Question about Viking VDSC365-6B Dual Fuel (Electric and Gas) Kitchen Range
The oven door on my Whirlpool oven won't stay closed
The oven door on my Whirlpool oven, model RBS305PD, won't stay closed.
  • 1 more comment
  • heymate Dec 04, 2008
    I think my son "stretched" the hinges by banging the door down too forcefully. I beleive the hinges and springs need replacing....How does one do this?? Thanks
    Me too. It seems to be "stretched". I think my son has been forcfully openning the door. How does one put new hinges and or springs. The iven still works but their is definate "play" when the door is in the closed position. Thanks Heymate
  • michaelbgm Dec 06, 2008
    Hi, I have a Billing oven type evp 423244m, model - 295ss, and the door dosnt close fully. any help would be appreciated.
    Thanks , Michael
    Sergeant:
    Champion:
  • 311 Answers
Need new hinges. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Posted on Nov 28, 2008
Whirlpool electric oven won't heat just barely
Hello & Welcome to FixYa
This indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then test the door switch. Please get back to me if you have any other questions.
Kevin
Jun 09, 2011 | Whirlpool RBS305PD Electric Single Oven
Oven door does not stay closed tight enough to keep light off or to keep open door light on heating
Sorry to read about your problem, I hope this helps you out.
you have a spring/hinge problem. or a small chance, your door seal is defective.
you may try to remove the door and re-seat it...
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 26, 2010 | Whirlpool RBS305PD Electric Single Oven
My oven light will not go out, can you help?
Have you checked your door switch to be sure it's hitting the closed option? Most of the time that t the problem. Make sure your door is aligned properly. If this does not correct the problem, please contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
We hope this solves your problem!
Nov 06, 2009 | Whirlpool RBS305PD Electric Single Oven
I can't remove the door on a whirlpool oven model RBS305PDB
I removed the oven door without putting in the door removal pins that I was supposed to use. Now I can't put the door back on.
Oct 22, 2009 | Whirlpool RBS305PD Electric Single Oven
How to remove door for whirlpool oven RBS305PDB2
open the door about 1/3 of the way and lift it off the hinge pins. it helps to have two people do this. when it is time to replace it, put the hinges in that 1/3 open position and slide the door back down on.
Oct 02, 2009 | Whirlpool RBS305PD Electric Single Oven
Daughter stood on door, now it won't fully close (the light stays on). Can I/how do I tighten the hinges? Thanks
Put a broom handle between the door and frame down near the hinge. Close the door on the handle tweaking it to where it will shut all propah. my friend. Good question you should run it by the pros at appliancejunk.com or fixitnow.com
Aug 29, 2009 | Whirlpool RBS305PD Electric Single Oven
Sounds like the door hinge springs are weak, it will probably be neccessary to replace them both.
Please leave feedbck
Dec 06, 2008 | Ovens
Oven door won't close tightly
Sounds like whoever installed your oven hasn't adjusted your door properly and as a result over time probley got worse? any way there should be 3 screws on each hinge the top and bottom screws hold the door in place the screws under the top ones are used for making adjustment with a Philips head screw driver open the door and try screwing in clockwise 2 or 3 full turns and with your free hand feel if the door is moving upward if so repeat the same on the other side and then close the door and see if its made a difference if so and its still loose try again if its made it worse the turn the screws in the opposite direction Let me know if this works
Dec 09, 2017 | Whirlpool RBS305PD Electric Single Oven
Viking VDSC365-6B Dual Fuel (Electric and Gas) Kitchen Range Logo
185 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
