Question about Mitsubishi WS-55809 55" Rear Projection Television
Cannot adjust convergence on Mitsubishi RPTV
Not sure if I'm doing something wrong but I cannot adjust the convergence on my RPTV Anybody have tips or how to's on this?
  • 1 more comment
  • tntbenham Nov 28, 2008
    The picture is bowed almost like a fish bowl. It started doing this after I moved into my current house. Maybe I shook something loose???
    I had a cable guy out to install cable and he said it is adjustable but I cannot seem to figure it out. Is this true? If so do you have any info on how to adjust?
    If the resistors need to be replaced is there a how to or should I leave it to the experts. I work with low voltage electronics so I am pretty good with that kinda stuff just a little warry of breaking/damaging something else.
  • tntbenham Nov 29, 2008
    Wow that's alot of info. I do use a soldering iron occasionally and a multimeter pretty much every day. I'm gonna open the TV up and take a look to see if I feel comfortable enough to tackle it or not.
  • taurarious Jan 06, 2009
    i have almost the same problem except my convergence is only off on the blue lamp. the blue wont even move when in the convergence menu. i have just ignored the problem by simply turning the blue lamp almost all the way down> give sort of an antique lens look, but im getting sick of it.
  • 905 Answers
As long as there is no bowing in the picture and the color does not want to move then there is probably just a bad resistor on the convergence IC that controls the color alignment , thus the resistors would have to be tested to find the low valued resistor on the IC
Posted on Nov 28, 2008
  • jason Nov 28, 2008
    and this will be on the big heat sink with the amp chips labled STK & #'s , but if there are no bad resistors then the chips will have to be replaced
    well for sure the STK IC's will need replacing when the picture is bowed , here is an example of the STK's
    thanks for rating , but that hurts our rating as only a fixya helps
    Also if you cannot solder well and be able to determine resistor values and measurements with a multimeter , you will definatly have problems in try to fix the problem IC's
    still need any other assistance? i can help determine and how to , if you can do this repair
I have a Mitsubishi 70 inch model number VS70803 high definition I get sound but I ate my picture it has vertical and horizontal bars in a mix what is wrong with my set and can it be repaired
It's a RPTV and probably the convergence circuits have failed. There is a repair kit for this model you can google for it. Usually costs under $100 and takes a couple of hours of DIY time to do the repairs.
Feb 05, 2015 | Mitsubishi Televison & Video
Mitsubishi Rear Projection WS
5ebe434.jpg A projection television and a convergence control method thereof are provided. The projection television, which magnifies images displayed on cathode ray tubes (CRTs) for the colors red, green, and blue using lenses and projects the magnified images onto a screen, includes a convergence control apparatus capable of adjusting the convergence while an input image signal is displayed, the convergence control apparatus including: an image signal decoder which processes the input image signal to generate a data signal, horizontal and vertical synchronous signals, and a start signal indicating the start of either the horizontal or vertical synchronous signal; a convergence control unit which normally projects an image signal output from the image signal decoder onto the screen and performs convergence control using a predetermined region of the screen displaced from a visible region of the screen according to a convergence control command; and a main microcomputer which inputs the convergence control command to the convergence control unit when the start signal is input from the image signal decoder, stops the convergence control when a completion signal is input from the convergence control unit, and performs a control operation to continuously display the image signal during the convergence control.
the pro in convergence control circuit better change tat..
Sep 21, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi VS-50609 - Red convergence is way off, suddenly
You have a bad ground on a convergence IC. You will have to carefully pull this board out and resolder the pins. If this does not solve the problem you will have to replace the ICs. I have saved a few of these TVs with just a resolder job. Thanks for asking!
Jul 11, 2010 | Mitsubishi VS-50609 50" Rear Projection...
Tried to auto adjust the guns, will not come within range
Hi Tod,
If colors do not align correctly, most likely you have a convergence failure. This requires replacement of the 2 STK ICs and possibly some low ohm resistors.
Some Toshiba have a Horizontal oscillator/Drive IC failure that results in a small or shrunk picture (2-3" border on all sides). The 3 colors do not align properly because of the reduced Hor drive signal. The convergence adjust controls will work but not allow good adjustment. Convergence is ok, Hor Drive signal is incorrect.
Many do-it-yourselfers mistake the Hor Drive problem in Toshiba RPTV with convergence failure. Too much adjustment of the convergence controls may cause the saved data to be really messed up and require more difficult alignment in the service mode.
If minor or simple adjustments in the customer convergence adjust menu do not fix your problem, there is a fault. Stop adjusting until fault is repaired
Convergence failure can be accurately identified with the Convergence Gallery on our website. Service in Toronto, Ottawa, Calgary, Edmonton and other Canada cities.
Apr 21, 2010 | Toshiba 42H81 42" Rear Projection...
I have a Mitsubishi RPTV. Everything looks fine except for the blue colors look blurred. I have tried software convergence but the blue still looks blurred and strange. What can I do?
Dec 27, 2009 | Televison & Video
Mits 55908 Convergence problem
Good Day, John;
It sounds like the Convergence IC's have poor solder connections, by re-soldering the convergence output IC's should solve your problem. The IC's are large and mounted to large silver "heat sink" with STK 392 # on them. Good Luck, big IRISH.
Aug 29, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi ws48511 convergence problem
Your model uses one convergence IC its a STK392-110 you need to replace that IC. You can get a replacement at the following link with free instalation instructions with pictures so you can do the repaair yourself. Here's the link.
Jun 26, 2008 | Mitsubishi WS48511 48" Rear Projection...
Convergence problem
Hi there!
You would need the manual to adjust the convergence. First to correct the curving and then to line up the colours. Not too sure wether you need a service remote or the one that came with the set. If no adjustment takes place when you adjust, replace the Convergence Amp IC'S. Good luck,JUS004
Feb 28, 2008 | Mitsubishi VS-55707 TV
Red convergence, cannot adjust left to right
replaced convergence amp ic's
Jan 14, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Ghostly vertical lines
you have done said it vertical lines then you will have to take your tv to a tech for repairs.good luck.
May 13, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
176 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
