Question about RCA 35V432T 35" TV
Colors are distorted, brightness excessive
I purchased a floor model RCA less than a year ago and the colors have deteriorated to the point where no adjustment makes the image right. The brightness consistently makes all the white in the image bleed and dominates the image, and the other colors are also warped (or just generally dark). I have been trying to understand the problem so any possible remedies and guidance would be appreciated. Schematics and\or a service manual would also be useful...even a website for understanding the way a TV works would be great! Thank you in advance for any and all help.
  • Sid Sanchez Feb 05, 2007
    THANK U STARGAZER...some basic questions...What is the "screen control" and how does it open up? How do I fix\replace it?
    As far as the fly back transformer, I think that could be the problem as the screen (brightness) control used to make the difference in the first couple of months and later no longer adjusted properly-although the focus still adjusts the image.
    Novelist:
    Champion:
  • 236 Answers
You may have a bad Fly Back transformer. The focus and screen(brightness) controls are located on this transformer. Some of the new RCA's have had problems with this transformer. If the screen control opens up the picture may either go dark or light which would cause your problem. Also a bad Picture tube could cause this. It shouldn't since the tv is not very old though. I've seen a few new ones go bad. Stargazer
Posted on Feb 04, 2007
  • Simpson Neal Feb 17, 2007
    Hello, again
    The screen control is located on the flyback transformer. It is an integral part of the flyback. You'd need to replace the whole flyback assembly.
    The screen control will open up if the wiper contact starts arcing or if moisture seeps inside. The wiper just slides along a film of resistive material (usually carbon) and since there is a pretty high voltage involved, it can start arcing and burn out.
    Also on the picture tube drive board there is a small high voltage disc capacitor which may become leaky or shorted which in turn will burn out this control.
    Both the focus and screen controls are made together forming an adjustable voltage divider.
    Depending on which part opens up determines which circuit is affected.
    I hope this helps explain its operation and location.
    Stargazer
How do i get my tablet to fully charge its less than a year old
Even though your tablet is less than a year old, the battery may have deteriorated to a point where it cannot recharge completely. You may have to make a battery replacement.
Sep 11, 2014 | Tablets & eReaders
I have a hitachi 54' projection tv model num.57SWX20B i purchased about 8 years ago brand new. when turned on operayes fine for about 5 mins. then i lose my picture to multicolored lines after a couple...
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 20, 2011 | Hitachi 53UDX10B 53" Rear Projection...
I keep having to adjust the convergence for blue. Flash focus doesn't do much so I have to laboriously go through and adjust all the crosses for the blue - it usually sinks low and to the right. My...
  • Screen looks 3D
Here are some images of convergence problems.
Or goto the site www.TvRepairKits.com for the parts and instructions on how to fix it yourself.
Feb 05, 2011 | Sony KP-57WV600 57" Rear Projection...
How do you align the colors?
Press MENU button and ON-SCREEN MENU will appear. Press
POINT LEFT/RIGHT buttons to move a red frame pointer to
IMAGE ADJUST Menu icon.
Press POINT DOWN button to move a red frame pointer to the
item that you want to adjust. and then press SELECT button.
The level of each item is displayed. Adjust each level by
pressing POINT LEFT/RIGHT button(s).
Move a red frame pointer to
the item to be selected and
IMAGE ADJUST MENU
IMAGE LEVEL ADJUSTMENT
Press POINT LEFT button to decrease contrast, and POINT RIGHT
button to increase contrast. (From 0 to 63.)
Press POINT LEFT button to adjust image darker, and POINT
RIGHT button to adjust brighter. (From 0 to 63.)
Contrast
Brightness
Press either POINT LEFT button or POINT RIGHT button to obtain
better balance of contrast. (From 0 to 15.)
Gamma
To store manually preset image, move a red frame pointer to
Store icon and press SELECT button. Image Level Menu will
appear. Move a red frame pointer to the Image 1 to 4 where you
want to set and then press SELECT button.
Image Level Menu
Move a red frame pointer to any
of Image 1 to 4 where you want
button.
Store icon
Press SELECT button at this icon to
store the adjustment.
IMAGE ADJUST
Menu icon
Press POINT LEFT button to lighten red tone and POINT RIGHT
button to deeper tone. (From 0 to 63.)
