Question about Whirlpool Dryers
My whirlpool clothes dryer will not start.
It is an older model #le6880xsw1 front loading electric clothes dryer.
After setting the timer, I can faintly hear the timer running. When I hit the start button nothing happens.
Also while trying to figure out how the dryer might be assembled I put the dryer on its side. when I sat it upright again, I heard little things falling.
Can you help me trouble shoot this dryer? I put a new belt on myself last year, but forgot how I got the thing apart.
Where can I find a manual for this on line?
I appreciate your help on this.
Rick
  • bennettco1 Nov 29, 2008
    Thanks for your help. After I figured out what I was looking for, I found a broken door clossed switch. I original thought the door closed switch was some how part of the latch that secures the door closed.
    This should be an easy fix now.
  • 706 Answers
Hello Rick,
Use this link to get information for your dryer.. it should provide you with everything you need. Get back to me if you are still having problems..
http://www.pcappliancerepair.com/model-display.php
Regards,
Rick
Posted on Nov 28, 2008
I am a retired ref. tech with only a little experience with dryers. I need a 696321 thermal switch for my Whirlpool LE6880XSW1 dryer. It is NLA from Whirlpool. Can I bypass it? If so, how?
No, it is very dangerous. It is there to protect from fire. If you were found to have bypassed a safety device, you would become liable in law.
Buy it from one of the other suppliers. You can even buy from Amazon. One of the parts suppliers would know what switch would work from a different make. They are pretty generic.
Whirlpool LE6880XSW1 dryer parts Google Search
Jan 12, 2018 | Whirlpool Dryers
I have a whirlpool duet model gew9250pw1 dryer it gets good and hot put when the cycle is done some of the clothes are still damp.i not sure if it is the timer or a censer. i know when we start it the...
Look for an airflow blockage. Be sure lint filter is cleaned and if lint is accumulated in the air stream path, take a vacuum or brush and clean it out. Dirt and lint are a dryer's worst enemy.
Mar 17, 2013 | Whirlpool Duet GHW9150P Front Load Washer
We have a whirlpool duet front load dryer, why does it beep during a cycle?? when clothes are still wet?
You can perform some Whirlpool electric dryer timer troubleshooting to determine if the timer is faulty or if the cause is somewhere else within the dryer.
  1. Access the Timer
    • Unplug the Whirlpool dryer power cord from the dryer electrical outlet. The timer is inside the control panel on the top of the dryer. Pull the dryer away from the back wall so that the control console can be raised without hitting the wall.
      Remove the single screw on each end of the control console that secures the control console housing to the top of the dryer. Grab the sides of the control console and raise the front of the console up and toward the rear of the dryer. With the control console in the service position you will now be able to test the timer.
    Test the Timer
    • Locate the dryer timer inside the control console. It will be directly behind the dryer timer control knob. There are two wires that connect from the dryer to the dryer timer. Place a piece of masking tape on each wire and write on the tape what terminal each wire attaches. Use a pair of needle nose pliers to remove the wires from the terminal ends on the timer.
      Set the scale on a volt-ohm meter to the RX1 setting to measure the ohms of the timer. Place one probe to one terminal and the other probe to the remaining terminal. You should get a reading between 2,000 ohms and 3,000 ohms. If you do not get this reading, replace the timer.
    Replacing the Timer
    • Pull the control knob off of the timer shaft on the face of the control console. Remove the two screws that secure the timer to the inside of the control console. Pull the timer out and take the timer with you to an appliance repair facility. Compare the new timer to the old timer to make sure that the mounting screws match.
      Place the new timer inside the console and secure the timer with the two retaining screws. Attach the wires to the timer and remove the masking tape from the wires. Lower the control console and reattach the console to the top of the dryer with the retaining screws. Push the control knob back over the timer shaft. Push the dryer back against the wall and plug the power cord back into the electrical outlet.
May 21, 2011 | Whirlpool Duet Steam WFW9700V Front Load...
My dryer timer counts down to 7 minutes and then continues drying
replace the sensa board and make sure the wires on the sensors are ok
Jun 07, 2010 | Whirlpool GEW9250 Electric Dryer
Intermittent high-pitched noise during drying cycle
It is probably the drum bearing going bad and yes it is okay to use but will probably sart clunking when it wheres out all the way.
Mar 11, 2010 | Dryers
Dryer wont start when start button is pressed, but humming sound
I'd sure start by making sure the belt isn't broken. You can usually see the belt with a flashlight after accessing the panel (some are in front, others in the rear) - don't go probing around bare armed without unplugging the unit....
Jun 20, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool Electric Dryer
More than likely the belt for the drum or the door switch is faulty. What is the model of your whirpool?
Mar 05, 2008 | Dryers
Open Questions:
Dryers Logo
286 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
