Question about JVC MX-KB30 CD Shelf System
Turns off immeaditally after turning on
Mine the display and everything work just fine but when i turn the system on it automatically turns its self back off within 5-10 seconds.. i had left the system off for several weeks and i no not understand why it keeps turning off... this happends with or without the remote.
  • Anonymous May 13, 2008
    The same thing is happening to mine. It done this last fall and wouldn't stay on to play. About 2 weeks ago I walked by and hit the power button and it came on!! It played for a couple of days and now it is shutting down again. It won't stay on for more than 5 seconds.
    Scholar:
  • 72 Answers
These units are designed in such away they are very suseptible to power surges, Brownouts. And a lot of times they just stop working through no fault of the user. A transisors or capacitor fails and the unit just does not work properly and goes out. The issue is generally the unit is priced so if you took it to a repair shop it would cost between $50 to $100 Dollars to repair. If they can get the parts to repair it or if it can even be repaired cost effectively.
Posted on Jan 16, 2007
SOURCE:
NEC V260XG temperature error. How to Stop??
check the thermostat; it appears that either the thermostat is not working properly, or is not set right or damaged
Apr 23, 2016 | NEC Display NP-V260X Dlp Projector - 3D...
Everything works fine in my mps4500 system except if I speak to the microphone too loud, it will result the speak power off. How to fix it?
I don't have a fix for this mine does the same thing I turn on and speak and it turns off then I have to turn back on.does battery need replaced or will it play with just the ac plug.
Dec 08, 2013 | Anchor Audio/PA Systems: Liberty Sound...
I am looking for the A/C fuse for a Ford mustang gt 2002
manual system
  • Blown fuse(s):
  • Battery junction box (BJB) F26 (65A).
  • Central junction box (CJB) F33 (20A), F36 (7.5A), F37 (10A), F39 (20A), F45 (15A), F47 (15A), F58 (10A) or F59 (7.5A).
  • Blower motor inoperative.
  • A/C compressor inoperative.
  • Disconnected electrical connectors.
  • Engine cooling fan inoperative.
  • Damaged control switch(es) or climate control panel.
  • Circuitry open or shorted.
Electronic Automatic Temperature Control Module Self-Test
  • NOTE: The vehicle interior and exterior temperatures should be between 10° - 32.2°C (50° - 90°F) when carrying out the self-test. If the temperature is not within the specified range, false in-vehicle temperature sensor DTCs will be displayed.
    The EATC module self-test will detect concerns in the system control functions and will display hard diagnostic trouble codes (DTCs) in addition to continuous diagnostic trouble codes for concerns that occur during system operation.
  • The self-test can be initiated at any time. Normal operation of the system stops when the self-test is activated.
  • NOTE: The key must be in the RUN position to enter the self-test.
    To enter the self-test, press the OFF and floor position buttons simultaneously and then press the AUTOMATIC button within two seconds. The display will show a pulse tracer around the center of the display window. The test may run as long as 30 seconds. Record all DTCs displayed.
  • If any DTCs are retrieved during the self-test, proceed to Electronic Automatic Temperature Control (EATC) Module Diagnostic Trouble Code (DTC) Index.
  • If a condition exists but no DTCs are retrieved during the self-test, proceed to Symptom Chart.
  • To exit self-test and retain all continuous DTCs, push the blue (cooler) TEMP button. The module will exit self-test, retain all continuous DTCs and then turn off (display blank).
  • To exit the self-test and clear all DTCs, press the defrost button. The display will show 888 and all function symbols for one second. The module will then turn off (display blank) and all DTCs will be cleared.
  • Always exit the self-test before turning the EATC system off.
  • Continuous DTCs will be deleted after 80 ignition switch ON cycles after a continuous condition occurs.
