Question about Whirlpool Refrigerators
Bottom of refrigerator sudenly emit a burning smell near compressor. remove dust. clicking sound on off at short intervals. compressor running on off. smell seem to die down. what's the problem. my rf is whirlpool side by side model# ED5VHGXMQ00
    Sergeant:
    Champion:
  • 311 Answers
Relay burned up. Replace it. Compressor will not run until you do so, so unplug ref. I cannot see your reply due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Posted on Nov 29, 2008
How do I get rid of awful odor coming from bottom of fridge when compressor running
the coils on the bottom are dirty blow out with air and vacuum. you will have to pull out Ice box and clean from back.
Aug 18, 2014 | Frigidaire : FFHT1715LW Top Freezer 16.5...
Refrigerator made a growling/rumbling sound & emitted a smell similar to sulfur, but exactly like a cap gun. Still cooling fine but fan at compressor not running.
sounds like the relay on the compressor has shorted, they are quite easy to replace but un plug the fridge of course. there is a black plastic cover on the side of the comp. the relay just pulls off, if it rattles when you shake it then thats your problem, it's a cheap part.
Dec 02, 2013 | Whirlpool Refrigerators
Sears 253 freezer compressor wont run
next time send the model number.if the compressor isn't running check the start device located on the side of compressor.the easiest way to check it is to remove it from the compressor and shake it,if you hear pieces rattling around inside it the start device is bad.unplug the machine,remove the back bottom panel,with a screw driver or needlenose plyers remove the metal clip on the device,remove the cover and slide the device backwards,it slides into three pins on the compressor,when you slide it off just shake it or check it with a meter,you might of smelled something burning or the compressor might make a clicking sound like every three minutes.if it's an older machine it could have a timer in it that's stuck or a bad cold control this is why you should send the model number,most likely it will be the start device.good luck and when you get it running change out the gasket
Aug 27, 2012 | Refrigerators
My bottom freezer refrig. Kenmore 596.72214200 - suddenly smelled weird burning smell from back of frig., hear occasional clicking sounds. Everything seems to be working. Smell seems to happen when...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 31, 2011 | Whirlpool Refrigerators
The light is on but the refrigerator isn't working at all.
you need to send the full model number,it's in the fridge section up near the ceiling,you'll see a tag with model and serial numbers,is the compressor running or is it clicking every couple of minutes.if so the start device is probably cooked.unplug the fridge so you don't burn off the pins on the compressor where the start device slides onto.remove the back bottom cover,find the compressor and you'll see a clip,remove it and slide the cover off and then slide off the start device,shake it,you'll hear pieces rattling around inside it and also it will smell burnt.call your parts store,give them the model number and they'll give you the correct device.let me know what you find
Apr 21, 2010 | Kenmore 63222 / 63224 Bottom Freezer...
Burning Rubber smell coming from fridge
try taking the bottom panel off and vacuming all the dust on the coils. The dust may be heating up and burning. The coils are usually at the bottom of the fridge. Check to see if the fan is running also.
Jan 16, 2009 | Refrigerators
Arking and noisey compressor startup. can smell a burning odor after restart
sounds like a bad overload relay assy for your compressor, its attached to the side of our compressor assy if that is what making the noise heres the part number 12002784. but if its burnig and arcing enought o ruin the compressor terminals you may need a new compressor, and depending on when purchased may or may not be covered. new overload relay comes with new compressor if needed
Oct 26, 2008 | Maytag MSD2756G Side by Side Refrigerator
Not freezing or cooling
There should be a small relay switch near the compressor. Sometimes dust or (ugh) a bug may get in there and block the relay from starting the compressor.
Sep 28, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerator burning rubber smell when it tries to turn on
sounds like the relay on the compressors is getting hot and cutting the unit out, if the fridge is quite old it may well be the run windings gone short circuit in the compressor pot. The relay switches from start to run windings so may be firing the start circuit, switching over to a shorted run winding, and then getting hot and activating the thermal cutout and hence the burnig smell, plus the start and rapid shut down of the compressor.
Mar 19, 2008 | Refrigerators
Refrigerators Logo
301 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
