Question about Toshiba 50H71 50" Rear Projection Television
Remote control problem
My TV is not reacting to my remote control any more
  • 247 Answers
Before trying anything more intrusive, replace the batteries in the remote.
If that doesn't work, check whether your remote is designed to be able to control multiple devices (DVD player and Sat Receiver as well as TV for instance). It's not unknown for little fingers to switch the remote over to trying to control something else. If there's a button on the remote marked "TV", press that and see if normal serviceis resumed as a result.
A.
Posted on Nov 28, 2008
My samsung led-tv remote controll dont work corectly!
Check it by cleaning up. To clean it, you have to open the remote control. If you wish to get some details about how to clean a remtoe control, check the site linked here. Pull up older posts.
Dec 17, 2013 | GE Televison & Video
Remote control doesn't work
Have the remote itself first checked---most tv shops have a tester--point remote at it and press buttons and it reacts-----Many digital cameras will react on their display screen in a very dark room in the same way.
If remote itself tests good the set has a receiver that takes the signal from the remote and it may be bad.
Aug 29, 2012 | LG 37LD450 37 in. TV
Toshiba 40rv52u remote control
If just using one remote to try have it tested----many digital cameras in a dim light will react with a flash on the display screen when remote is pointed at them and buttons pressed.
Also try putting remote against remote receiver lens on front of set--if it reacts close up---the remote receiver in the set is bad---can be same if no reaction at all.
Either the remote or the receiver---one or the other.
A last thought here is some sets (read owner manual) have a feature to lock out the remote which can be engaged by accident.
May 15, 2012 | Toshiba 40RV52U TV
Samsung tv ln40b530p7fxza
Have the remote checked--it can be tested to see if it is the problem--if remote is good but does not work on set the remote receiver may be bad inside the TV.
Most shops and some electronic places have a remote tester--point remote at it and press the buttons and if working a light reacts---some digital cameras will also if on react on the little screen they have if this is done.
Either the remote or the receiver in the set is most common.
Apr 03, 2012 | Samsung LE32R41BD 32 in. HD-Ready LCD...
I need a code for my panasonic tv my remote is rm-88e
Hi julius,
If you don't have a code follow this auto search mode, this will automatically search the remote control the code of your unit.
1. Power on the unit(TV).
2. Press and hold SET key and TV key at the same time. The led light will be on at the moment, then released the pressed key.
3. Press the SET key again, then release it. The led light will flash and it is in the quick search mode.
4. Point the remote control to the TV, then press the POWER key(every second) until the TV react. Once the TV reacted try the other function key.
Repeat the steps until you've got the right code.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Mar 25, 2011 | Universal Remote Control Remote Control
Hi We won't the plustron remote control code to operate a phillips tv. The remote is a Plustron URC11E-8. The model number of the TV is 29PT3323/79R.
Hi bro, I haven't a code for urc11e-8, i've only have a code for urc11c-8a.Just try the code hope it will work for your unit :-)
philips tv:
036,037,056,060,068,082,100,109,113,114,122,132,154,156,157,162,163,167,176,179,198,215,216.
try one code (3 digit) at a time.
if not working try the quick search.
Press the set+tv at the same time. (the tv must be powered on.)the led on the remote will be on at the moment.
Then press the set key again,the remote control enters into quick search mode, led keeps flashing.
then point the remote to your unit then press the power key (see the device reacts or not) if not try press the power key every one second until the unit reacts.
hope it will work bro....gud luck.
Jan 03, 2011 | Televison & Video
Sony model KDL-32L5000 does not respond to the commands of its remote control model RM-YD028. We have been using a Direct TV remote as well to control volume but its not reacting this remote either...
If the only thing not reacting is the audio, then the audio board or the main board has gone bad. Enter the model number and tv make on you tube to get more detailed info.
Dec 15, 2017 | Sony KDL32L5000 32 in. LCD HDTV
Lookin for code
Try the Auto Search. It is explained in the user manual.
Text straight from the manual:
Set Up By Auto Search
A.) Power on the device you want to control.
B.) Press and hold [SET] key, in the meantime, press and hold the device key [ex. TV1] for more than 3 seconds and then release them, the auto search begins. The remote control enters into Auto Search, LED flashing, and remote control transmits power signal every 2.0 second automatically.
C.) See if the device reacts or not, once the device reacts, press any key (except the SET key) to stop the Auto Search.
May 24, 2009 | Durabrand DWT1304 13" TV
Kingavon remote control rc81s universal remote control
To program the Kingavon Home & Leisure 8 in 1 Remote Control RC81S:
SETUP by MANUAL SEARCH
A: Power on the device that you want to control. If it is a VCR, it must be inserterted with a tape. *(This works without a tape)*.
B: Press and hold [SET] key and press the device key (TV1 etc) at the same time.
C: The LED will be on at the moment. Then release the pressed keys.
D: Press the [POWER] key again, then release it. The remote control enters into Manual Search Mode and the LED keeps flashing.
E: Point the remote control to the device, and then press the [POWER] key. See if the device reacts or not. If it reacts, turn to step F. If not, repeat step E (press the [POWER]) every 1 Second.
F: Test other keys, if they do not work good enough, return to step A.
Feb 24, 2008 | Televison & Video
Toshiba 50H71 50" Rear Projection Television Logo
64 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
