Question about Janome Memory Craft 9000 Computerized Sewing Machine
Janome 9000 Needle Keeps Breaking!
I'm trying to embroider a towel. Using the P foot, but have broken 3 needles in a row! The foot is on tight, and so it the needle - and inserted correctly. I am new at using this machine, but everything's so automated - feed dog position, tension, etc - I can't imagine what might be wrong. Tried switching needle sizes up to a #90 - broke right off at the top (bent, too). They almost get stuck down in the feed dog area when this happens. Have I threaded it wrongly? Help!
  • julia_willia Nov 30, 2008
    I do have medium weight stabilizer underneath, but the woman I bought the machine from (as well as the place where she purchased it locally) both recommend a water-soluble on top. I am doing that.
    Could it be the way I've hooped it? Not tight enough? It appeared taught enough to me....??
    Problem Solver:
  • 19 Answers
Hi there check the race for needle piercing mark if it is pierced you will need a new race this piercing although tiny will cause this problem
always use janomes blue tip needle avalon on top backing paper below.
i am sure youre problem is a damaged race
good luck mary h
Posted on Dec 23, 2008
I think you may have to use some sort of tear away paper on top of the loops so the needle doesn't get caught, as well as stabiliser underneath. I just checked the manual for my janome and that's what it says for towelling.
Posted on Nov 29, 2008
Needle breaking while embroidering
Could be tension is too tight. But there are also several other possibilities, ie something is not in alignment, so the needle is hitting the presser foot, needle plate, the needle is deflecting off the fabric. You might also try a different needle brand or type (ie, embroidery, top stitch, etc.)
Nov 13, 2016 | Sewing Machines
Needles keep breaking when embroidering.
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
Oct 17, 2013 | PfaFF Quilt & Craft Pro 7530
Have a Janome 1600P-Top thread keeps breaking
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Apr 21, 2013 | Sewing Machines
I have a Futura XL-400 and when I am embroidering it keeps breaking the thread at the needle area. I hear a noise which sounds like its coming from the bobbin arean then the thread breaks and its also
try these suggestions
change the needle
check the needle plate for burrs
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Apr 11, 2013 | Singer Futura Xl-400 All-In-One Sewing And...
Juki DDL 227 top needle keeps breaking
Needle breaks
The needle thread breaks
Oct 08, 2012 | Juki Sewing Machines
Janome mylock 204d needle keeps breaking when sewing a rolled hem on sequined fabric
May 16, 2012 | Janome Sewing Machines
When I start to try to embroider the red light just blinks and I can not send tothe machine
you might try youtube for video's on embroidery
Feb 02, 2012 | Sewing Machines
New Home My Lock 134D Serger. The right needles keeps breaking. Yesterday I realize it is hitting the pressure foot. I have changed out the needle (size 14) about 7 or 8 times now. I have adjusted the...
check to see if the presser foot is loose
check to see if the needle is in backwards
if the presser foot is tight & needle is not in backwards then it could be a timming problem, since you said the needle is hitting the presser foot
please rate this with the thumbs in upper right hand corner
Aug 08, 2010 | Janome MyLock 634D Mechanical Sewing...
Breaking Needle Thread Janone Memory
Several possibilities
1. The needle thread is not threaded properly.
2. The needle thread tension is too tight.
3. The needle is bent or blunt.
4. The needle is incorrectly inserted.
5. The fabric is not being drawn to the back when sewing is finished.
6. The thread is either too heavy or too fine for the needle.
7. Old perished thread. Use quality thread for best results.
8. Needleplate burred near hole, from needlestrikes 9. Hook is burred (Feel the tip of the hook under bobbincase with your finger....polish with 1600 emery paper carefully)
Aug 30, 2009 | Janome Memory Craft 9000 Computerized...
Top thread breaking during sewing.
your needle needs to be replaced and make sure it is in correctly..if this does not work you will need to make sure your thread is not old. then adjust you bobbin tension...there are 2 tensions on machine top and bobbin
May 22, 2009 | Janome Memory Craft 9000 Computerized...
Janome Memory Craft 9000 Computerized Sewing Machine Logo
124 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
