Question about Panasonic KX-TG2248S-OB Cordless Phone
Handset won't work
I got a call, but when I picked the handset up from the cradle it beeped and this message came on the screen: Please lift up and try again I can't use any of the function keys (menu, speaker phone, etc) either. Tried unplugging it, taking battery out and putting it back in, looked in the manual, but can't fix it.
  • 3 more comments
  • Phyllis Castenholz Jan 16, 2007
    My phone is still not working. Any ideas?
    Thanks.
  • davebrun Dec 05, 2007
    "please lift up and try again" displayed when any button is pressed except off. Panasonic model KX-TG2216
  • AsibE Dec 08, 2007
    I have the exact problem with the same KX- tg228S Panasonic phone. How can I fix it? Dec 08, 2007.
  • subh123 Dec 09, 2007
    I am having exact same problem. Couls anybody know how to fix it
  • Mehdi Javan Mar 02, 2008
    I have the same problem too. Please help.
  • 65 Answers
SOURCE: panasonic handset please lift up and try again error
According to the manual when you get this message
Please lift up andtry again.
A handset button was pressed while the handset was
on the base unit or charger. Lift the handset and press
the button again.
Posted on Feb 08, 2008
SOURCE: My new phone had a
Verizon sent a technician in
Posted on Dec 05, 2008
SOURCE: no link to base.
unplug the base and when you plug it back in
the handset should work
Posted on Feb 07, 2009
RPFinney
  • 385 Answers
SOURCE: cordless phone not connecting to base. no dial tone.
switch the A/C mains off 5 minutes
or
Re-register them to the base,
This resolves the problem
Regards
Richard.
Posted on Apr 26, 2009
SOURCE: Panasonic DECT 6.0 - Flashing Lights
Simliar problem resolved for me when I took the batteries out, waited a couple of minutes and put them back. Also phones works best with certain batteries and not others.
Posted on Jun 17, 2009
Using Uniden digital answering machine with 2 phones. When I pick up either phone to make a call a message appears on the screen, "connecting". . Tried another phone ,line good.
Check if the base power adapter is warm to the touch. If it's cold, then the base has no power. Test if distance between the handsets and the base is an issue by moving closer to the base. Check for any radio interference. Check if the handsets are registered. You may need to de-register them first. Try unplugging the base (power and phone line cord) then remove the batteries from each handset. Wait at least 15 minutes before restoring the power/batteries. If the base has a charging cradle, place one handset in that cradle and wait a few minutes. See if that handset works. Otherwise, try to register one of the handsets and see if it works.
If the problem persists, then the base probably has a problem transmitting or receiving the signals from the handsets. Unless the system is under warranty (one year), you should replace the system. Otherwise, contact Uniden customer support.
I hope this helps. Please add a comment with the model of the Uniden phone if you want directions for registering/de-registering the handsets.
Aug 16, 2018 | Uniden Lands Phones
Why do you have to press talk to answer the pdone
There has to be some action to tell the phone you're answering the call. Old phone did so when you picked up the handset. With this phone, you might have picked up the handset just to check the caller ID, so it won't answer the call upon removing the phone from the cradle. Besides, you might have picked up the phone to go out onto the patio or to the bathroom, for example. How is the phone then to know you want to answer a call?
Aug 11, 2011 | Uniden 5.8GHz Dual Cordless Phone
Display screen shows "Will return soon" Would like
You need to cancel absent message on your phone. The method depends on which Panasonic phone system your phone is connected to. Following are the methods for three different Panasonic phone systems. Once you cancel absent message, your screen should return to date and time, if not then press * until it does.
KX-TA624 Phone System
Press intercom button, dial 750#, lift handset then return handset to cradle to end.
KX-TA1232 Phone System
Press intercom button, dial 7500, lift hanset then return hansdset to cradle to end.
KX-TDA100 or KX-TDA200 Phone Systems
Press intercom button, dial *7500, lift handset then return handset to cradle to end.
Jan 27, 2011 | Panasonic KX-T7633 Corded Phone
Cannot hear phone ringing in headset, only on handset.
The HL10 handset lifer is what notifies your headset that you have an incoming call. If you are using the handset lifter and are not receiving the 3 short beeps in your ear piece there are a couple different things that could be going on.
1. The internal microphone could have gone out on the lifter. This microphone is what sends the signal to your headset that you have an incoming call. If the microphone is working you will hear 3 short beeps in your headset.
2. If the volume is too low on your telephone, the handset lifter will not notify the headset of an incoming call, so try turning the volume up on your phone and see if that takes care of the problem.
3. The HL10 handset lifter ships with a ring detector that has a 2.5mm jack on one end and a small round microphone on the other end. This ring detector is intended for phones that do not have the speaker located under the handset. You could try plugging this into the back of the lifter and setting the microphone next to where the lifter is mounted on your phone. This might help pick up the sound of the phones ring tone.
If you are manually lifting your handset out of the cradle and sitting it to the side instead of using a lifter, then you will not receive the 3 short beeps in your earpiece to notify you of an incoming call.
Good luck from Headsets Direct!
Nov 03, 2010 | Plantronics Voyager 500A Deskphone Adapter...
My phone is stuck on speakerphone. When I pick up...
There are two things to check that you can fix. First, try replacing the handset (curly) cord. A broken wire in the cord can make this happen. If that's not it, watch the hookswitch. That's the plunger that goes down when you put the handset in the cradle, and pops back up when you lift the handset. If it's stuck down, you will only get speaker and no sound in/out of the handset.
May 21, 2010 | Nortel Norstar 16-Line PBX Speakerphone
I cannot use the cordless part of my panasonic KX-TC1221BXB. The following message is shown ''No link to base. Place on cradle and try again'' But even after placing back on the cradle, the same message is...
I couldn't find the exact manual for your phone but I would try to re-register the phone. Following are some instructions for similar models of your phone.
*To do this on a non-expandable cordless phone:
  • Press and hold the LOCATOR/INTERCOM button on the Base until a beep sounds.
  • Press and hold the FLASH/CALL WAIT button on the Handset until a beep is heard.
  • When registration is complete, a beep sounds from the handset.
  • Wait for 20 seconds after registration is complete to allow the handset to establish communications with the base.
If this fails to help: Remove the AC Adapter from the phone base or wall outlet for a few seconds and reconnect. It may also be necessary to remove the battery from the handset for a brief moment.
Mar 06, 2010 | Lands Phones
Cannot answer phone when it rings
when you lift the handset from the cradle try pressing the line number button on the handset or answer button on the handset.
May 29, 2009 | Vtech Cordless 6041 Phone
No dialling tone - just a beeping sound
It sounds like the handset is not 'registered' to the base station/cradle. Solution may be in the user handbook, which you should be able to download at :
www.cordless-phones.uk.com
Jun 23, 2008 | NTL VS1500 Cordless Phone
Panasonic KX-TG2248S-OB Cordless Phone Logo
52 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
