Question about Carrier Heating & Cooling
48DD0284 model I am wanting a part number for a Time delay relay. Dont know how to look up
    Novelist:
  • 124 Answers
Carrier time delay relay can be replaced by generic icm time delay 5 minute delay on break or a new digital stat that has a 5 min time delay built in. simply break the yellow wire through the low voltage at the condensor. usually a common and a yellow in and a yellow out are connected to the old relay. sometimes a red as well. the old relays needed power and a common all the time and a yellow in when contactor call is sent and a yellow out to the contactor after delay times out. new two wire delays only need power in and power out. they have a dial to adjust desired delay 0 to 5 minutes. good luck good luck
Posted on Dec 07, 2008
  • 61 Answers
I looked up information and the unit is obsolete. I also did not see a time delay in the diagram with the original unit. It must have been added later. Post me back and let me know where it goes and what numbers it has on it.
Posted on Dec 01, 2008
My bryant furnace fan will not turn on. Everything is sequencing, the induction fan starts and the flame lights, but the fan will not turn on. The capacitor reads 4.86 uf. Any suggestions?
Your fan delay relay is not functioning. On most furnace fan controls, there is a fan delay relay that delay the fan from turning on until it senses the temperature increase, typically around 130 degrees. once the relay senses the temperature increase it closes a contact inside the sensor and turns the blower on. It is the same device that keeps the fan running once the furnace turns off. Just take the Model number and serial number to your local dealer and get a fan delay relay and replace it.
Dec 07, 2014 | Bryant Heating & Cooling
I am wanting to energize a relay for 3 min. then off, whether the power stay's on to coil or not! what I want to do is when a door rises and hits a switch I want to energize a coil for 3 min. whether...
You want 3 minute 'off delay' timer.
When timer is energized with push button or momentary electrical signal, circuit remains ON for set amount of time, and then turns OFF.
http://waterheatertimer.org/How-to-wire-Dayton-Off-Delay-Timer.html
Aug 15, 2011 Dayton/ Grainger website is offline
Most delay timers have 1 amp capacity rating, so circuit needs fast acting 1 amp fuse, and timer controls separate relay or contactor unless Load is equal to 100 watt light bulb.
3-minute off delay pin timer
Omron shows 120Volt 8-pin M-series-(minute) 3 minute delay timer
Part number H3CR-H8L 120volt M
http://waterheatertimer.org/pdf/Omron-timers.pdf
Example 240Volt timer showing timer and base.
http://www.sourcingmap.com/ah33-220v-030-minutes-delay-timer-relay-socket-p-119441.html
Wiring diagram shows on side of timer.
Aug 15, 2011 | Amperite Dayton Solid State Timer On Delay...
I am looking for a multi function relay similar to the Dayton (1)6A855 but with a 240vac input not 120vac input. Can you assist please. Regards Bruce Peters
1) Dayton 6A855 time delay pin timer
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=dayton+6A855&op=search&Ntt=dayton+6A855&N=0&sst=subset
Grainger owns Dayton, so you might want to contact Grainger
http://www.grainger.com/Grainger/static/help_contactus.html
1-888-361-8649
2) Time delay timers at Grainger:
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=dayton+timer&op=search&Ntt=dayton+timer&N=0&sst=subset
3) Grainger shows time-delay 8-pin 120 or 240V
http://www.grainger.com/Grainger/DAYTON-Relay-1EJN7?Pid=search
Grainger shows 11-pin 120 or 240V
http://www.grainger.com/Grainger/DAYTON-Relay-1EJN6?Pid=search
Searching for "11 pin 240Volt delay timer" turned up results:
4) Following pdf shows knob-adjustable 240V delay-on pin timer
https://www.relayspec.com/specs/020050/T1Series.pdf
5) Signaline has delay timers (800) 862-2875
6) SSAC
http://www.ssac.com/standard/ff-tdr1.htm
7) Another pdf with 240V delay pin timers
http://www.askco.com/pdfs/tdd_tud_data.pdf
8) Not wanting to say what already know, but each 240V circuit is made from two out-of-phase 120V lines. Any 240Volt Load can be turned OFF by turning off one of the 120V lines. In this way, the Dayton 120V timer can be used to control 240V load.
