Question about Quasar SP-2723 27" TV
Is our Quasar TV (SP2723) a digital or analog television?
Question about whether Quasar TV -- SP2723 is digital or analog.
    President:
  • 2,992 Answers
That's an analog TV and would need a converter box for the new digital broadcasting.
Posted on Feb 11, 2009
How do I get free local TV over-the-air stations?
The Quasar VV-2002 only has an NTSC (analog tuner). Very few stations with NTSC transmitters are still broadcasting. Only low-power stations were allowed to continue broadcasting an analog signal. Unless you are very close to one of the transmitters, your TV will not tune in the station.
You'll need to connect the TV to a digital-to-analog over the air converter box. (The low-end ones that were free or cheap with the government coupon are harder to find; a few models are still available.) These convert the ATSC (digital) signal to NTSC. Then use an appropriate antenna and follow the instructions to tune in the available OTA signals. Send these to the TV either on the RF or composite Line-in. Set the TV to the appropriate input and use the converter box to change channels.
I hope this helps.
(20" TVs weren't required to have an ATSC tuner until 2007. Since there are reviews for the VV-2002 from 2004, it obviously is an older set.)
Nov 19, 2015 | Quasar VV-2002 20 in. TV/VCR Combo
Tip
Quasar SP3235 Manual Download
Download Quasar SP-3235 Color Television Manual
Have you misplaced your Quasar SP-3235 Color Television Owners Manual?
Would you like a digital, searchable, pdf version of the Quasar SP-3235 Color Television Users Guide?
Follow this link
to download a pdf version of the Quasar SP-3235 Color Television manual.
I hope that helps.
on May 04, 2010 | Quasar SP-3235 32" TV
How can I replace the outlet for the cables on the back of my quasar SP 3234E TV?
A "freezing" picture sounds like something other than your television. Do you have a cable box or satellite box attached? They fail sometimes and need to be replaced. (You have an analog TV and "freezing" is a digital problem.)
Jul 22, 2014 | Quasar Televison & Video
How do i know whether my tv is analog or digital
The LC-42P7M is both. It accepts both digital and composite (analog) inputs.
Jul 19, 2013 | Sharp LC-42P7M 42 in. LCD TV
Does have my quasar model sp 323 tv have an ATSC tuner? was made in 2001?
No,all tvs have CRTS(Tv Tube).Are analog tvs,don't have ATSC tuner inside.
Oct 18, 2010 | Quasar SP-3234 TV
We are in Ghana we need frequency and we update to get more channel
Your flat panel TV is probably factory set to receive ATSC signals (Hi-def DIGITAL TV), whereas
Ghana may not have converted from analog TV (NTSC) yet.
Digital TV's cannot receive analog signals. I'm just guessing about whether or not Ghana supports
Hi-Def broadcasts - you'll have to check with (any) TV channel in Ghana. The Analog-to-digital
conversion is an expensive one at the broadcast end, and may not have happened yet in Ghana.
The US conversion took place by FCC mandate June 12, 2009.
There are available $65 (USD) digital-to-analog converters, but what you may need is an
analog-to-digital converter, which doesn't exist. Your Flat-panel TV amy have to wait until Ghana
begins broadcasting a Hi-Def TV channel.
For a HD antenna, a regular old rabbit ear-type antenna will do.
Oct 15, 2010 | Televison & Video
Analog Quasar tv keeps turning off.
The bang test is a good indication that there are poor solder connections inside the set. If you can solder and are comfortable working inside the set where potentially dangerous high voltages exist even when unplugged, you can fix this yourself. Look at the main board and resolder any joints that appear grainy or have rings. That should resolve the problem. If not, see if there are any changes in the symptoms and update this.
Dan
Jan 30, 2009 | Proton MM2701VT 27" TV
HD tv changes
The changes that you mention will only effect you if you use either rabbit ears or a rooftop antenna. The over-air broadcast signals are being changed from analog to digital. If you have cable or satelite service, there will be no change.
Dan
Nov 13, 2008 | Quasar SP-2723 27" TV
Digital
From what I see under amazon.com, it does not have a digital tuner.
But the February 2009 turn off is a deadline for over the air only.
When cable companies turn off their analog signals is a different matter. Some may soon, some may wait until 2012.
The gov't coupon program is only good for converters that handle the over the air digital ATSC signals, not cable's unencrypted digital QAM signals.
Jan 20, 2008 | Quasar SP-3235 32" TV
Quasar SP-2723 27" TV Logo
213 people viewed this question
Top Quasar Televison & Video Experts
 Grubhead
Grubhead
jason
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
