Question about Canon P23-DH Calculator
Where can I find an ink roller for my Canon P23-111 calcultor?
Whart ink roller do I need and where on line can I order it from? It is for a Canon P23-111 calculator.
  • 1 more comment
  • kangmdphd Jan 21, 2009
    Where to buy a roller ink?
  • Anonymous Mar 12, 2014
    P23-DH11 ink roller
  • Anonymous Mar 27, 2014
    Who sells the replacement ink roller for a Canon P21-D calculator?
I recently purchased replacement ink roller for the Canon P23-DH 111 (2 pack) from Staples Business Depot.
It uses ink roller CP-13 .
Priced under $10
Posted on Apr 03, 2009
Try this site
http://www.heasterlawson.com/canelcalblac.html
best luck
Posted on Feb 20, 2009
When printing on my Canon Pixma MP500, there is a dark black line down the middle of the page. As the pages print, it gets lighter and lighter, but is very dark on the first one. Any thoughts?
Ink tends to overflow at the bottom guide rollers and the roller gets coverd in ink and causes the black line!The best will be to take it to a dealer and have it cleaned!Good Luck!
Apr 16, 2010 | Canon Pixma MP500 All-In-One InkJet...
Canon makes thick black line when copying
Hi there, had a smiliar problem in the office this week all three printer having the same issue, black lines, all related to the drum kit, either being covered in ink, or in once case it had a break in the roller.
have a look at this pic, its the drum roller for your printer, amazon link
It is normally sits under the printer toner, take the toner out and you should have access to the unit the tonner fits into, if you look at it closly you should see the roller see if you find any telling signs of ink residue/or cracks on it. If you do its most likely the problem.
Hope it helps
Z33m
Dec 11, 2007 | Office Equipment & Supplies
Ink leak?
It's not the cartridges, the waste ink is coming up thru the bottom to the exit rollers. The only fix is to have a shop open it up, clean up the ink mess and install a shield that stops the ink from coming back up when it should go to the absorbers. The new machines all have this shield and the ink tube cut back to make the ink go where it should.
Feb 21, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Leaking Ink Cartridge
You need a shop to clean the extra ink that's coming up on the rollers and install a mylar strip to prevent that in the future. It's the waste ink being forced up thru the exit rollers and getting on the prints.
Sep 10, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Back line on back
Hi there. You aren't alone. I have included a lot of information here, much of which is from an authorized Canon tech.
During excessive printing, ink does not get absorbed into ink pads fast enough causing a build up of ink on the platen roller and the exit rollers.
Canon techs are instructed to replace the ink absorbers with a modified kit that includes a silicon tube, plastic joint, and mylar sheet. The shape of the waste ink pad has been changed to prevent the ink build up.
If you have a mind to do it yourself and your not under warranty you can purchase the blotter kits at beckscrs.com and I believe the part number is QY5-0146-000. You can download a user manual at www.alfons-servis.narod.ru.
I'm going to be real honest with you, though....it is a LOT less complicated, time-consuming and expensive to just buy a NEW printer.
I hope this helps. If not, let me know.
Jul 17, 2009 | Canon Pixma MP500 All-In-One InkJet...
Black Line down middle
The line is from ink coming up from the absorber pads on the bottom. It needs a good cleaning and a mylar sheet to keep the ink from coming up onto the rollers. A shop repair.
Jul 02, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Pages comes out with large black line running down page. I've tried cleaning it helps a little but I still have a black line.
If the large black line is on the back of the page, it is because too much ink is built up under the transport and transferring to the exit rollers. There is a mylar shield needed under the transport after cleaning the rollers to keep the ink from coming up again. Usually a shop repair, around $89.00
Jun 22, 2009 | Canon MP830 All-In-One Printer
Ink Roller Refill
Just flip it out and you can order one at office max. It just clicks right in...
Check this url out...
http://www.officedepot.com/a/browse/p200-dhiii/N=5+325133/;jsessionid=00003njCXd20m6tI7ltdY3TGmWw:13ddq0tng
They are reasonably priced too...
cmhimg
Feb 11, 2009 | Canon P200-DHIII Calculator
Changing Ink in the Canon P170-DH Printing Desk Top Calculator?
The manual for the Canon P170-DH calculator is found on the canon usa web site. It is 22 mg in size, but prints out to 4 pages in English, Spanish and French.
According to the manual: Use only Ink Roller CP-13.
There are four figures showing the steps, so you'll have to imagine it.
1. Turn power switch off.
2. Remove the printer cover (Figure1).
3. Hold the tab of the ink roller. Lift the ink roller out of the base (Figure2).
4. Insert the new ink roller into position. Push down on the center of the ink roller until it locks into place (Figure3).
5. Replace the printer cover (Figure4).
Print out the manual for yourself and put it in a safe place.
Nov 20, 2008 | Canon P170-DH Calculator
Wide black line down middle of paper
I have same problem, with new ink cartridge, also tried cleaning the print head, no luck.
Oct 20, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Canon P23-DH Calculator Logo
1,507 people viewed this question
old marine
old marine