Also the 120V Dayton can operate 120V double-pole contactor, and then the contactor controls 240V Load.
http://waterheatertimer.org/How-to-wire-Dayton-Off-Delay-Timer.html#contactor
Apr 04, 2011 | Amperite Dayton Solid State Timer On Delay...
I am in need of some advise. I have a pellet stove and need to replace an obselete part, I am wondering what would be the best delay relay timer to use, it will operate an 6rpm/150lb torque auger that goes...
1) Pex supply sell the E502 OFF delay Paragon product: Timing cycle begins when switch is activated, and shuts down at end of timing cycle. 5 seconds to 3 hours
http://www.pexsupply.com/Paragon-E502-Electronic-Off-Delay-Timer-5-sec-to-3-Hrs
http://www.grainger.com/Grainger/cycle-timers/timers/electrical/ecatalog/N-8hb
See manuals for Paragon product:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#percentage
2) Tork ACT120 cycle timer (minimum ON is 30 seconds)
http://www.grainger.com/Grainger/TORK-Adjustable-Cycle-Timer-4JNH8?Pid=search
http://www.nsi-sales.com/act_series.htm
See ACT manuals:
http://waterheatertimer.org/Tork-timers-and-manuals.html#cycle
3) Intermatic CT1000 cycle timer: cycle durations of 30 seconds to 30 minutes, with on-off durations from 1 minute to 29 minutes.
Click model number to access manual
http://www.intermatic.com/products/timers/mechanical%20time%20switches/percentage%20cycle%20timers.aspx
Drillspot sells indoor/outdoor 120V or 240V CT1000
http://www.drillspot.com/products/1325934/Cycle_Timer_CT1000_Cycle_Timer?s=1
4) Do a google search for 'electronic cycle timer' or 'percentage timer'
5) Timers listed above can be wired to a contactor (or relay) that turns on auger, if that's what project calls for.
Dayton off-delay timers require push-button operation
Feb 03, 2011 | Amperite Dayton Solid State Timer On Delay...
Kenmore 665 Ultra Wash FH141493
Hi daryano
I'm Harvey the Master Plumber
You want to know how to get the delay to work?
Most models work this way: Washing dishes the first time sets the favorites and the next time you start it the favs come on automatically provided you haven't changed the settings. So after the first use just hit delay and nothing else and when the dalay time is up it should work fine.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Aug 31, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
5 min time delay for central system blower unit not reset whe serviced
Make sure to turn off the furnace at the breaker or disconnect switch before attempting to touch the electronics of the furnace. Also look around the furnace for an owners manual. The manual will have the process for changing the blower off delay. I have given you a pretty generic process below. If you need more specific directions I will need your model and serial number. If your furnace is new enough I may be able to find your manual in our system. Good Luck:)
In most cases a circuit board model will have a small (1/4 inch x 1/8 inch) black, plastic jumper. I think I remember that some can be red also. Anyway This jumper is plugged on to two vertical prongs coming from the board. There are other bare prongs on either side of the jumper. If you look at the writing on the board you will see different numbers ranging from 60 to 190. These numbers represent seconds in time. You can change this jumper to match the seconds that you want for the blower off delay.
Jun 27, 2008 | Carrier 38CKC042 Air Conditioner
Protection of yamaha pc 2002
Protect delay is in the relay and not adjustable as to delay time.
I would not worry unless no sound then may have to replace relay.
GOOD LUCK
BIG RED
Feb 20, 2008 | Yamaha P2500S Amplifier
Number of rings
press *94, then press the number of rings you want 1-9. The tone will change and thats it.
Nov 29, 2007 | Siemens Gigaset S455 Cordless Phone
Heating & Cooling Logo
135 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
