Question about Microsoft Windows XP Professional for PC
Hello i have this AIOSOFTWARE NPI on my screen and it wont leave i tried everything , can you help me get this off. is this some kind of viruse or what is it??
  • kavarthapu Nov 30, 2008
    every time i switch on the pc the aio software error messare can be appear pls help me
    Problem Solver:
  • 3 Answers
Try this website: http://answers.yahoo.com/question/index?qid=20061014221204AAu37n5
Posted on Nov 29, 2008
Hello when I try to turn on the phone it some times has 2 different screens but not the home screen it has a plain black screen ans then it has a colorful dot screen I don't know whats wrong
May be because of viruse or downloaded app.Try factory reset if not successfull than try hard reset your phone.For hard reset kindly mention your phone model.
Jul 22, 2015 | ZTE Cell Phones
Re-Program ?
restart you computer. repeatedly press f8.
go to safe mode.
have a system restore.
Jan 27, 2008 | New Product Innovations NPI NPI NUWAVE...
My LG phone screen will not react to touch
When a phone screen is blank or has a white screen, etc, there are three things that could be the cause;
1. Bad/defective screen and the solution is screen replacement. (In your case, your screen might be failing).
2. Software/Virus problem and solution is to flash the phone
3. Flex problem and solution is to change the flex. In some cases the flex might have shifted or not in it's right position, in this case, just fix the flex back properly and all will be well.
Bad/defective screen:
If your phone is having a white screen, first thing to do is dismantle the phone carefully, check if the screen is properly fixed to the phone board, also check if screen flex is intact. Once you've confirmed that all these are okay and screen is not still coming up, then it means your screen is bad. You can go ahead and replace the screen.
Make sure you confirm the screen is bad before you do any replacement.
Software/Virus:
Sometimes software/virus problem on phones are mistaken to screen problem. When a screen is white or blank, sometimes it's a virus problem. To further confirm, turn on the phone, wait for about 2 minutes when you know the phone must have booted fully, then use another phone to call the phone with white or blank screen. If the phone rings, it means it's not a virus problem, but if it doesn't ring, it means it's a software/virus problem.
If you discover your phone has a virus problem, you will have to flash the phone for it to display again,
Flex problem
When your phone screen is blank, white, has horizontal/vertical lines, turn images up-side-down, etc, be calm, there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out, that's why your screen is acting like any of the mentioned problem.
This is usually common with flip and slide phones. The flex worn out as a result of constant opening and close of the flip or slide phone. Samsung and Motorola phones mostly have this kind of problems.
Replacing the flex is the only solution to this problem. If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be replaced.
Conclusion
Disassemble your phone and check the screen part in order to verify from the above which is actually the cause of the problem.
Please let me know if you need anymore assistance.
Good luck.
Jan 12, 2012 | LG GT540 Cell Phone
My nokia 5230 wont start up it only show up to the nokia logo
hello,i guess that could be caused due to a bad battery or probably a factory default if the phone is still kind of new.kindly change the battery to try and power it on to see if the problem still persist.or you kindly visit the store of purchase to see if it's not a virus attack,an internet flash will be required if it's a virus attack and an anti-virus will be necessarily needed to be installed on it.
please kindly rate the solution if it's helpful,
take care.
May 28, 2010 | Nokia 5230 Cell Phone
What can i do , if my behold samsung screen got freez, everything else just working fine, like camora. But not the screen its wont respond. PLease Help?
hello,all you need do is just to visit an expert repairer to check if the outside screen or the inner screen is faulty.if any of them is faulty you will have to fix them up so as not to witness the freezing mode again.
kindly rate this solution if it's helpful,
take care.
Apr 16, 2010 | Samsung Behold Cell Phone
Menu screen won't go away.
Try to hard reset the tv..Leave it unplugged for 4-6 hours and then plug it again and use..If this did not help Try to contact a service centre or service person because this is probably a hardware problem which definetly needs service and replacement!!...Thank you..
Hope this helps you....
Kind Regards!!
DON'T FORGET TO RATE;
Jul 21, 2008 | Philips 50PF7320A 50 in. Plasma HDTV
My sony ericsson p990i phone has it's virus on the internal memory
my sonyericsson P990i just stoped opening messages.each time i try to access my inbox it says application closed,reason code;E32USER-CBase,reason no;21
Mar 30, 2008 | Sony Ericsson P990i Cellular Phone
New keys, autoroll
properties, setting, rollback driver
Sep 09, 2007 | New Product Innovations NPI NPI NUWAVE...
Microsoft Windows XP Professional for PC Logo
118 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
