Question about Altec Lansing ACS 295 Computer Speakers
My Altec Lansing
My speakers were working fine and then one day I tried to play some music and there was no sound coming out. The computer sent a message that said there is an audio problem there is no device installed or there is a problem with the speakers
    Brigadier General:
  • 6,966 Answers
Hi, I would suggest that you should check into your computer rather than your speakers. Specifically your sound card and its drivers. Try going to your Device Manager and check your Sound, Video and Game Controllers. There should not be any Yellow markings anywhere. Cheers
Posted on Apr 08, 2007
Static coming from speakers
Not much information here but I will try my best, could be a problem with the cable your using between the speakers and the mp3 player, you could have a dry joint, if it's like a "hum" sound your getting it's a bad ground, without the mp3 playing plugged in tap the end of the stereo minijack cable with the speakers turned up? hear the 50hz buzz - if the interference sounds the same it's most likely a bad cable or bad connector on the speakers. I would need to either hear the interference to determine what fault it is or if you can describe it better i.e. what it sounds like.
Mar 31, 2014 | Altec Lansing Multimedia Computer Speakers
No sound out of my Altec Lansing ADA 745. Computer Sound card is fine.
If other speakers are working, then 745 is defective or the volume switch is set to mute. Please check that, repair it if required.
Aug 27, 2012 | Altec Lansing Technologies Audio Players &...
Altec Lansing GT5051, I'm hearing a humming noise from the speakers as soon as I turn them on. The humming noise is heard even if speakers are not connected to source.If I try and play music with...
Sounds like a problem in the speakers' internal power supply, maybe a faulty capacitor. Speakers need to be looked at by a technician, or replaced with a new set.
Jun 05, 2011 | Altec Lansing GT5051 Computer Speakers
Only one speaker works - altec lansing computer speakers ADA215
The solution is actually quite simple, due to a design flaw. Altec lansing designed a rather cheap mini din plug-in which can either be replaced or repaired depending on your skill and patience level. Your ground contact is fine BUT the positive contact is not making connection due to the fact that the plastic housing has broken away and pulled the contact with it. This can be super glued back into place or just replaced with a new mono minidin plug-in.
Mar 09, 2010 | Altec Lansing ADA 215 Computer Speakers
Problem with Altec Lansing ADA 885 Computer
check u have the lastest sound driver.or u can try uninstalling it and run driver cleaner then try reinstalling driver.if u are using vista u may have to go to audio devices and set from there.also try air the input plug whole just incase dust has settle there. hope this helps.
dt
Dec 06, 2009 | Altec Lansing ADA 885 Computer Speakers
Altec Lansing VS 4121
It is unlikely that this is a problem with your speakers more likely that it is a problem with the DVD player itself. I would recomend trying another DVD player.
Regards, Andrew
Sep 17, 2008 | Altec Lansing VS4121 Speaker
No sound
check the plug that goes directly to the altec box. or it could be the wire is the culprit..
Apr 08, 2008 | Altec Lansing VS4121 Computer Speakers
One speaker not working
jjohnmith
First things first:
1) check your speaker for good connector, and all is working is playing fine.
2) check if your warranty covers one SPK. or RMS
other than that ,
Good Luck
Feb 01, 2008 | Altec Lansing VS2121 Computer Speakers
My iPod stopped playing through speakers- but only at work...
Esmurfette
First things First!
1) check on other speakers to see if your iPod work fine
2) check connector for loosing electric connectivity.
3) check with your headphones to see if your iPod play music well.
4) Check, power on the computer spk. you got. or the input that is working right.
Good Luck
Jan 29, 2008 | Apple Logitech Inc MM50 Portable Speakers...
Surround wont work
try and download sound softwares from majorgeeks.com.
hope this works.
Jan 05, 2008 | Altec Lansing VS3251 Speaker
204 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
