I have a Peavy "Classic 30 BT" guitar amplifier that stopped working. When the power switch is ON, the pilot light glows but the vacuum tubes don't even glow. Using a volt meter, I found that 120 Vac is at the input leads of the main power transformer but there is no voltage at the secondary leads. I unsoldered the transformer leads and measured an open circuit across the input leads of the transformer. I unsoldered the copper band that wraps around the transformer and removed the plastic covers over the transformer terminals and windings. I found a small cylinderical component taped against the transformer windings that is connected in series with the primary 120 Vac windings. My Ohm-meter shows this component as an open circuit, even when I reverse the Ohm-meter leads to reverse the Ohm-meter polarity. I am guessing this is a thermal protective device for the transformer and it has failed OPEN. Does anyone know what this device on the transformer coil is and how I might find a replacement component so I can repair the transformer and the get the amplifier working again?
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
I have to agree with you that that component is a thermal fuse. In my country, they are readily available in most electronics/hobbyist parts store. These components are also used for small motors and therefore would also be available in some (but not all) kitchen appliances parts stores. A temporary workaround is to install an ordinary fast blow fuse.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Nov 29, 2008
I replaced Can I change the tubes on my fender blues deluxe reissue from 6l6 to 6v6 power tubes
An internal component has failed. Without it in front of me for testing I cannot say which. You need to takje it to the repair shop.
Jan 28, 2016 | Fender BLUES-DELUXE-REISSUE Tube Guitar...
I have a peavy classic 100 2x12 1975 has a high pitch squeal coming out of amp when powered on
If this happens only when the guitar is plugged in, most likely there are two possibilities. The first, you have some issues with the electronics in the guitar OR are using an acoustic guitar witch has an extremely sensitive pickup that provides nothing but feedback. If this is happening with the guitar unplugged, there is a mountain of possibilities.
Sep 01, 2014 | Music
Valveking 212 combo shows lamp lights but power tubes are not lighting no sound
no filament power then, filament fuse open..blown winding on transformer, regulator bad..You an ET with shop full of tools...then we can get to work...
Dec 31, 2013 | Peavey ValveKing 100w All Tube 212 Combo...
There is no sound coming out of my Marshall 100 watt tube amp head?
make sure the standby switch is operating correctly.Sounds like the power tube.
Dec 18, 2013 | Marshall Amplification Marshall JCM800...
My peavy amp will not turn on
1- check the outlet for power by plugging in a lamp or something
2- check the amps fuse. Most power amps have user replaceable glass fuses.
Aug 17, 2012 | Peavey Bandit 112 Guitar Amplifier With...
Hi, Peavey Classic Guitar amp , Has NO SOUND
Hi Mike,
If you switch on the amplifier, do you hear nothing at all?
Or do you hear low level noise or hum out of the speaker?
Don't know if you're technician.
If the tubes are glowing, you can measure the high voltage.
Check also fuse 3 and 4, thats the neg. voltage -27V and -14V.
regards,
Gerard
Jul 06, 2009 | Peavey Audio Players & Recorders
A HUMMING Peavey Classic 30
I repaired a classic 50 recently and the problem was a bad solder connection on the main input jack. You may also want to have the tubes tested.
If the unit is over 20+ years have it recapped.
I do this stuff but Vermont might be to far.
Scott
Mar 17, 2008 | Audio Players & Recorders
127 people viewed this question
 Grubhead
Grubhead
