Question about Kenmore Washing Machines
How do you install belt on a kenmore front load washer model #41743042200
    Sergeant:
    Champion:
  • 311 Answers
Goes on motor mpulley first then roll it onto large; it's tight but fits. Adjust position of belt on motor pulley grooves so it rides centered on large pulley. Make sure large pulley is not warped; replace if it is. If belt came off on you buy a new one. I cannot see your reply due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Posted on Nov 29, 2008
  • sam siri Jun 28, 2013
    the belt i have is model134051000. i 've alredy checked . it is the right one but it is 2 inches shorter than my old one. it 's seem too short when i try to put it in. i afraid to strech it and also do not know how.
usually direct drive if top load,no belt has a motor coupling,send model number so i can look up your model,sears kenmore doesn't make washers,they just put the name on it,say washer starts with 110. on model,then you know whirlpool made it.
Jun 24, 2014 | Kenmore 24032\24036 Top Load Washer
Tip
Drive Belt Installation on a Whirlpool Duet or Kenmore Elite Front Loader
This advice is on how to replace the drive belt on Whirlpool Duet and Kenmore Elite front loader washing machines. To replace the drive belt on a Whirlpool Duet washer, follow these steps:
1. Unplug the washer and turn the washing machine around so you can access the back panel. Remove the rear panel by locating and loosening the screws around the perimeter of the panel.
2. Loop the drive belt on the drive motor pulley with the ribbed side on the pulley. Leave a one-groove gap between the belt and the end of the pulley.
3. Take both hands and pull straight up on the belt and place on the drum pulley beginning on the left hand side.
4. Hold the belt firmly in place and slowly turn the drum pulley to the right while holding the belt in place. The belt will eventually align and hold in place on the drum pulley.
NOTE: This may require some effort to get the belt in place.
If you have any questions, or are uncertain if these steps apply to your washer (some newer model Maytag front loaders are now manufactured by Whirlpool) please provide me with a model number and I can let you know if these steps apply. I hope this information is helpful.
on Sep 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Over loaded my front load lg washer and now it is not able to spin. Makes awful grinding noise. Is this something I can fix myself?
this hapened to me years ago it was an easy fix I took apart my washer ther should be a belt that almost looks like a belt off a car it probably went off track once you get it apart try spinning the belt you should be able to fix yourself
Jul 06, 2012 | Kenmore HE2 Plus Front Load Washer
Instructions on how to install a belt on a kenmore top load washing machine model #: 110.24622300
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Next, see the following illustrated description of how to replace a belt on top load washers:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=144&osCsid=2d35143b9424efb2825c26899392c2e1
Sep 08, 2010 | Kenmore 22422 Top Load Washer
How to change belt?
<P><SPAN style="WIDOWS: 2; TEXT-TRANSFORM: none; TEXT-INDENT: 0px; BORDER-COLLAPSE: separate; FONT: medium 'Times New Roman'; WHITE-SPACE: normal; ORPHANS: 2; LETTER-SPACING: normal; COLOR: rgb(0,0,0); WORD-SPACING: 0px; -webkit-border-horizontal-spacing: 0px; -webkit-border-vertical-spacing: 0px; -webkit-text-decorations-in-effect: none; -webkit-text-size-adjust: auto; -webkit-text-stroke-width: 0px" class=Apple-style-span><SPAN style="FONT-FAMILY: arial, verdana, sans-serif; FONT-SIZE: 13px" class=Apple-style-span>If this is a Kenmore FRONT LOADING WASHER, similar to the one pictured, the following link explains step-by-step, how to change the drive belt:</SPAN></SPAN><BR class=Apple-interchange-newline></P><P>&nbsp;</P><P><A href="http://www.fixya.com/support/r3609900-drive_belt_installation_whirlpool_front">http://www.fixya.com/support/r3609900-drive_belt_installation_whirlpool_front</A></P><P>&nbsp;</P><P>&nbsp;</P><P>There is no tension pulley on this model washer and there are no adjustments to tighten or loosen the belt.&nbsp; If you have diffiulty getting the belt to go back on the drive pulley on the back of the tub, or if this is NOT a question for a WASHER, please post back with your MODEL NUMBER and let me know.&nbsp; I hope this helps you.</P>
Aug 24, 2010 | Kenmore 44102 Front Load Washer
Belt is loose or needs replaced. on a 70 series kenmore washer machine
Can you provide the exact Make, Model and Kenmore model number? ..........
Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines.........
The model number on top load washers is usually found by lifting the lid and looking above the tub.
The Fixya numbers are Stock Numbers.
Since basic top load direct drive, top load electronic and front load washers are very different, the actual Model Numbers are necessary to correctly diagnose the problem.
Slipping on direct drive washers is usually caused by a damaged / broken Motor Coupler or clutch.
If yours is a direct drive machine, see the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135&osCsid=5666a1d539401da8aec3c1514f2bc0f9
Jul 09, 2010 | Kenmore 24032\24036 Top Load Washer
Model 417.43042200 Kenmore Washer
I HAVE A KENMORE FRONT LOADER WASHER. MODEL 41743042200 AND IT MAKES A NOISE WHEN IN THE SPIN CYCLE, THIS ONLY HAPPENS WHEN SPINNING. CAN SOMEONE HELP
Apr 23, 2009 | Kenmore 45081 Front Load Washer / Dryer
How difficult to replace belt for front load clothes washer Kenmore 8 years old? I'm an average handyman.
the belt is held by pulleys, there is an ajustment bolt loosen this (should be marked) to loosen the belt. some models have a frame bolt that must be removed to get the belt off. this repair should be fairly easy to do.
Apr 21, 2009 | Kenmore 22422 Top Load Washer
Kenmore front load washer eco system belt
Go to Sears.com and follow the links for parts, you will have a search window for your model and their website has complete illustrated parts breakdowns with part # and prices.
Record the Sears belt part number and check with anyone who sells belts in your area.
They will have a cross reference to Sears/Kenmore part numbers so you don't even really need to know the size.
The replacement belt will have a length on the cardboard sleeve that you can add to your user guide.
Jul 22, 2008 | Kenmore 44832 Front Load Washer
Kenmore model 41743142200
Un plug washer remove belt by lossing the tensioner , bring to appliances center and assemble again /
Jan 07, 2008 | Kenmore 45081 Front Load Washer / Dryer
Washing Machines Logo
191 people viewed this question
Sal De
fordexpert
Robert Rankin
