can't turn it off. Nothing works, no matter what button I press.
    Help
Try the reset button which is pin-sized hole on bottom right when looking at the HD-400. You will need paper-clip to press it.
Posted on Jul 27, 2007
SOURCE:
My ipod is frozen and the buttons dont work the unlock button is frozen and the ipoda1236 EMC no. 2174 screen wont turn off
Hi lastonsarah
If you have forgotten the code or put the wrong code in your ipod, you can unlock the Ipod by doing the following:
Connect your IPod to the primary computer you use it with (the first one Ipod synced with), and open iTunes.
When you disconnect iPod from the computer, it will no longer be locked.
If you can't unlock Ipod using either (the code or connecting it to the computer you use to manage its songs). . . you can restore your ipod to factory settings using ipod Updater.
Please note that this will erase all data on your ipod.
Afterwards, you can add your music and data back to your ipod.
If you want to change the primary computer that your Ipod is associated with, do this:
1. Restore your iPod. WARNING: The restore process cannot be undone.
All of your songs and files will be deleted.
Always make a backup of your important data.
2. Connect your ipod to the computer that you want to be the primary computer.
3. Open iTunes and synchronize.
If you can't unlock your ipod and you don't have access to the primary computer, your only option is to restore the Ipod, which will erase all music and data.
Please take time to rate me
Bud
Apr 22, 2013 | Apple IPOD 8GB MODEL NO. A1236
Frozen MP3 player - MPIO HD300
Have you tried downloading the specific drivers for that MP3?
Here is the site...choose your player then download and install...reboot and see if it solves your problem.
http://www.mpio.com/downloads/index.php
Feb 29, 2008 | Mpio HD-300 MP3 Player
Tt'll try to load a song (and will then crash.
maybe the file itself is corrupt.
Have you tried with other files?
If you did and they played well all you have to do is to get the song again
Jun 22, 2009 | Creative Labs Zen Digital Media Player
Player frozen, green light on
i had my GFs mp3 player and it was flashing green light, not solid, but still was frozen and couldnt even bring it up on my computer after plugging in the USB cable. but i just tapped the reset button on top right side, and it stopped flashing and turned off. i turned it back on and started to play normally. not sure if it will be the same since the light situation is different, but the reset button worked for me. good luck
Jan 28, 2009 | Creative Labs ZEN Stone MP3 Player
Try to reformat using your USB 2.O, with The Super-Reboot MP3 Software, may take up to 24/48 Hours to Reformat
Jan 18, 2008 | Mpio HD-300 MP3 Player
Unreadable directory by recent windows XP laptop
MPIO Utility can be used with MPIO player that supports USB Mass Storage.
With this, you can..
- Format and Recover MPIO player
- Upgrade firmware of MPIO flash-type player
- Building playlist of MPIO hdd-type player
* Supported OS : Windows 98 SE, ME, 2000, and XP
* MPIO Utility doesn't work with FL200 and FY300.
* If you are using the latest firmware, be sure to use the latest version of MPIO Utility.
* Please uninstall the old version of MPIO Utility before installation.
[Download]You can redownload drivers and first uninstall the old one's.RICHARDM69
Sep 25, 2007 | Mpio FL400 MP3 Player
After knowledge more than help
Here is the link to the user manual for your player if you need it; http://www.mpio.com/downloads/manual/HD400-ENGLISH.pdf The format of video that you play on the player will not be able to be shown on a tv without converting it using a different device - easiest and cheapest would be a pc, which basically makes it pointless using the player itself. it may be in the future that tvs will come on the market that accept a direct USB connection from devices like your player, but i havent found one yet available - keep checking. Sorry if not good news, hope it helps you out - please ask again if you want any more info :)
Apr 06, 2007 | Mpio HD-400 MP3 Player
Mpio fg200
Turn off the unit and connect it to the computer.
The computer should recognize the player.
Run a program called Mpio Utility (Can be found on the CD or Mpio.com)
Select format & Config
That should do the trick.
Or go to www.mympio.com
Feb 01, 2007 | Mpio FG200 MP3 Player
Mpio HD-400 is stuck on loading screen windows doesnt recognize it
alotita, I have an MPIO HD-200. Does Windows play the sound like you have something attached when you plug it in? Or does Windows not regognize it al all? Either way, I've had to play with mine after I've dropped it a couple of times. I charge the battery all the way, then just keep plugging and unplugging from the USB wire. The last time, it took 20+ times before Windows would recognize it.
Nov 14, 2006 | Mpio HD-400 MP3 Player
My Mpio FG100 is messed up! Help! Please!
lol thats not how .... switch the hold switch on, press and hold func botton press play while holding then turn on the mpio while holding after that a screen saying"preceed to format? press rec hold for N secs til screen pops up saying that its doing a low level format
Mar 31, 2006 | Mpio FG100 MP3 Player
Mpio HD-400 MP3 Player Logo
281 people viewed this question
Top Mpio Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Mpio Audio Player and Recorder Expert? Answer questions, earn points and help others
