Question about Sanyo STW0923H2 Thru-Wall/Window Air Conditioner
Electric Heater Coils Always On
I have a Sanyo through the wall heat pump unit. When I plug it in the heater coils start heating even with the dial in the off position. No matter where I turn the dial; heat,fan, or cool the heater coils stay on. The compressor seems to be working fine and the reverse switch seems to be working but with the electric heating coils on all the time of course all I get is heat. This is also very dangerous because as I said the coils stay on even with the fan off causing the unit to overheat and start smoking. Any help is sincerely appreciated.
We use the STW0925H! in 60 rooms on this property and have encountered similar problems that were caused by weldedd contacts on one of two relays that controls the electric strip heat. They can be replaced if needed.
PTHP's and PTACs employ thermal fuses as well as a bimetal limit stat on the heating element to limit risk if fan motor were to fail and the heating element were to remain energized. It would be wise to check that both are fuctioning properly while you are servicing the unit.
Posted on Mar 07, 2008
    Problem Solver:
  • 6 Answers
I suggest that the thermostat or the switch is at fault, contacts may be stuck. hope this helps
Posted on Mar 04, 2007
Should the fan come on the outside unit when the heater comes on?
If you have a heat pump unit then yes because the AC is working in reverse and makes heat from the outside unit. If you know you only have electric heat only then no.
Feb 11, 2015 | Heating & Cooling
Heat surge amish heater turns off and trips reset button
Do NOT use this unit as is!.
My experience is you have to pay to ship it for repairs and if out of warranty you should buy another heater. All electric heaters use the same power for the same heat unless its a heat pump, so save money and buy $30 WalMart heaters.
Nov 17, 2012 | Heating & Cooling
My sq inverter works on cold air but when changed to heat stops working
Some models don't use the compressor as a heat pump for heating. And only use electrical heating coils in the heat cycle.If yours is one of those. It may be a burned connection at the thermostat or at the heater coil. Heater coils may have a safety diode or fusible link that opens if the heater coil is on but there is not enough airflow. If that is the problem you will need to remove the bad heater coil and replace it.
If your unit is a "true" heat pump the change over valve could be stuck or it's coil burned out. If you know what it looks like you can measure the voltage at the coil. If you have voltage sometimes you can whack the valve with a screwdriver handle to "unstick" the valve.
Jul 11, 2012 | LG Heating & Cooling
Heat is always on either high or low never goes off for air only setting
if it's electric the heater could be shorted.one of the coils could be touching metal shorting it out,pull the heater out and check the coils for a break in them,next time send the brand name and model number.
Apr 30, 2011 | Dryers
Not generating heat and dosnt stop automatically
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101 ,..,
Apr 03, 2011 | GE Dryers
Dryer wont heat up. It runs fine but no heat. Replaced the Thermal fuse"flat white with 2 wire terminals.
gas or electric ok gas replace gas coils check glow bar ignighter,check thermostates,,,,,,electric check power to both sides of wall outlet you need 220 volts and it will start and timer will advance on 110 vts second check second fuse looks like a thermostate normally located at top of heater coil call if you need to http://www.washerwizzards.com
Dec 24, 2009 | Maytag Neptune MDE5500AY Electric Dryer
American standard thru-wall heater air conditioner (PTEC1501GAA) will not heat. When wall mounted thermostat is turned up for heat, the fan turns on but no heat comes out. I opened it up and checked the...
sounds as if the heater coil itself is burnt out. These coils may be repaired if you can get an universial coil repair kit and rewire the heater coil yourself. Since the age of the unit is in question I don't know if it is possible to get a kit for repairs but you never know. I would check an a/c supply house for this kit. Good Luck on your repairs
Dave
Nov 03, 2009 | Carrier 52PQ307 Wall/Window Air...
Heater not blowing hot air display says lo
when the coils freeze up , from intake of outside air, when using the heat pump mode, the unit will try to defrost the coils before going back to heat mode. mine did this alot. does it kick back to heat after a few mins? also after 2 years , mine started having issues with the exhaust blower control and would go into warp mode and bang noise.seems like common issues for this unit.whether the amana, or haier version.
Dec 13, 2008 | Amana Haier AP125HD Air Conditioner
No heat
The element above the fan has brobably gone bad. you can take the grill off of the wall and inspect the coils for breaks with a flashlight. if you do see a break in the coils then the heater is toast.
Oct 05, 2008 | Cadet Manufacturing 67508 Coil / Ribbon...
Electric wall mounted heater
Make sure that the heater is mounted where convection currents occur freely. When heat builds up around the top of the heater its temperature will rise uncontrollably. You'll be luck not to get a fire.
Jan 18, 2008 | Fahrenheat (FFH1614) Wall Mounted Panel...
Sanyo STW0923H2 Thru-Wall/Window Air Conditioner Logo
199 people viewed this question
Top Sanyo Heating & Cooling Experts
Dennis Boxerman
Fotis Papastamatiou
Darial Jr Lasaria
Darial Jr Lasaria
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
