Question about Gateway Computers & Internet
Ethernet card disabled - Gateway Computers & Internet
  • 120 Answers
If the above does not work, hold the windows key and press Pause|Break. Then go to device manager and enable the network card.
Posted on Nov 28, 2008
  • 1,879 Answers
Go to network connections then right-click on the Ethernet icon then choose enable
Network card disappeared overnite
Before adding any ethernet card, try to restore your system by using system restore option available with windows to a date on which your system was perfectly working. If the your system works fine after that, then it is quite likely to have your system infected by malicious software or anti virus. Scan your system for virus. If the ethernet is not working then add a new card after disabling the on-board network card in the CMOS setup.
Jan 01, 2012 | Dell OptiPlex GX620 PC Desktop
My dell xps 410 will not go online thru either of the ethernet ports on the computer. im using my phone with usb tether and it goes online fine. it says it need the ethernet controller driver but...
Hello, look at this link, you should have installed the bottom driver, but take care! if you've got a LAN card as well, you might have got the MOBO one disabled in bios, so best to take out the LAN card, find out what it is and look for a driver for it, meanwhile, with it removed, install the LAN driver for the MOBO LAN port, (bottom driver on this link ) and see if it appears in your 'Network Connections' (Check in bios to see if it's been disabled, though)
Regards, nicam49
The link: http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=DIM_PNT_9200_XPS_410&os=WW1&osl=en&catid=&impid=
Aug 22, 2011 | Dell XPS 410 PC Desktop
Not able to get an IP from the network when connecting thru the Targus docking station model ( APC51US) i am on windows 7. note that i am using the same cable adn it work fine when i connect it to the...
In order to use the ethernet card on your Docking Station ( or Port Replicator), you must first disable any internal Ethernet cards.
To do this:
  1. Type "Network Connections" in the Start Menu seach box, and press enter.
  2. Right click on your computer's internal ethernet adapter (i.e. "Local Area Connection" & select "Disable"
Ref: Targus Support
Apr 19, 2011 | Targus Port Replicator, Docking Station,...
My desktop won't connect to internet. I have repaced ethernet card but both cards read cable unplugged I have tried every settting,configuration and troubleshooting technic I know. I'm running windows XP...
Bad ethernet cable? do you have another one? in device manager it shows that cards are working properly? since same with two cards have to wonder about cable or router
Sep 02, 2010 | Sony VAIO Digital Studio PCV-RX550 PC...
Replacing ethernet PCI card 10/100 by gibabit 1000
When you replace and install LAN card you need to install also the driver. Be sure that your onboard ethernet PCI card are disabled in BIOS. So that the new install LAN card are working.
Regards
PCmania
Sep 26, 2009 | Dell Ethernet Card Network Adapter
How to replace ethernet card on hp pavilion a706n, it looks like it is built in to the motherboard, can I just buy a replacement and put in one of the empty slots??
It is buillt in however if you have a spare PCI slot on the motherboard you could fit another ethernet card which would override the built in one.
Sep 14, 2009 | HP Pavilion a706n PC Desktop
Need to know jumper settings to disable onboard ethernet i have installed a ethernet card but i cant get them to not have conflicts
You probably just need to go into the bios setup to disable the on-board controller. If it is a dell, you usually just hit F2 when booting up to access the setup screen.
May 05, 2009 | Computers & Internet
The onboard ethernet card just stopped working. There is no fix I can find. I reinstalled windows and the drivers. once you instal the driver it only will start in safe mode.
Reboot your PC and hit F10 or F2 or any key it shows on your screen and go into BIOS setup and there should have one entry you can disable the onboard ethernet card.
Apr 25, 2009 | ASUSTeK P5K Desktop Board - Core 2 Extreme...
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
