Question about Canon Office Equipment & Supplies
Aargh! I have a Canon Pixma iP6700D printer that has been wonderful (Win XP). I've printed several photos w/ no problem. Today, it grabbed two 4x6 gloosy sheets from the automatic feeder and delivered them w/ wet ink both on top and on the underside. Now, on the scenic photos, there is no green--it's printed as lavender/purple/black. Yellow flowers are printed in a light magenta. I've run several maintenance functions, including nozzle and roller cleaning. No success. However, when I print the vivid color in a Disney pix, the colors are fine. Tanks are full Have tried both glossy 4x6 and plain paper. Same results. What's wrong?! Thanks, Judy
Buffalo12980
  • 625 Answers
SOURCE: pixma iP4000 problem
the printhead is shot. I've replaced my printhead twice on my pixma ip6000D in just over two years.
Posted on Aug 21, 2007
jimmynuetron
  • 24 Answers
SOURCE: Missing Colors
This is a simple problem just reset your printer's color management settings!!!!!!!!!!!!!!!!!!!! :-)
Posted on Oct 24, 2007
  • 52 Answers
SOURCE: Horrible print quality
hi i am a certified Canon repair tech for this printer. the first problem is the paper you are using hp photo paper is specialty formulated to be used with there inks. every manufacture is the same if you want the proper looking photo and you are using a Canon printer you need to use Canon photo paper because the paper is formulated for their inks. hope this helps to clarify.
Posted on Jan 05, 2008
SOURCE: Printer will not use the magenta color
I had the same problem. It is most likely that your print head nozzles are clogged. Your choices are to attempt to manually clean them, or order a new print head from Canon.
Attempt the manual cleaning at your own risk, this doesn't always work. When it does not work, it means your print head is damaged.
To maually clean the print head. Printer cover up (so you can get to the cartridges and print head). Turn the Printer Off. Remove all the cartridges (I put each cartridge in a separate zip lock bag). Then flip up the lever and remove the print head.
Now heat (don't boil) distilled water (Iused a good sized cook pan and a plastic measuring cup to pour the water). Find a container you can soak the print head in (I used a deep alluminum baking pan). Pour the hot (not boiling) distilled water over the print head molding where the cartridges seat down (hold the printhead over your diposable alluminum pan). Then dunk the molded print head part into the pan numerous times. When the water gets dark change it (be carefuill not to stain the sink). Then slowly pour the hot distilled over the print head (opposite side from where the cartidges seat in). Eventually no ink will be in the water. Set the print head on a dry paper towel, and let it dry for 24 hours or longer. Reinstall the print head, then the catridges. If it worked, your true colors will return. It make take up to 15-20 photos to get all the ink catridges flowing-be patient. You can also just wait 24 hours after re-installing the cartridges, and hopefully it will take less photos to see the correct color match.
Never keep printing when a cartridge is low or out.
Print a few prints every week. Not printing for weeks causes the printheead and the ink flow to clog!
Good luck. I just recovered my S820 and my i900D using the above cleaning method. Like everything else, your mileage may vary! It cost me $1.29 for distilled water and about an hours worth of time!
Posted on Oct 20, 2008
rhoncruz
  • 134 Answers
SOURCE: Poor photo copy when printing 4x6 glossy in cassette tray.
Set the Ink Intensity (Windows) The Intensity setting controls the amount of ink placed on the paper. The higher the intensity the darker (more ink) the printed image will be. If the Intensity setting is set too high, the printed page may become too wet and curl or streak. Follow the instructions below to adjust the ink intensity settings.
  1. Access the printing preferences by opening the printer Preferences / Properties.
    For Windows Vista
    • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
    • Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears.
    For Windows XP Home Edition
    • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.'
    For Windows XP Professional Edition
    • Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.'
    For Windows 2000/Me/98
    • Click / Select 'Start' from the bottom left of the Windows screen, and 'Settings,' then 'Printers.'
  2. On the Main tab, select 'Manual' for 'Color Adjustment', and then click 'Set'.
3.Use the slider bar to adjust the 'Intensity'.
Note: Move the slider bar right to darken the image, and move the slider bar left to lighten the image.
Click 'OK' to complete the setup.
I hope it helps!!!
Posted on Dec 02, 2008
Paper jam, Canon iP6700D
your printer have to be opened so please take it for servicing
Nov 06, 2009 | Canon PIXMA iP6700D InkJet Photo Printer
How do I reset the left margn on my canon ip6700D printer
Margins are set in printing preferences in the window that pops up after you press print. If prints like the nozzle check are off center you need to clean the encoder strip.
Nov 04, 2009 | Canon PIXMA iP6700D InkJet Photo Printer
My IP6700D prints some color but with a green cast
Someone forgot to peel the tape off the PM cartridge, must have been me.Thanks
Jan 04, 2009 | Canon PIXMA iP6700D InkJet Photo Printer
Prints incorrect colors
Try another head-cleaning cycle -- it worked, last time, correct????
Dec 09, 2008 | Canon PIXMA iP6700D InkJet Photo Printer
Partial photos
I have a Canon IP6700D that I was having the same problem with. I adjusted my virtual memory (increasing it) and changed from spooling to printing directly to the printer in the control panel. It seems to have corrected the problem. Hope this helps you.
Jul 16, 2008 | Canon PIXMA iP6700D InkJet Photo Printer
Crooked pictures
i think you set the printer incorrectly. go to the properties and change to highest resolution. or maybe your printer head is dirty. clean the nozzle.
Mar 05, 2008 | Canon PIXMA iP6700D InkJet Photo Printer
CANON IP6700D PRINTING
i have a ip6700d.the problem is that im trying to scan but it cant connect to the machine. what's the problem?
Feb 19, 2008 | Canon PIXMA iP6700D InkJet Photo Printer
Jan 04, 2008 | Canon PIXMA iP6700D InkJet Photo Printer
47 people viewed this question
old marine
old marine
