Question about Abit NF8-V Pro Motherboard
Dvd drive replacement
I want to swap my dvd/cd burner drive for a new one. What is the difference between ata, sata, pata? What size will fit? How do I know which one to buy for my HP Pavillion? Any brand or model recommendations? Thanks so much. Dennis
  • 341 Answers
Get a PATA also called IDE drive.They are cheap and will work great in your box.You don't need the speed of SATA for a DVD drive.Even though they make SATA drives. Pata's data tramsission rareis much faster than even the fastest DVD. You have a four device potential for you IDE on your motherboard and only a two device potential for your SATA. Save the second SATA port in case you want to add a second hard drive some day
Posted on Nov 29, 2008
Pata slave drive not found in bios a05 of dell dimension 8400 but found in windows and linux os's
Hi
Have you tried swapping the pata drives - eg master to slave and vice versa ?. I have found that if the drives are not from the same manufacturer, quite often, you cannot get both drives to work. Seagate and WD normally are O.K., but some of the older Fujitsu ones just knock out any other drives on the same 40/80 way cable.
Mar 17, 2017 | Dell Dimension 8400 PC Desktop
WHAT HD & SIZE RECOMMENDED FOR MY GATEWAY 500S PC WITH OS XP?
You cannot use a SATA (serial ATA HDD in this machine. You need a PATA (parallel ATA) HDD, also known as IDE, ULTRA IDE, ULTRA ATA. This has a 40-pin ribbon connector & a 4-pin power connector.
Sizes generally available would be 80GB up to 250GB, although very few PATA drives are now sold since SATA is the new standard.
Jan 25, 2013 | Gateway GT5220 PC Desktop
My Mad Dog LS-DVDRW TSH652M is broken and must be replaced. Is it a PATA or SATA type drive?
Remove it and look at the 2 cables connecting to it. 1 is power and the other cable is DATA
Feb 22, 2011 | Mad Dog Multimedia DVD±RW Dual Layer...
I want to get a new internal hard drive but I,m not sure of the hard drive interface type. The specs say Serial ATA 300. The drives I am looking at say SATA?
Dear friend. in fact Serial ATA is SATA.
and i checked your Hard drive out.
your hard drive uses SATA technology to connect with the PC.
please vote
Jan 15, 2011 | Dell OptiPlex GX260 PC Desktop
Hi,the motor in the burner is not cuming on,the power light comes on and the hardware comes up on my computer,only used it 2 times ,it didnt fall,please help,
DVD/CD NOT READ Fit the cable tightly sata/pata If it same problem fit new cable. Same as before It could be a problem with the lens, you should try cleaningthe lens, it's already gone bad there is no harm in trying
if that doesn't work you can either repalce the lens or purchase a new DVD/CDdrive
Follow these two step I think it would help you.
Don't forgate to vote me
Dec 01, 2010 | LaCie DVD±RW Drive (FireWire)...
I have an aspire sa20 dsktop computer and want to replace my dvd rom with a dual layer dvd writer.i have had one come and the plug to install it is different than the rom into it.do the mothe board have a...
I do not have a manual for the ACER sa20 but it appears that it only has a PATA drive controler and not SATA. You can get a PATA to SATA converter on Ebay or buy a SATA controler card or buy a PATA DVD drive instead of the SATA one.
Jul 10, 2009 | Acer Aspire SA20 PC Desktop
Mt6451 hdd replacement?
Hi there.
You can choose from any hard drive manufacturer providing you know what type of hard drive you need, you are certainly not tied to Gateway for parts.
Thanks for choosing FixYa!!
Jun 09, 2009 | Gateway MT6451 Notebook
No sata l type on my motherboard
the only way i know is to buy a convertor like the 1 from the link
http://www.cooldrives.com/serial-ata---ata-atapi-ide-interface-adapter.html
might be easier to just swap the drive you have if youve just bought it or buy a new ide drive
Mar 13, 2009 | LG GSA-2166D DVD RW Dual Layer Burner
Need to install my new dvd writer on my dell dimension 9200 pc. The plugs are different. now what?
If the plugs are different most likely you bought a SATA drive. If your MB doesnt support SATA then there really isnt any use for that drive, i would return it and purchase an IDE drive, chances are thats what you have. Good Luck!!!
Aug 04, 2008 | Computers & Internet
Sony Dual DVD +/- RW
set the hard drive to master and the dvd to slave
Jan 24, 2008 | Computers & Internet
Abit NF8-V Pro Motherboard Logo
65 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
