Question about Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
Bosch dishwasher constantly beeping, wont start
Our Bosch dishwasher is 3 years old and has worked fine.  It is stainless steel inside and out.  Someone sprayed Shout laundry cleaner in it, thinking it was a disinfectant to clean it.  After that, the whole inside of the dishwasher and everything inside it was covered in hard white film that wont come off.  We washed everything 5 times.  NOw, the dishwasher wont even start.  When you press start it just beeps nonstop and nothing happens.  Help!  Thanks
  • rjvrjv Mar 02, 2009
    any answers? I have the same problem.
  • 5 Answers
SOURCE: dishwasher
Go to www.dishwasherfilter.com and have sparkling clean dishes with no film or spots, every time!!!
Make sure you use promo code DF5150 to get an additional discount!
Posted on Apr 02, 2008
  • 93 Answers
SOURCE: Have very strong film build up on Bosch diswasher
two things that works well may sound funny but it works get yourself a packade of thang orange juice crystal dump it in the dishwasher let it run a cycle it will cleane the film of the interior anothe thing that works verry well is clr it is a mild acid you will find it at your homedeot or any hardware store trust me it works i have been using is for 30 years i am in the comercial dishwasher busness i see this every day thanks from gilles
Posted on Mar 15, 2009
SOURCE: Rust spots on Bosch door panel (1 year old)
I have same problem, low grade stainless will rust, could be the problem
Posted on Mar 29, 2009
odiebugs
  • 949 Answers
SOURCE: bad odor when open door after cycle
This is just a suggestion, run a cycle and after a few mins of it washing, open the door and add a cup of bleach and let the washer run. See if this helps.
Posted on Apr 09, 2009
rylee_smith
  • 8619 Answers
SOURCE: My Bosch dishwasher SHU3306UC/12 isn't cleaning
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Posted on Aug 14, 2009
My bosch dishwasher beeps everytime we close the door.
Better switch of till you are ready with full load. Otherwise you have to trace the beeper and disconnect it.
Apr 12, 2010 | Bosch 24 in. SHY66C05 Stainless Steel...
Rust spots on Bosch STAINLESS dishwasher
Debruce Polish is the answer. It is non-toxic and odorless, DeBruce will remove the rust and pacify the finish. DeBruce is perfect for touch ups and great on ceramic cook tops and more. We buy DeBruce polish at debrucepolish.com.
Jul 28, 2009 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch dishwasher growling and not draining
Bosh dishwashers work off a gravity pump system. They sometimes require a stronger pump. Make sure if it has a air gap either at the top of the sink or johnston T or in the wall that, that is not plugged. They are very sensitive to how the drainelines are set as well. If it was installed prfessionally, call the installer back out as they should warranty there install for 1 year. Also all products have a 1 year MF warranty as well. You should be able to get a BOSH tech out at NO charge to see if it is a deffective pump.
May 04, 2009 | Bosch Evolution 300 SHE43M05UC Stainless...
Feb 25, 2009 | Bosch 24 in. SHY56A05 Stainless Steel...
Soap dispencer won' t dispence soap
My Bosch intergreted dishwasher is only 3 years old. For the past year, the dishwasher dispenser refuses to open on the second cycle. We have had the repair man here 3 times, and each time he says it's fixed,but it clearly is not. Does anyone know what to do about this??
Barbara Berger
Sep 30, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Streaks on stainless steel tub of both kitchen aid dishwashers
Hi, Emilychee1
Do you have city water or well water?
How old is you home and the plumbing?
How long do you have the stainless dishwasher and sink?
Ill wait for you reply!!
ngafm
Sep 11, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Logo
67 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
