Question about Whirlpool GEW9200L Electric Dryer
GEW9200LWO won't start-sensing lite on.
Troubleshot unit completely. After tests manual say's replace machine control electronics. replaced contol eletronics issue still the same,no start. When I checked the motor circuit it calls for 2.4.-3.6 ohm on the main and 2.4-3.8 on the start. I had 1.8 on both main and start. this is the only difference I had while toubleshooting.
  • hunter862 Nov 28, 2008
    As I stated,every other system check was completed without as issue.
    Sergeant:
    Champion:
  • 311 Answers
Did you check the thermal fuse? I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Posted on Nov 28, 2008
Green power light only on trevi exclusive
When power is turned on, the coffee selection button should blink during warming up. If it is not blinking then the following i possible:
1- The electronic sensor is bad. It is clamp mounted on the boiler to sense temperature and send message to control board to turn the heating off when it is ready to make espresso. The blinking light will be fixed to display this.
2- The heating element on the boiler is bad and not heating. The electronic sensor cannot relay any temperature as it is.not sensing the heating.
3- The electronic control board is bad and not sensing the temperature.
The machine should be opened up to test the sensor or the neating elements, and replace what is bad..
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Aug 31, 2014 | Spidem Trevi Automatic Espresso Machine
Dryer doesn't stop when door is opened and light does not work (new bulb)
see the next steps and proceed with common sense: God bless you
If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. To determine if the lid switch has failed, watch the part testing video at the bottom of this page. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse
Aug 01, 2012 | LG Tromm Electric Dryer
99 suzuki vitara stalls out all the time engine lite comes on. Now it won't start. Almost like it is not getting any gas.
The information below was complied by me, it explains what causes the check engine light to come on and the process of finding the cause.
When the Check Engine light (or Service Engine Soon or small picture of an engine) is turned on, the systems computer control unit (called the PCM) has sensed a fault in the electronic controls of the engine and/or the emission system. When this happens you will seldom feel the car engine run any different. There are about 200 possible system faults (the gas cap is just one of them) that turn the Check Engine light on, to know what has developed a problem you must have the system tested
Oct 14, 2011 | 1999 Suzuki Vitara
After wash cycle in complete, the door stay locked, and displays the code e22
Hi.
E22 is usually a control board failure. The drain pump must also be tested.
The manual says:
Triac sensing circuit for the pump faulty.Possible fault = Electronic board faulty.
Control board and pump must be tested.
Regards.
Ginko
Sep 13, 2011 | Zanussi IZ12 Front Load Washer
Kenmore oasis washer model #110.27062600 starts to fill then stops. Filling with F1 code.
Hi
It's a communication problem between the central control unit and the electronic control box."F1" error code means "Primary control failure" and suggested correction is to replace the machine/motor control assembly. If you use a screw driver in front of the machine to open the top you will find a repair manual on the inside of the front panel.
There are three long screws behind the control unit "hood", in the back-top of the washer, facing straight up and down. After unscrewing,lift the hood up and forward to find the electronic control. First, you should check all the wires and make sure the connections are ok. If that still doesn't fix it, unplug all the wires, and take the electronic control out by unscrewing one 1/4" bolt. Put the new one in and re-wire everything (it shows what wires go where on the electronic control box
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 04, 2011 | Kenmore Washing Machines
I cannot get the washer to run completely through ANY cycle. it stops and flashes F-1 and other flashing areas. The door gets locked and clothes are trapped in the washer. How do I try and fix this problem...
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Nov 05, 2010 | Kenmore HE2 Plus Front Load Washer
82822 / 82824 / 82826 Electric Dryer: kenmore HE2 electric dryer, beeps and all display ...
May 17, 2010 | Kenmore 82822 Electric Dryer
Model GEW9200LWO control lock light
Even tho the door lock light is working the switch has dropped a leg supplying power to the rest of the machine. Repace the door switch and you should be good to go. Even tho you have a GE it was made by frigidaire for GE. Common problem with the newer switches. They have gone back to the originals as the replacement for this.
Feb 01, 2010 | Whirlpool ET8CHEXSQ Dryer
My Kenmore Elite front loader dryer dispalys error code CF 01.
CF01 - There may be an internal problem with the control, attempt a Hard Reset.
Mar 13, 2009 | Kenmore Elite HE4 Electric Dryer
DD603 2 Drawer Flashing Fill Warning
poss water valve b4 i would consider a control
Mar 04, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Whirlpool GEW9200L Electric Dryer Logo
169 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
