Question about Gateway FPD1950
Dead monitor I just moved into a new house and as soon as I went to set up my computer my monitor did not power on. When I plug it in the on/off button flashes like its turning on but quickly turns off and nothing happens. I have tried both different power cables as well as different outlets.. Same results.. Am I out of luck or is it a simple fix..
  • megan1990 Mar 11, 2008
    i just bought a laptop from overstock.com it use to work then suddenly i go to turn it on and the screen is black the lights are on the fans are on and i can get it to work by hooking another monitor to it what could the problume be.
  • SUZIHASNI May 16, 2008
    Took the tower in for video card replacement and now the monitor won't power up. Power button and screen flicker briefly when power is connected and that is all.
I've the same problem with my 1950. I'm told it is a problem with the logic card, and not the power supply. to 'The Marv', I don't know what the graphics card has to do with 'louee's' problem of the power not coming on..
Posted on Jun 05, 2008
    Scholar:
  • 72 Answers
Make sure the monitor is connected to the right video graphics card. This will happen if you are using the wrong one. Because at one time someone added another graphics card. Move the computer and put the monitor cable back in the wrong port on the back of the computer.
Posted on Jan 16, 2007
My Acer TCO03- power button is just blinking but no picture display
Blow hot air into the back with a hair dryer before trying to start it.
(not kidding)
if that works, one of the capacitors on the power board went bad.
even if that does NOT work, one of the capacitors on the power board went bad.
It is ALWAYS one of the capacitors on the power supply gone bad.
Being unplugged for a few weeks - as you stated - drained it of "juice", and it just cr*pped out. It was going to fail soon, in any event.
Fixing it can cost you less than a dollar, if you Google for information.
Best of luck!
Mar 03, 2015 | Acer Monitor Lcd 19in Al1923 0.29mm...
Yesterday my electricty went off and now I can't get my monitor to come back on. The power light is flashing. I've tried unplugging it and plug it back in and then hold in on the power button. But so far...
Hey
Flashing means generally that the monitor is in stand by mode since there is no signal from the computer.
If possibly try the monitor on another machine and another monitor with the computer to norrow down the problem.
Please let me know the results of the above and if you have any questions or requests I will be available and will answer to them as soon as possible.
Nov 04, 2010 | Gateway FPD2275W LCD Monitor
Touch screen wont turn on power light keeps flashing green, rapidly, worked right up till we moved it to a new computer. what do i do?
It may be that the cord you have plugged into the tower either a.) doesn't like the plug in or b.) your going to need to adjust power and voltage settings to the monitor
Oct 30, 2010 | Elotouch 17" LCD Monitor
I can't turn the monitor on. The light continuosly flashes
I would go ahead and get a new monitor. It sounds to me as if the button is broken were it connects on the inside
Feb 23, 2010 | Acer Value Line AL1717B Monitor
Blackout on plug in!
Try your monitor on another computer or another monitor on your PC. This will tell you if the monitor has a problem or your video card (or connection).
Oct 30, 2008 | BenQ FP731 17" LCD Monitor
Green Flash power only on one computer
It sounds like the monitor functions properly and your computer functions properly, but the combination causes a problem. Try making sure the screen resolution on your main computer is set to an acceptable resolution for your monitor - AL1916. Try setting it low to 800x600 and move up from there until it doesn't work anymore. You can change the screen resolution from the Display Settings (right click on the desktop and select Display Settings) window.
Jun 11, 2008 | Acer AL1916B 19" LCD Monitor
Dell E151FPp LCD Monitor
Next time you reset, check both the monitor settings and your BIOS settings for wake up
Feb 24, 2008 | Gateway FPD2275W LCD Monitor
NO POWER AT ALL!
Does the power supply have its own power switch?
It is located next to where the power wire plugs into the back of the PC.
Jan 10, 2008 | E-Machines eMachines Desktop PC
Blueish screen
Follow these steps to solve the problem... Make sure that the moniter power button is off. Unplug monitor from mains ( the auto exit button should flash red after about five seconds and you hear a popping sound.) plug monitor back in mains. hold down + and - on the monitor now hold down power button on monitor let go of power when power button when the green led lights up let go of + and - buttons wait a few seconds and press menu, a hidden menu will appear in the top right use the + and - buttons to move the highlighted option over the auto colour option in the menu push the menu button.
Jun 08, 2007 | iiyama ProLite E434S 17" LCD Monitor
Monitor flashes image for split second then goes blank but green LED flashes as well
while the monitor is still powered on, but with the LED flashing, unplug the monitor from the PC. press the power button, and the monitor should go off, now plug the pc back into the monitor. Turn the monitor back on and it should work.
Occasionally this will not work for me, but if I repeat it it normally works
Hope this helps - my problem is intermitant so it may be different to what u guys have
May 02, 2007 | ViewSonic VX924 19" LCD Monitor
Gateway FPD1950 Logo
167 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Steve Allison
Steve Allison
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
