Question about Frigidaire FTF530FS Front Load Washer
Drum won't spin and water won't drain
I have a Frigidaire front loading machine that is about 7 years old. The dial will run through the cycle, but the drum won't spin and the water won't drain. I hate to get a repairman until I kind of know if this is a major problem..thanks for your help!
  • gorjusborg Mar 05, 2009
    I had the exact same problem, the washer would run through the whole cycle, but the clothes were sopping wet.
    Running the washer through a cycle while I watched revealed a buzzing sound I'd never heard before. It sounded as if a motor was under strain, but the cycle was progressing as usual.
    When it came time for high speed spin cycle, the washer wouldn't spin at full speed.
    I took off the front panel of my FTF530FS (FTF530FS1) washer. The drain pump was in the front right corner. After unscrewing the hose clamp for the widest diameter boot, I found a breast pad, a dime and ball of hair that were clogging the drain pump on the intake side. After removal of the clog, the machine ran normally.
    Sergeant:
    Champion:
  • 311 Answers
No spin unless drains. Check pump and hose leading to it for blockage; if none then replace it. I cannot see your reply due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Posted on Nov 29, 2008
My Frigidaire front load washer model no. GLTF2940E, is about 5 years old. It has always worked fine. Last week the spin cycle left some cloths wet and now when I start it, it only allow about 5 seconds...
Sounds like you have faulty water inlet valves. They may not be opening fully. You can test the power to the valves with a voltmeter to see if the power is quitting or if the valves are malfunctioning
Mar 12, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidaire GLTF2940FS...does not do a final spin/clothes wet
If water remains in the drum the unit will not go into the final spin.There may be a couple of reasons for your problem.
1.) A coin or other foreign object is blocking the drain hose. Check the drain hose for foreign objects impeding the exit of the water.
2.) The Drain hose is not raised above the machine outlet to create a siphon effect. See your manual for proper hose positioning.
3.) The pump is a third possibility which you should hear the impeller spinning during the drain cycle. There is a coin catch after the diaphragm of the pump that looks like a rubber boot that should be inspected for objects if you remove the pump. I believe the pump is about $60.00 and is accessible after removing the front panel under the door.
Sep 10, 2009 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire front loader washing machine won't spin...
The problem is a faulty Door Latch Assembly. The same thing happened to my Frigidaire front load washer. The part is easy to install, costs about 60 dollars and can be picked up at most appliance repair stores . To access the switch just remove the wire around the front drum gasket, peel back the rubber gasket beside the switch assembly then remove the two screws holding it in place. remove the three wire connector blocks and swap in the new switch. My washer was giving me error code 41 witch is a faulty control board. But the problem was in fact only the switch...
Sep 02, 2008 | Frigidaire GLTF2940ES Front Load Washer
just had my frigidaire fronter loader repaired,,try the door switch ...mines wouldnt spin clothes were soaked did everything else fine... what may have happen is when the spin cycle is ready to do its part it double checks to see if door is locked but with a bad switch it sends the wrong signal and computer this the door is open so it shuts off....well gl mines is running got lots of laundry to do,.,,,hope this helps
May 29, 2008 | Frigidaire GLTF2940ES Front Load Washer
Drum won't spin.
ck fuse on board with ohm meter in board ..cks open change motor bd..also possible door lock or door strike
Apr 30, 2008 | Frigidaire ATF6000ES Front Load Washer
Drum makes loud noise when spinning
HI thanks for the question. Frigidaire has a life time warranty. on that part .call them. thanks the appliance doc. please rate my answer. thanks.
Apr 29, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Gallery Front Loader doesn't spin
The CCU board is likely at fault see one of my discussions on this here
these boards have intermittent failures that will drive you wacky.
http://www.fixya.com/support/t364216-whirlpool_duet_ht_ghw9400pl0
Jan 23, 2008 | Frigidaire ATF6000ES Front Load Washer
No spin
Your problem is that the carbon brushes on the motor have worn out and need replacing.. eaisly done
Dec 10, 2007 | Zanussi FJS1225W Front Load Washer
Frigidaire front load washer problems
My problem is that water is still draining when it goes to final spin. final spin is not working properly. then machine shuts itself off before timer.
Nov 16, 2007 | Frigidaire GLTR1670A Front Load Washer
Frigidaire FTF530FS Front Load Washer Logo
270 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
