Question about Oster 6330 4-Slice Toaster
The digital control panel is on the fritz,
No toasting option buttons are functional. Can this be fixed inexpensively?
    Problem Solver:
  • 3 Answers
We ran into the same problem today with our toaster. There was never a problem before I cleaned it--not only by sliding out the crumb drawer, but by turning it upside down to dislodge every last crumb. After that, It would not stay down when pushed down--and none of the buttons were functional.
My husband took the cover off and found that a magnet is what keeps the lever down when the toaster's on, and allows it to go back up when the toasting is done. It's an electro magnet that works only when the toaster is on. It seems that when I turned the unit upside down and rightside up again, crumbs landed on the magnet's contact plates (which are about 1/4" x 1/2") and would not allow the magnet to engage. Because the magnet wouldn't engage, the lever would not stay down, and the toaster shut off. Brush off the magnets, replace the cover and toast away!
Posted on Jan 09, 2009
What is an ICP - RCC - Speedometer fuse for on a 1997 ford taurus dohc ICP - RCC?
Hey Brian ,
ICP - Integrated control panel
RCC - Remote Climate Control Module
Integrated Control Panel-Electronic Automatic Temperature Control
Control Assembly The Taurus, Sable vehicles group together the following systems into a single integrated control panel:
  • AM/FM stereo radio
  • clock
  • rear window defroster switch
  • electronic automatic temperature control (EATC)
  • full-logic cassette tape player
  • compact disc player control (optional)
The remote climate control module is mounted to the A/C evaporator housing behind the integrated control panel. The integrated control panel is connected to the remote climate control module with a dedicated two-wire communication link. The integrated control panel EATC features:
  • a vacuum fluorescent display (VFD) for displaying set temperature, ambient temperature, function and diagnostic trouble codes (DTCs).
  • electro-luminescent backlighting for all buttons and graphics.
  • function override buttons.
  • temperature control and blower speed rocker switches.
Jun 08, 2015 | 1997 Ford Taurus
The cursor (arrow) sometimes just disappears and to get it back I have to restart the laptop. Is there a function button that would fix it??
What is running when it disappears and windows has options for the cursor in control panel > cursor /or win XP control panel > mouse
Oct 29, 2012 | MSI M670 Notebook
I play Call Of Duty Black Ops and You usually need to sprint by pushing in the Left Analog stick and your direction. For some reason my controller is pressing multiple buttons when I push the analog stick...
You have a couple of options here. Sounds like your controller may be on the fritz, so if you have the money, I would suggest purchasing a new controller.
Otherwise, in the game options, you can re-map any function to another button on your controller. I would recommend remapping the sprint button to some other button that you don't use for that game.
Dec 10, 2010 | Sony Playstation 3 (PS3) Console
LG TV keeps flashing This function is not available now.
unplug the TV. hold down the power button for 30 seconds. plug the TV in.
this worked for me :)
Apr 06, 2010 | LG 42LC2D 42 in. LCD HDTV
Fujifilm FinePix S1000FD shutter button won't focus
There is an option in the menu to put camera on continuous auto focus. You must have the camera on manual setting to have this option available, but once selected, it should stay on in auto setting. It will wear the battery faster, but it should solve the issue you are having. Hope this helps!!!
Aug 03, 2009 | Fuji FinePix F30 Digital Camera
Whirlpool electric double oven #RBD305PDQ14 control panel blank
I suspect a poor connection at the wiring to the EOC is the cause of the failures.
Apr 21, 2017 | Whirlpool RBD305PD Electric Double Oven
Switches off after 1h, Check program to display internal temp?
go to control panel and check your laptop's power options present inside the icon POWER OPTIONS..change the options according to your suitability..
May 22, 2009 | HP Pavilion dv4000 Notebook
I have a Dell INSPIRON 5100 I can't find out how to adjust the brightness on my sceen I' ve looked everywhere tring to fix this Prob. Can U help Thanks
If you look at the function buttons for example f1- f12.
there should be symbols in a light color. at the same time there will b a function key on your keyboard usually has the letters (fn) you hold this button down while pressing those other function buttons they all do something different so look for one that looks like a pics of the sun.
Mar 01, 2009 | Dell Inspiron 5100 Notebook
Toast button sticks and sometimes does not function. Sometimes it will work if it is jiggled.
I had the same problem which was getting worse. Eventually I took the oven apart by removing the feet, shell and front. Then I removed the circuit board on the front panel which has all the switches on it. We never use the "Defrost" function, so using a soldering iron, I swapped the "Toast" switch with the "Defrost" switch. The Toast function now works normally. I plan to get some spare switches for the next time one of these goes wrong. While I had one of them out I checked it out and a Panasonic P/N EVQ-PAE05R available from Digi-Key P/N P12192S-ND looks like it will do the trick.
Oct 20, 2008 | Krups FBC112 1600 Watts Toaster Oven with...
Shutter release/AE lock and control panel display
Same problem that would not allow me to take a picture without pressing the LOCK button on my Nikon 8700. Here is how I believe I fixed the problem:
Turn the camera ON.
Press MENU button on your camera to bring up the menu.
Scroll down to SET-UP, open the SET-UP menu by scrolling right.
In the SET-UP menu, scroll all the way down to FUNC (Controls) on page 2/3 , open the FUNC (Controls) menu by scrolling right.
You are now presented with 2 options:FUNC and AE-L, AF-L)
Select the FUNC option by right scrolling.
Choose the 2nd option: i.e the mountain, flower and timer icon (distance, macro and self-timer icon) by right scrolling.
Press the MENU button to get out of the menu.
Attempt to take a picture without pressing LOCK.
Should work! Anyways, it worked for me.
Cheers.
May 27, 2008 | Nikon Coolpix 8700 Digital Camera
Oster 6330 4-Slice Toaster Logo
383 people viewed this question
Top Oster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Ben Eng
Level 1 Expert
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
