Question about Dell Precision 340 PC Desktop
Dell Precision 340 will not boot past the bios
This dell will not boot past the bios, I have taken out the battery and tried the various jumpers. They did dump the bios and cmos which was reloaded. It hangs up after it loads the adaptec ultra/ultra, there used to be a window where I turned the ultra/ultra off. The window no longer comes up and it will not go into setup or reach a floppy drive.
  • rgypsees Nov 29, 2008
    Thanks for trying, I manually turned off the adaptec unit which is built into the mother board. The computer used to load the adaptec and then a window was available to modify or make changes to it. The window does not get loaded to allow me to turn the unit back on. So it must be initialized via a hook up to the mother board. I may call dell and discuss it with them. This unit has been a piece of **** since the day it got here, was just trying to see if it could be reconfigured with out the dell stuff for a usable system.
  • Loteck May 11, 2010
    Can you turn off this ultra/ultra thing in the BIOS.
  • 2,427 Answers
It is possible that one of the drives are causing the proble. Disconnect all drives Hard drives, CD, DVD, BLUERAY,Floppy etx and turn the system on if it boots then shut it down and connect the drives one at a time until you find the one at fault.. If this fails then the problem resides in the main board itself, YOu said you cleard the cmos, try reseating the processor (removing and then putting it back) then flashing the bios (clear the cmos) ,, if that fails then you may need to replace the mainboard.
Posted on Nov 29, 2008
I have dell precesion 650 not boot and message comeout checkpoint[IntV]
You can try resetting the BIOS via jumper on the motherboard, if not change, try removing all expansion cards other than video see if anything changes.
If no change, replace the motherboard
Jun 16, 2011 | Dell Precision 650 PC Desktop
I need to know how to do the bios password thing on a DELL PRECISION M20 laptop
To reset the BIOS read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
To set up a password, go into BIOS by pressing DEL key on start up and under Security set supervisor password.
Dec 15, 2010 | Dell Precision M20 Notebook
How to reset Dell Precision M60 BIOS password
Nov 06, 2010 | Dell Precision M60 Notebook
Dell 340 will not recognize my cd or dvd drive.
check if you see any light on the drive, if yes. then the power is there and then the problem is with the data cable of the cd drive. try to repalce the cd drive with another cd drive. if it still doesnot work and if the same cables work with the hard drive, then the cd drive has gone bad. and if the new drive also doesnot work then reinstalling the operating system should fix the problem only and only if it appears in the bios. if it doesnot appear in the bios. then the problem is not of the operating system. then its the motherboard.
Oct 13, 2009 | Dell Precision 340 PC Desktop
How can i reset bioss password....dell precision m65
my friend the new laptop has no jumper anymore on the board, and u cannot reset the bios this easily, some laptops u still can do that by disconnecting the bios battery and connect it after some minute, but if this doesnot work donot destroy ur laptop.
Jun 14, 2009 | Dell Precision M65 Notebook
Bios password set
remove battery, boot to system settings, re-insert battery, CMOS PW should now be cleared
Jun 11, 2009 | Dell Precision 380 P4 Dual Core 3 GHz...
How do I reset my lost bios password for Dell Precision M70
If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard. If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
On some motherboards, the battery is soldered to the motherboard, making it difficult to remove. If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password. If you have the motherboard documentation, you will know where that jumper is. If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper. This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard.
If all else fails, you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your motherboard.
The BIOS password may be cleared from a Dell Optiplex by removing the password jumper (PSWD) from the motherboard.
The location of the password jumper on a Dell Optiplex motherboard can be found by reviewing the Optiplex User Guides.
For most Dell Optiplex desktops, the steps to reset a BIOS password and clear all CMOS settings are:
  • Locate the 3-pin CMOS password reset jumper on the system board.
  • Remove the jumper plug from pins 1 and 2.
  • Place the jumper plug on pins 2 and 3 and wait approximately 5 seconds.
  • Replace the jumper plug on pins 1 and 2.
Each Dell Inspiron has a master password which will clear the BIOS password. You can get this number by calling Dell Technical Support at (800)624-9896.
Dell Technical Support will request the Service Tag and Express Service Code from the bottom of your Inspiron.
Thank You,
Your Support Tech.
Manish Shirsikar,
Fixya.com
May 18, 2009 | Dell Precision M70 Notebook
Boot a Sony DVD RW DRU-840A drive in DELL precision 530
Have you tried changing the boot order.
If you're trying to use it as a boot device you need to tell the system to boot the cd /dvd drive FIRST and of course you need to have a bootable cd / dvd in the drive.
Let me know if you're already tried this.
Mar 04, 2009 | Dell Precision 530MT (WHL530MTGHEI31LE) PC...
Dell System Precision Workstation 340 will not boot
open your cpu then remove cmos cell for 10 seconds.
alos near cmos u see jumper it is set in 1-2 posirion change it to 2-3 thne power up the computer then again set it to itsd original positionmeaNS 1-2 .
Nov 26, 2008 | Dell Precision 340 PC Desktop
Dell Precision 340 PC Desktop Logo
1,024 people viewed this question
Alun Cox
