Question about KitchenAid KITCHEN AID 5 Quart Artisan Series Stand Mixer
Can't remove beater from mixer...
Hi...would appreciate it...so much...if anyone can tell me how to get a stuck beater out of the mixer...soooo stuck...I ask everyone that comes over to try and get it out...no luck!
  • mzecharia Dec 07, 2008
    I have the same problem. My stand mixer is a year old. Now suddenly the wire whip is stuck and can't remove it to wash. It still works but I have to clean it without pulling out the wire beater, which is very inconvenient.
I took the advice from: http://forum.kitchenaid.com/forums/topic.asp?TOPIC_ID=6356
I put a wash cloth in a pot of boiling water and used tongs to wrap it around the beater shaft while the mixer was resting on its side. When the wash cloth was not too hot to touch, I put it back in the boiling water and did it again. I was then able to easily remove the beater.
Posted on Dec 13, 2009
  • 118 Answers
I would suspect that it has become stuck on the shaft. It depends on what is sticking to what you should use. If it is some sort of food, then soaking it for a while (20-30 mins) with fantastic would loosen it. If its seems to be dry welded, then I'd use something more like liquid wrench (automotive section). Just remember that the locking mechanism requires that you push the beater up, then turn, then pull. so look at the exposed portoin of the beater and see if you can tell what part of the j-channel the pin is located will tell you which way it needs to be moved. I would be not afraid to tap it will a soft mallet (wood or plastic) but not with anything too hard (steel).
Posted on Nov 30, 2008
WD40
Posted on Feb 16, 2009
Im tryin to find replacmet beaters for my mixer and everyone doesnt sell them where do i find them... Model numb is 23869239
That may be a Kenmore part if so Sears can replace the parts. Can't help anymore with out a little more info on the Makeer of the mixer
Sep 24, 2014 | Food Mixers
Blade is stuck in shaft of kitchen aid
Get some CRC around the shaft and into the beater hole and wriggle it about until it comes free. Rasp the build up in the beater hole out with a round file and clean up the shaft on the mixer. Remember you are cleaning out the hole not trying to make it bigger than it was. In my experience it is a build up of flour in there bonding itself to the hole in the aluminium beater.
Aug 31, 2014 | KitchenAid KITCHEN AID 5 Quart Artisan...
Beater is stuck
I had this happen on my Kitchen Aid mixer. There is probably a build up of dough/cake mix etc inside the hole where the beater fits into. Fill a mixing bowl or a jug deep enough to fit over beater with very hot or boiling water. Immerse the stuck beater in the water up to where it connects in to the mixer and hold for about minute. Once the hot water has melted the build up you should be able to remove the beater. Hopefully this may work on your brand of mixer.
Apr 14, 2014 | Blakeslee DD-60 Stand Mixer
I have kitchen aid stand mixer and i can't get the beater to attach because the button is stuck??
The button doesn't move. You must push the beater up beyond th notch and turn it while pushing up.
Jan 14, 2013 | KitchenAid KITCHEN AID 5 Quart Artisan...
One of my blades is stuck and I can't engage the release
Make sure your Beater can slip in and out of the Beater Shaft
easily. Do not force the beater onto the Shaft if the shaft is bent.
If it cannot be removed easily by hand, use a soft rubber mallet
(not a steel hammer) to slightly tap the beater so it can be moved
up and down the shaft or from side to side. Then you can easily
turn the beater left and remove it from the shaft.
From Kitchenaid Manual:
To Attach Flat Beater, Wire Whip, or Dough Hook
1. Turn speed control to OFF.
2. Unplug stand mixer or disconnect power.
3. Tilt motor head back.
4. Slip beater onto beater shaft and press upward
as far as possible.
5. Turn beater to right, hooking beater over pin on shaft.
6. Plug into a grounded 3 prong outlet.
To Remove Flat Beater, Wire Whip or Dough Hook
4. Press beater upward as far as possible and turn left.
5. Pull beater from beater shaft
Jul 19, 2011 | KitchenAid KSM150PS Artisan Series Stand...
I have a Kitchenaid 550 watt 6 qt. stand mixer model #KB26GIXER. I tried to use it this morning and couldn't get the beater blade to lock in place. Isn't there supposed to be a spring and washer...
There is only one pin on the beater shaft to hold the beater in place.
There is no spring or washer on the shaft.
To Attach Flat Beater,Wire Whip, or Spiral Dough Hook, simply
1. Slip flat beater on beater shaft.
2. Turn beater to right, hooking beater over the pin on shaft.
Jun 25, 2011 | KitchenAid KP2671 Professional 6 Series...
I have a Sunbeam Mixmaster from mthe 1970s,
If this mixer sits on a stand, first remove it from the stand. Turn it upside down and shine a flashlight into the right side socket to look for obstructions. When you say you swivel the head, do you mean you rotate the handle? This is how to eject the beaters after use. It may be that the ejector on the right side is stuck. If so, you will need someone with mechanical skills to disassemble & repair.
May 23, 2017 | Sunbeam 2366 MixMaster Series Hand/Stand...
The flat beater is stuck in the mixer and I can't remove it.
oh yes you can.:) pur some wesson oil into the sockets the beaters go into and a little around the button.. Let set a few minutes and work the beaters back and forth as you pull gently. Make sure it is unplugged!!!!!
Oct 27, 2009 | KitchenAid KSM150PS Artisan Series Stand...
KitchenAid KITCHEN AID 5 Quart Artisan Series Stand Mixer Logo
2,399 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