Mar 28, 2011 | 2002 Ford Mustang
Tv wont turn on
i had this problem myself, press the power button and when it goes green press it again but hold it for 10 seconds, then it should work fine mine did good luck :)x
Jan 29, 2010 | Televison & Video
Heater displays everything but you cannot turn anything on ac will not turn on neither will the heat the buttons will not even light up please help
From the equipment description, I take this to be a EATC ( Electronic Automatic Temperature Control ) system.
You can try to run the EATC diagnostic test & recalibrate ( once you have confirmed it is not a fuse )
Electronic Automatic Temperature Control Module On-Demand Self-Test The EATC module on-demand self-test will retrieve on-demand (hard fault) DTCs only, it will not retrieve continuous DTCs. Continuous DTCs can be cleared when exiting the EATC module on-demand self-test. Make sure to retrieve continuous DTCs by carrying out the Electronic Automatic Temperature Control Module - Retrieve Continuous DTCs procedure before clearing any continuous DTCs.
•The EATC module on-demand self-test will not detect concerns associated with data link messages like engine coolant temperature or vehicle speed signals. A diagnostic tool must be used to retrieve these concerns.
•The EATC module on-demand self-test will detect concerns in the system control functions and will display on-demand (hard fault) DTCs for concerns that are present during the self-test. The vehicle interior temperature should be between 4°-38°C (40°-100°F) when performing the self-test. If the temperatures are not within the specified ranges, false DTCs may be displayed.
•The self-test can be initiated after cycling the ignition switch from OFF to ON. Normal operation of the climate control system stops when the self-test is activated.
•To enter the self-test, press the OFF and DEFROST buttons simultaneously and release, then press the AUTO button within 2 seconds . The display will show a flashing blower icon for 20 seconds , after which all vacuum fluorescent segments will be displayed if there are no on-demand DTCs present. If DTCs are present the EATC module will display "00 00" and then on-demand DTCs. Record all DTCs displayed.
•If any DTCs appear during the self-test, carry out the diagnostic procedure. Refer to the Electronic Automatic Temperature Control Module Diagnostic Trouble Code Index and follow the ACTION for each DTC given. See: Diagnostic Trouble Code Descriptions
•If a condition exists but no DTCs appear during the self-test, GO to Symptom Chart Condition: The EATC System Is Inoperative, Intermittent or Incorrect Operation. See: Symptom Related Diagnostic Procedures
•To exit the self-test and retain all DTCs, press any button except DEFROST. The EATC module will exit the self-test and retain all DTCs.
•To exit the self-test and clear all DTCs, press the DEFROST button. The EATC module will exit the self-test and all DTCs will be cleared.
•Always exit the self-test before powering the system down (system turned OFF). Once the self-test is exited, the ignition switch must remain ON for at least 30 seconds to allow the door actuators to automatically recalibrate.
•Continuous DTCs will be deleted after 80 ignition switch ON cycles after the intermittent fault occurs.
The EATC module will retrieve only continuous (intermittent and hard) DTCs when carrying out this procedure.
•Retrieval of continuous DTCs can be initiated after cycling the ignition switch from OFF to ON. Normal operation of the climate control system stops when retrieving continuous DTCs.
•To retrieve continuous DTCs, press the OFF and DEFROST buttons simultaneously and release, then press the RECIRC button within 2 seconds . All vacuum fluorescent segments will be displayed if there are no continuous DTCs present. Continuous DTCs are indicated by the presence of the degrees Celsius symbol (°C) on the EATC module display. Record all DTCs displayed.
•If any DTCs appear, carry out the diagnostic procedure. Refer to the Electronic Automatic Temperature Control Module Diagnostic Trouble Code Index and follow the ACTION for each DTC given. See: Diagnostic Trouble Code Descriptions
•If a condition exists but no DTCs appear, GO to Symptom Chart Condition: The EATC System Is Inoperative, Intermittent or Incorrect Operation. See: Symptom Related Diagnostic Procedures
•To exit and retain all continuous DTCs, press any button except DEFROST. The EATC module will exit the retrieved continuous DTCs mode and retain all continuous DTCs.
