Question about Sewing Machines
My machine Bernina 830 does not run.
Hello:
I can not move the knob for button hole
the adjusting knob for straight stich and zig zag is stopped in (2) and go to (4) but didn t stay, because come back to (2)
the left center - rigth adjusting knob (needle position) is stopped and can not move.
Bernina 830 in the manual identified with numbers: 19, 20, 21
Thanks for your help
Rose Mary Lucas
  • msp2 Apr 15, 2009
    I have the same problem. The button-holer knob will NOT turn. All other stitches work fine. Please help! --msp
  • 202 Answers
Rose, most likely your machine is gummed up and needs oiling. A product called Tri-Flow is best. It can be purchased at most any hardware store. Or just use normal sewing machine oil. Open the top and put a fair amount of oil down behind the knobs and let it soak in. As it soaks just wiggle the knobs or turn them little by little back and forth until they free up. Don't force anything as something will break.
Good luck
Posted on Nov 29, 2008
    Scholar:
  • 41 Answers
Hi Rose Mary,
I'm assuming you are talking about the original Bernina 830 (their newest machine is also an 830!)
If you've not had your machine professionally serviced in awhile, it could be as simple as a good, thorough cleaning and adjusting. Your machine should be professionally serviced about every 1-2 years....not a bargain service that blows out the dust and puts oil on the hook, but a service that checks all the gears for wear, adjustments, hook timing, feed timing, grease for the gears (if required), removes lint build-up deep in the machine - very thorough.
There are various gears in the 830 that control these functions. It sounds as if one of the gears may be either broken or jammed. Unfortunately, unless you are trained in machine repair, this isn't something you should attempt. When gears are replaced or adjusted, generally the timing of the machine must be reset as well.
We would recommend that you take your Bernina to your nearest authorized Bernina dealer (they'll be trained on your specific machine and have easy access to any parts that may be needed).
If you do not know a dealer in your area, you can search on the Bernina website.
The original Bernina 830 was one of the greatest models Bernina has made and is well worth putting the money into keeping it running. Great machine!
Hope this helps narrow down what may be happening.
Happy stitching,
Kim & Linnette
www.sewingexpressions.com
  • Sewing Machines Master
  • 12,053 Answers
Rose:
In addition to Rick's suggestion, you can direct hot air from a hand-held hair dryer into the internal mechanisms of the sewing machine. This, combined with the oil, will help loosen up the old oil and get things moving again.
In the future, be sure to clean and oil your machine regularly. See the diagram in your manual and use a good quality sewing machine oil, not 3-in-1, WD-40, or cooking oil.
Posted on Feb 24, 2015
I cant get my stitch Width Zig zag knob to turn om my bernina record 930. Any one have this problem?
Most likely because your machine has not been serviced (oiled & cleaned) in a long time and the old oil has turned to glue and seized. This is probably the most common problem with mechanical sewing machines. A mechanical sewing machine should be regularly maintained..ie every 40 hours of sewing use or at least every six months when not in use. You may want to take it to a Bernina service technician. Ask for a bottle of Bernina oil for CB hook machines and ask if they will show you how to oil it.
Bernina 830 won zig zag won buttonhole no decorative stitch
Bernina 930 Record oiling diagram
Questions Answers for Bernina seized Sewing Machines
Aug 14, 2016 | Bernina Sewing Machines
Bernina 1130 not catching bobbin thread
there will be a adjustment in that you should select the stiching mode and in that give the straight mode the problem will be solved
Jun 05, 2008 | Sewing Machines
Kenmore ultra stitch 6 Model 13402
If the machine is not zig zagging when you select zig zag it will mean the selector finger needs adjusting which is a shop job
May 26, 2014 | Sewing Machines
Needle arm is not centered and will not center. when machine is turned on the needle arm moves completely to the left outside of the range it should be in.
You probably have your machine on a different stitch than a straight stich, such as zig zag or a button hole.
Jun 07, 2010 | PfaFF Creative 7570
I need to raise the teeth on a Bernina sewing machine and I can't remember how to do it. Any help?
On the front of your machine, is there a knob that you turn for zig-zag/straight stiching and the other way for darning? There will be an icon showing the stitches
The darning selection will lower the feed dogs.
Apr 30, 2010 | Bernina 1008
I have a Bernina 830, the older original one which is not computerized. My zig-zag does not engage.When I turn the knob selector, it turns and the needle does move back and forth. But when I sew the needle...
Take your machine in for service.
Bernina is the only brand that holds value and anything you try may damage the machine.
Take the machine to an authorized Bernina dealer for service.
Mar 27, 2010 | Sewing Machines
Singer Athena 2000 won't zig zag
Did you switch the metal plate to one of the ones that won't allow left/right movement by any chance?
If the wrong plate it in -The machine somehow figures out that the plate won't allow the needle to move in the left/right directions and only does a straight stitch or funky other stitches.
Jun 08, 2009 | Singer Sewing Machines
Bernina 930 won't zig zag
You will need to remove the top cover. 2 screws one of which is under the bobbinwinder lid. They only turn a half turn to release. After opening the top cover and if you watch what goes on inside from the top, move the top change lever you will see part of it goes through a fork or U-shape part. This part is probably stuck and needs some oil. After oiling and working it back and forth a bunch eventually it will start snapping into the notches its supposed to. I beleive then you will have your zigzag back.
Either that or you have the stitch width set on zero.
Hope I helped.
Feb 08, 2009 | Bernina Artista 180
Zig Zag Not working on my Bernina 830.
Basically it is a matter of a stuck part. Flip open the top by prying up on the front or ends of the lid. You already noticed the hinges on the back. When you get it open, exercise the right hand lever on top (marked ZZ at bottom and 1-20 at top. If you look just to the right of this lever against the back wall you will see that it moves a little part back and forth into triangle shaped grooves. The part is not going completely into the grooves so drop some oil in there and exercise it a few more times, using your fingers if necessary to make the part move into the triangle grooves at the front and back. After a while it will loosen up where it should operate by itself smoothly . Hope this helps.
Dec 12, 2008 | Bernina Artista 180
Sewing Machines Logo
805 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
