Please help me fix " Bootmgr is compressed " problem in Panasonic CF-52 .....Where is the safe mode? I don't know the function of the keyboard's keys ...... Can't press F8 like normal laptop to go to the safe mode T_T
You will need a operatingsystem disk or a repair disk to fix it. Insert it in the drive then bootfrom it. You want to get to a dos command prompt (black screen with whitelettering) and type the following commands. Press ENTER after eachcommand.
bootrec.exe /fixmbr
bootrec.exe /fixboot
bootrec.exe /rebuildbcd
Reboot and see if the problem is solved. If not get back to the doscommand prompt and run the check disk utility.Torun the check disk utility you will need a repair disc or a operating systemdisc. Put the disc in the cd drive and boot from it. You want toget to the Dos Command Prompt (Black screen with white letters) and type thefollowing command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
SOURCE: keyboard lights on CF-52
To Control Keyboard lights on CF-52
FN - Up Arrow
or
FN - Down Arrow
SOURCE: my toshiba p205d s7438 bootmgr is compressed
1.Insert the Windows XP CD-ROM into the CD drive, and then restart the computer.
2.Click to select any options that are required to start the computer from the CD drive if you are prompted.
3.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
4.Press 1 (One) to select windows XP and then hit enter.
5.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
6.At the command prompt, Type
compact /U C:\bootmgr
compact /U C:\ntldr
BOOTMGR IS COMPRESSED
Press Ctrl+Alt+Delete to Restart
1. After rebooting with OS DVD, choose "Repair your Computer" and then select "Startup Repair". Reboot your computer.
2. After rebooting, click on "Load drivers" button an explorer style window will pop up, go ahead and right click on the drive that may have been compressed and deselect `Compress this Drive'. Choose apply and then apply to subfolders/files before rebooting.
There are registry commands also that can be used. But the above 2 steps can be very helpful to start with.
