Mitsubishi WS-73909 Tv does not power on.
I have Mitsubishi WS-73909 Big Screen Tv does not power on. When I turn it on, the green light comes on for a couple of seconds and it shuts off..
I pressed both the menu button and the input/device button on the set both in together and hold in for 6 seconds to see if the led will blink a two digit blink code, it blinks twice rapidly, then pause, then does the same ten times.
your help is appreciated, Thank you
  • cmassey Jan 17, 2009
    My set, Model number WS73909 does pretty much the same thing.
    When I first plug the power cord in, the green power light flashes for perhaps 10 to 15 seconds like it's loading it's software then goes out and when I press the power on switch the green power light comes on for less than 5 seconds then goes off!
    I don't have a fix for this but it reminds me of the power supply board that doesn't have all the correct inputs from inside the set!
  • Televison & ... Master
  • 1,830 Answers
daniel719
  • 240 Answers
SOURCE: MITSUBISHI WS-73909 will not turn on
it is normal for the green light to flash for 70 sesonds at first plugin the set will not turn on while it is taking place try it again after the light stops blinking.
now if your still having problems I need the error code
to get the error code Hold down input (device) and menue at the same time for 5 sec.
the led will start blinking an error code to you.
if it is broken we need the code.
thanks.
daniel
Posted on Jan 13, 2009
  • 126 Answers
SOURCE: Mitsubish WS-819 Protective Shutdown. 2 blinks, pause, 2 blinks
Over 95% of the time a 2 - 2 blink code on that model is a convergence output problem. You need to replace both of the convergence output IC's and perhaps the pico fuses feeding them voltage. The pico fuses are F9A04 and F9A05. They are on the same board with the convergence outputs.
Posted on Jun 02, 2009
SD Tech
  • 14553 Answers
SOURCE: mitsubishi vs-60705 grenn power button goes on
It is an error code for short protection---the most common cause for this is one or both of the pico fuses that protect the convergence IC's are bad--set will detect no voltage and instantly shut off.
I do this here for free so if this has been helpful give me a vote here. if you have questions or need help:
etower.766@netzero.net
Posted on Aug 22, 2009
  • 8457 Answers
SOURCE: I have an Mitsubishi HD 1080 big screen tv. When
Ur power ic inverter board is dead.
U need a new one.
Posted on Aug 26, 2009
SD Tech
  • 14553 Answers
SOURCE: My Mitsubishi ws-55511 does not turn on. I push
1.) 2-2 is short protection and usually means one of the two fuses that protect the convergence IC are bad.
2.) This model uses a Single convergence IC--A STK-393-110 THAT can be purchased for about 14 dollars plus shipping on ebay.
3.) If one of the fuses that protect it is blown the set detects no voltage present and shuts down instantly.
4.) I have photos of what the fuses that need to be checked look like; also there are several protect resistors around the chip that need to be looked at also--I have photos of them also.
5.) I also have step by step start to finish instructions for this repair for this model--It tells you how to do the repair and everything you will need to do it.
6.) If you want the photos and instructions give me a vote here and I will email them to you free.
7.) I do this here for free so if this has been helpful take a minute and give me a vote here.
REGARDS, SD TECH
Posted on Sep 13, 2009
Testimonial: "This was a great step by step answer to my problem. Thanks!"
I have a Mitsubishi rear projection TV (WS-73909) that didn't turn on and had a green blinking light. I replaced the 7 DM capacitors and now it turns on. Both the remote and front control panel ca
Let me know as I can look for this---the set has a keyboard lockout that is cleared by holding the menu or another front button for more than 5-10 seconds with set on---I can find the service manual and check if needed.
Nov 04, 2012 | Mitsubishi WS-73909 73" Rear Projection...
I have a mitsubishi ws-65315. When I go to turn the tv on the green power light comes on and you can hear the tv click on, but seconds later shuts off.
this model has a self check, when green light comes on and then goes off. Push and hold both the Menu and Input buttons on the front of the set for at least 5 seconds and release both.
Power light will blink a two digit error code like 2 blinks 2 blinks, a pause and then repeat it several times.
Let me know what error code you find and I will tell you what it means.
SD TECH
Feb 22, 2011 | Mitsubishi WS-65315 65" Rear Projection...
Our WS-55313 Mitsubishi Projection screen tv was on then just died. When we push power button or remote on, the green power light comes on for a couple of seconds then the tv goes off .
do the self check this model has.
When green light goes off press and hold both the input and menu buttons for five seconds and release both buttons.
The power light will blink a two digit error code like, two blinks, two blinks, a pause and then repeat it several times.
let me know what the error code you find is and I will let you know what it means.
SD TECH
Dec 26, 2010 | Mitsubishi WS-55513 55" Rear Projection...
Listen: you need to wait for the set to first shut off! then push on the TV(not the remote) Input and Menu both at the same time for 5 seconds and then release---the power light will then blink---this model has this feature--
Sep 13, 2009 | Mitsubishi WS-55511 55" Rear Projection...
MITSUBISHI WS-73909 will not turn on 1. I have a Mitsubishi Big screen TV model no WS-73909. Few days a go the city power went out when the TV was off. The TV had a surge protector. Then the TV will not go...
Are you a Quailified Technician ? Because this repair is not for the novice. The best thing I can tell you is contact a Mitsubishi Authorized repair center or tell me what area you live in and I can find one for you. cost is 250-350 to repair.
Apr 10, 2009 | Mitsubishi WD-65000 65" Rear Projection...
Turns off as soon as I turn it on. ws - 65819
I had the same problem. The repairman said the Convergence ICs were bad, located on the big aluminum heat sinks on the center board in the TV. He replaces both, and a couple of fuses (that look like resistors).
The tv worked fine for a couple of days then did exactly the same thing. They are coming back out to fix it next week. If there is anything different, I'll post an update.
Nov 22, 2008 | Mitsubishi WS-65819 TV
Tv will not power up, shuts off after 10 second
http://serviceman.site88.net/index_files/MitsubishiTV.htm
Oct 01, 2008 | Mitsubishi WS-65857 65" Rear Projection...
MITSUBISHI 65" RAER PROJECTION TV MODEL-WS 65511
Try to press both the menu button and the input/device button on the set both in together and hold in for 6 seconds to see if the led will blink a two digit blink code, then let me know the two didgit code, and I will try to assist you. Please respond to this same post when replying.
Aug 08, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi turns on for 3 seconds then shuts off..after power surge
try holding in the menu and input buttons together on the front panel for about 8 seconds to see if the self diagnosis feature will blink a two digt code then let me know what happens
Jun 05, 2008 | Mitsubishi WS-55411 55" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