•To exit and clear all continuous DTCs, press the DEFROST button. The EATC module will exit the retrieve continuous DTCs mode and all continuous DTCs will be cleared.
•Always exit the procedure before powering the system down (system turned OFF). Once the procedure is exited, the ignition switch must remain ON for at least 30 seconds to allow the door actuators to automatically recalibrate.
Electronic Automatic Temperature Control (EATC) Module and Electronic Manual Temperature Control (EMTC) Module Cold Boot Process The purpose of the cold boot process is to allow the EATC or EMTC module to re-initialize and calibrate the door actuators. To carry out the cold boot process, follow the steps below.
1.Turn the ignition switch to the OFF position.
2.Disconnect the EATC or EMTC module electrical connectors.
3.Wait one minute .
4.Connect the EATC or EMTC module electrical connectors.
5.Turn the ignition switch to the ON position.
6.Select any position except OFF on the EATC or EMTC module. The EATC or EMTC module will now initialize and calibrate the mode doors. Calibration of the mode doors will take approximately 30 seconds .
Nov 27, 2009 | 2005 Ford F-150
It turns off, or goes to sleep. Won't wake up.
Hello there topothemorni,
Are you familiar with Windows' "Power Options" module, and that within it you can tweak all things related to power saving (e.g., system sleep, hibernate, and automatic MONITOR shut off)? More than likely you just need to make a visit there and make some desired adjustments.
[Control Panel > Power Options]
... OR ...
Start > Run > type "powercfg.cpl" (without quotes), then hit Enter.
Once there, you'll probably find most everything self-explanatory.
Also, it may be responding to configurations adjustable from within the monitor itself. Somewhere on the monitor there will be a OSD (On Screen Display / Setup) button of some type, where from there you'll be able to make whatever necessary tweaks. Refer to its documentation if you don't find it self-explanatory.
Good luck and please let me know if you have any further questions, and/or just to let me know how things worked out.
"Today's the best day of my life...and NOW you're part of it!"
Mar 26, 2009 | Computers & Internet
Screen won't show up but this is diffrent
This happened to mine and it had to be sent back to be repaired (3rd time) as the graphics card had failed; it started with the display colours looking strange, then the picture went totally. If you can hear everything working (beeping/whooshing" as you go through the "blades", it sounds like you have the same problem. below is how to reset to the default display sttings just in case anything has gone wrong on this.
To reset the display settings of the Xbox 360 console to the default settings, follow these steps: (Copy and pasted from Microsoft support pages)
  1. Remove any discs from the disc tray.
  2. Turn the console off.
  3. Turn the console on.
    Note If you are using an Xbox 360 Wireless Controller, turn the console on by using the Xbox Guide button on the controller.
    Note Make sure that you use the player 1 controller when you do this. The player 1 controller is the controller where the upper-left quadrant light is on.
  4. As the console starts, press and hold the Y button, and then pull the right trigger at the same time. This causes the Xbox Dashboard to reset the display settings to the default settings and then automatically restarts the console. So it's OK when the Xbox 360 console restarts.
If this doesn't work then try phoning XBOX Support on 0800 587 1102.
Dec 23, 2008 | Microsoft Xbox 360 Console
Locked dvd tray.
with the unit off press and hold the stop button and the eject button.
Jul 08, 2008 | JVC TH-S11 Theater System
FAN!!!
Oh, it turns out the the microwave was over heated and the fan was cooling it. The fan will automatically turn on and stay on until your microwave reaches normal temp. just unplug your microwave and let it cool off. then plug it in and everything should be just fine.
May 25, 2008 | Frigidaire GLMB209D Microwave Oven
Rca hd50lpw175
I'm sure you've found out by now that your bulb was going bad...
Jul 28, 2007 | RCA HD50LPW175 50" HDTV
JVC MX-KB30 CD Shelf System Logo
222 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