White balance (Red)
Press POINT LEFT button to lighten green tone and POINT RIGHT
White balance (Green)
Press POINT LEFT button to lighten blue tone and POINT RIGHT
White
Jan 22, 2011 | Sanyo PLC XU35 Multimedia Projector
We have a RCA D52W23 rear projection TV. Now the color looks like it is in 3D. A friend has the same problem a few years ago and bought a part on line and fixed it themselves. What is the part and where...
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 19, 2011 | RCA D52W19 52" Rear Projection Television
The projector is approximately 4 years old & on average runs for about 60 hours per week, 40 weeks of the year. After fitting a new lamp last October & resetting the projector, the image is still...
Additional information is required for us to assist. Can you better describe what you mean by "poor image"? Are the colors separated? Is the picture out of focus? Are the colors wrong?
Please describe the picture or post a picture of the screen if you can.
Thanks,
Dan
Feb 03, 2010 | Sanyo PLC-XP57 LCD Projector
My 52 inch RCA projection TV has the picture wide on top and small at the bottom..what can cause this and how can it be fixed??
This sounds like a problem with "convergence" of the TV. The convergence circuitry performs the electronic aiming of the Red, Blue & Green projectors. Typical convergence problems result in distorted images on the screen such as: double or triple images on part or all of the screen, wavy lines, curled edges, excessive red, green or blue color or tint, etc. Sometimes, convergence issues can be corrected in a menu setting of the TV that has to do with "Picture Settings" or "Advanced Settings".
If the colors are out of alignment a great deal or went out "all of a sudden" it will probably not be repairable via the menu adjustment described above - but is certainly worth trying.
If it does not straighten out with the menu adjustment, it will probably require replacement of the convergence integrated circuit(s) chips located in the TV. This was a "big ticket" repair years ago, but can be done sometimes for as little as $40 in parts. Don't let the low price fool you though.. It can easily take several hours (or more) to access, remove & replace the components and reassemble the TV. Soldering skills are a must - and I'm not talking about soldering plumbing pipes here either. These are delicate electronic parts and need a 15 - 30 watt soldering iron and de-soldering braid or "solder ******" and LOTS of patience to perform CORRECTLY. As such, it is "not a DIY project" unless you're willing to risk turning your TV into a large floor model paper weight. If you decide to attempt this repair, you should google your TV brand and model along with the term "convergence". Parts, costs and procedures vary by TV. Unplug the TV for a day or so before starting the work to let capacitors discharge fully - just to be safe. Lastly, if you're going to attempt the repair - don't forget to purchase silicone heat sink compound - it is an absolute *must*!
Sep 24, 2009 | RCA Televison & Video
TV problem 46GW948 GE 48? Thomson Guide Plus GemStar
i hope this helps. on the tv, press menu, then channel up or down to "screen", then menu;
then channel up or down for adjust projection tv(6), then press menu;
then use the volume up and down, as well as the channel up and down until each of the 3 colors are lined up. press menu after each color i slined up to go to the next color.
hope this helps.
May 29, 2008 | Televison & Video
Faces too pink in my ip6700D
Solution: Manually adjust color from the driver (Windows)
Manual Color Adjustment Follow the steps below to make fine adjustments to the color hue for the printed output. These settings will only make minor color adjustments. If more drastic color adjustment is necessary, use an image editing application.
  1. On the Windows desktop, click 'Start', point to 'Settings', then click 'Printers' (Windows XP: On the Start menu, click 'Printers and Faxes', Windows Vista Click / Select Start from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'.).
    Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
  2. Windows 2000/XP/Vista: Right-click the printer icon, then click 'Printing Preferences'. Windows 98/Me: Right-click the printer icon, then click 'Properties'.
  3. On the Main tab, select 'Manual' for 'Color Adjustment.'
  4. On the Manual Color Adjustment screen, adjust each color individually to achieve the desired effect.
    Note: This screen may vary depending on model.
Dec 24, 2007 | Canon Pixma iP6000D InkJet Photo Printer
Color printing
Nov 16, 2007 | Canon Pixma iP6000D InkJet Photo Printer
RCA 35V432T 35" TV Logo
119 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
