Question about U.S. Robotics (USR8054) Router
How do i / can I connect dsl (att / motorolla modem) to USroboti
How do i / can I connect dsl (att / motorolla modem) to USrobotics 8054 for wireless access?
I have been working on the same problem. I found information on the router settings on the USR website http://www.usr.com/support/8054/8054-ug/three.html but after the wizzard was run and PPoE setting was set to automatic (IP is Dynamic), it still doesn't work. I believe the modem needs to be set to bridge mode, instructions for this are on AT&T's website.
http://helpme.att.net/article.php?item=12197 Good Luck.
Posted on Feb 06, 2009
Cannot connect to att DSL through Linksys router.
hi
I've tried:
Having the router get an IP automatically from the modem.
Changing the router's IP address.
Having the modem pass PPPoE authentication to the router.
Bridging the modem.
Power cycling the guts out of everything.
Jul 02, 2010 | Linksys Wireless-G WRT54G Router
Intermittent DSL connection. Frequent need to reboot modem.
the modem is already old and obselete try to upgrade the modem. even though the lights on your modem works. try to call ATT because they can run a line test so they can determine if the connection is good or not
May 22, 2010 | Efficient Networks SpeedStream 5360...
Att dsl internet on deskop and want wireless for my laptop
Yes you can buy a different DSL modem and that should not be a problem , then once you have the new DSL you just contact ATT and they will set up the settings on it...
Oct 09, 2009 | 2wire 2700HG-B Router (2700HGB)
2wire att dsl modem/router on vista
Connect your DSL to wireless router and enable automatic ip on wireless. check whether DHCP is enable in DSL router or not.
Apr 24, 2009 | 2wire 2700HG-B Router (2700HGB)
Have changed to att may I use linksys modem
Yes, you can still use the Linksys router with your ATT dsl modem. Could you provide me with the model or brand of your ATT dsl modem so I could provide you with the steps on how to setup your router?
Feb 27, 2009 | Linksys EtherFast Cable Modem with USB and...
Laptop only getpoor dsl wireless signal even if standing at base
wireless signal is not from ATT but from the router or modem.
the distance between is line of sign. approximate max distance is 500 ft. you should have not problem connecting it.
The only obstacle is walls, trees, or any other thing between you and the modem.
Nov 14, 2008 | Zoom X6 (5590) DSL Modem (55900003)
Connecting ADSL wireless modem router to COMCAST
unfortunately you can't because the 2wire is a dsl modem it has to use the phone line to connect to the internet, it would be different if it was just a router but since it is a modem it needs that connection to the phone line in order to work
Oct 15, 2008 | 2wire (1000-400108-001) Router
CAN A 2WIRE DSL ROUTER WORK WITH A CABLE INTERNET CONEECTION
The 2wire dsl modem/router cannot be use with a another cable modem , since this 2wire device is also a modem/router and its made for the DSL conenction that's why it wont work with Cox cable, the best thing that you can do is to ask Cox to give a wireless modem/router like this 2wire so you can still use the wireless connection of your computer..
Hope that helps..........
Sep 06, 2008 | 2wire (1000-400108-001) Router
2701HGB modem - dsl light flashes red
if all the lights on the modem are Green then it means there's no prob with the hardware. just make sure that you're going to use the right WEP key or wireless password. the network name is 2wirexxx, the X is the the last 3 numbers of the SN which can be found on the bottom of your 2wire 2701HG-B.make sure that your wireless switch is also turned on of course. the wireless light on the modem will lit if it is connected
May 07, 2008 | 2wire (1000-000057-000) Modem
Open Questions:
U.S. Robotics (USR8054) Router Logo
493 people viewed this question
Top U.S. Robotics Computers & Internet Experts
Michael Galve
Michael Galve
Aris C.
Aris C.
Are you an U.S. Robotics Computer and Internet Expert? Answer questions, earn points and help others
