Question about Sharp R-1460 Microwave Oven
The vent fan stopped working on my over the range Sharp R-1460-A
I need to know where the fan is located and what the problem could be. I push the fan button and the fan will not come on. I do not have the owners manual to locate where the motor is in the microwave. Please help...
  • William Miller
    William Miller May 11, 2010
    The vent fan is located behind the grille.
    Have you recently had trouble with the cooktop lights?
    You can download GE
    owner's manuals
    here.
    Please reply back with
    your brand and full model number from the tag so we can help you
    properly.
tiway1
  • 100 Answers
SOURCE: replace glass turntable for Sharp microwave
You can order it from...
www.microwaveglasstrays.com
This link will take you directly to the tray you need - Sharp part # NTNT-A084WRE0
Posted on Jul 06, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Limited space for over the range microwave
You can call Sharp and ask them what current models if any will be drop-in replacements,either using the same mounting hardware or at least the same space.
You can contact Sharp at 1-800-BE-SHARP (1-800-237-4277) or visit them online.
Posted on Oct 19, 2008
MicrowaveSvc
  • 9098 Answers
I replied to your other post on this, but I'll just paste the solution here and get myself 2 FixYa ratings! *grin*
Posted on Oct 20, 2008
jyackle5
  • 8197 Answers
SOURCE: Sharp Microwave R-1480 ~ Removing
You need to remove the grill above the door to find two more screws that go straight to the back wall plate. They will be on the left and right side. There are chrome or a gold color. That is the only other way that they mount to the wall.
Good Luck
Posted on Dec 18, 2008
  • 52 Answers
SOURCE: Microwave doesn't work
the outer casing has to be removed, inside you will find a large fuse 10A> this protects the transformers and magnetrons, also you will find some smaller control circuit fuses, they are normally mounted on the circuit board at the rear of the control panel.
Posted on Feb 23, 2009
I have a 1995 Sharp Carousel R-1440. Our power went out then when it came on our microwave it no longer working properly. the clock works but when the door is closed the cooling fan starts running- it...
Yes your oven's controller is probably malfunctioning you need to replace the SYSTEM BOARD but I personally suggest to buy an other oven.... the system board will be hard to find and expensive...
See if other electronics is acting funny since the power loss... you could CLAIM the damage from the insurance company
Good luck!!
Feb 28, 2011 | Sharp R-1460 Microwave Oven
Model R-1460, when I shut the door it runs but doesn't heat up. What needs to be done to fix it?
Do you mean that when you close the door, the fan comes on? If so, it sounds like a bad door switch. Probably the secondary interlock switch.
This failure is caused by opening the door when the unit is in cook mode. On ALL microwaves, not just one or two brands.......
Be sure to push the stop button before opening the door to add or stir... Or wait for the cook cycle to end. (This is why microwaves have a two step function on the stop/clear button. Hit stop once to stop cook mode and twice to reset timer).
You should use an ohm meter to check all 3 switches. The switch can be either stuck 'closed' or physically closed but not 'making' electrically.
Sep 13, 2009 | Sharp Microwave Ovens
My sharp R1650 has no power including light and vent
Thjere is a large Ceramic fuse on top of the chassis The outer cover has to be removed to access it The cost of replacement is about $20-30. But it would be better to know WHY this blew. replacing it may cause it to fail again immediately if there is a short circuit somewhere in the unit
Aug 15, 2009 | Sharp R-1460 Microwave Oven
Oct 19, 2008 | Sharp R-1460 Microwave Oven
Oct 19, 2008 | Microwave Ovens
R-1460
Check fuse. Remove 3 screws from the plastic grill located at along the top front of the unit. Remove the phillips head screw above the control panel. Slide up and pull out to partially remove control panel. You will see a white fuse. Replacement is CD3G 125v 20amp or BUSS ABC 20 or Little Fuse 314020 at 250v 20a. Radio shack caries the ABC.
May 12, 2008 | Sharp R-1460 Microwave Oven
Microwave Ovens Logo
24 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
