Question about RCA P52921 52" Rear Projection Television
56" RCA projection TV (FLYBACK related problem)
Hello! I just replaced the FLYBACK transformer on my 56' RCA rear projection TV model P52921 (Flyback part # 239111, Chassis CTC195M). The HOT was not replaced and I believe the new FLYBACK is not an original part. Anyhow, after replacement the TV powered up and initially the picture looked fine. However, everytime the unit is powered up there is a hissing noise coming from the back that lasted for 3-4 seconds then it disappears. The TV worked well with the exception of the noise and a slight blurr at the very right edge of the screen. The TV worked in that manner for about 7 days until today it did not power up as it did before replacing the FLYBACK. Without any testing and with those two clues (the noise and picture blurr) can someone help me understand what might the problem be? It could be anyone of these: The new FLYBACK, the HOT blew, Driver and HOT base circuit components, the LV regulator, or maybe bad soldering to the new FLYBACK. Any good ideas? Thanks
  • 6 more comments
  • Haitham Moaty Jan 16, 2007
    I made sure that the FLYBACK has the correct part # number (239111). Can the hissing nise possibly come from the HOT?
    No it not an original part but a replacement for the original FLYBACK part # 239111. I bought it from a retailer based in Orlando Florida called ACME Enterprises.
    The only physical defect I can see on the new FLYBACK is the beginning of a dark spot at the top of the transformer (Looks like a burnt spot).
    maybe a ring test first to rule out the FLYBACK? except I don't know how to perform one, maybe you can direct me to a good tutorial link to understand the ring test?
    Also, how can I test the HOT? is there a specific resistance that I should get across it? Could the HOT possibly cause the HV leakage from the FLYBACK?
    I thought that the FLYBACK usually takes the HOT out with it but I am not sure if the HOT can also affect the FLYBACK causing it to have a leakge and make a hissing noise.
    You guys are outstanding!! thank you very much for the valiable information!
    My last question relates to the hissing noise and the flyback possibly going out after 7 days of operation. Can a bad HOT by any chance cuase the flyback to have a HV leak and make a hissing noise?
  • Haitham Moaty Jan 17, 2007
    so is the horizontal output drive same as the HOT?
    Ok what would solve the problem is for me to know both the location numbers and part numbers for those two HOTs (the horizontal output transistor and trnasformer). If you can provide me with this information I will be very thankful!
    I will assume that the horizontal drive transformer is the same as the horizontal output transformer (please correct me if I am wrong), thanks!
    I see, that makes things clear. Can you provide me with their part number or at least tell how to obtian them form a web based database? thank you very much!!
    Scholar:
  • 119 Answers
The base to emitter of the hot will read short on a diode checker/test on ohms it vairies but typically about 50 ohms.e to c, or b to c should have very high resistance. unsolder the collector of the hot. make sure all solder is gone. now test the ohm between your tuner ground & the pad of the hot collector it should read open.
Posted on Jan 16, 2007
  • kevin letteney Jan 16, 2007
    the hot could go bad by itself & not affect the flyback. but if the flyback goes bad i have often found the hot bad as well.
    Scholar:
  • 168 Answers
Well usually the hissing sound comes from a leaky flyback. maybe the one u bought for the replacement did work for a while but gave up suddenly. this part should be replace by the same specs, otherwise it might create another problem.
  • 3 more comments
  • Noel Andres
    Noel Andres Jan 16, 2007
    no. HOT doesnt emit a noise like this. remember flyback is shielded and coated, any leak will produce a noise like this. try to inspect if theres any physical defect on the flyback. did u bought the flyback in RCA?
  • Noel Andres
    try to look also at the horizontal deflection circuits (hor. oscillator, pre-drive, drive ckts.) and possibly power supply circuits
  • Noel Andres
    Horizontal output transistor usually has a damper diode across C and E and a bias resistor included between E and B. these internal components alter one's expected ohmmeter test of H transistor; here's how. the base to collector junction will test as a diode, but E to B will show a low resistance, approx. 50 ohms in both directions. now the E to C ohmmeter test will test as a diode. the foregoing results indicate a good transistor. readings other than these indicate a bad H output transistor.
  • Noel Andres
    Noel Andres Jan 17, 2007
    there's another HOT which is the horizontal output transformer. wherein the hor out transistor output is connected.
    hor driver is before the hor out transistor so, its a dirrent thing.
  • Noel Andres
    horizontal driver is not a transformer, its a transistor connected directly to the hor. output transformer then to the horizontal output transistor then to the flyback.
W to replace the flyback transformer on an RCA rear projection tv
Go to www.tvrepairworld.com you need the 270125 flyback kit listed under the RCA repair kits. The flybackk comes with the CD with step by step instructions.
Apr 06, 2010 | Televison & Video
I have a 56 inch rca that blinks three timeswith a humming noise but wont turn on
The 3 blinks (an error code) and the hum (most likely from the flyback) indicate that the flyback transformer is bad and needs to be replaced as the simple way of putting it (fairly common problem with projection tvs). If you plan on doing it yourself, then you should have some electrical expertise since working in a projection tv like this can be very dangerous otherwise I would go through the local shop. Let me know how this turns out for you.
Benjamin
Jul 18, 2009 | RCA D56W20 56" Rear Projection Television
RCA D52W26 rear projection. 2 years old. 3 times and powers out.
Try replacing CP150, CP114 and CP120 first cost about 12.00 with free instructions available at the following link under the RCA parts category
http://servicemanuals.vstore.ca/
Feb 10, 2009 | RCA P56923BL 56" Rear Projection...
Convergence problem
If the convergence is out on that set you most likely do not need to make an adjustment the circuit will need to be repaired. There is a stk on the convergence amp board that needs to be replaced. A good tv shop will run you somewhere between $300-$500 to do the repair
Oct 28, 2008 | RCA P56923BL 56" Rear Projection...
RCA P52937 Flyback Transformer question
The lead going from the flyback to that other device is a voltage divider or splitter as they're incorrectly referred to... To remove the leads press down firmly, twist and then pull up...
Bill
Nov 21, 2007 | RCA P52937 52" Rear Projection Television
60 inch rca dead set
2 things cause this high voltage trippler or your flyback transformer.
May 31, 2007 | RCA P52921 52" Rear Projection Television
Big mistake
what was the origonal symptom before replacing the flyback? You could try using epoxy on the wire get a nice size glob of it on there where the wire got cut.
Jan 17, 2007 | RCA P52921 52" Rear Projection Television
High Voltage leakage
Yes Flyback Transformer can have a small pin hole leaking out high voltage.or it may be cracked.
If you can find the horizontal output transistor which is located near the flyback transformer,one lead of this drive transformer is connected to the base lead. (horizontal output transistor). There may be a little coil in series with this lead going to the transistor.
RCA P52921 52" Rear Projection Television Logo
522 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
