Question about American Standard Plumbing
Leak around handle and spout
Asked someone about the leak and they said to change the cartridge. So I did Still it continues to leak intermitentlyl
    Problem Solver:
  • 6 Answers
If it is leaking around the handle, the cartridge may be loose and you need to tighten it more. If it is leaking from the spout, the cartridge is faulty. Even if you bought a new one, it may be faulty. They are made in China and the quality control is awful.
Posted on Nov 30, 2008
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    Would it be cartridge or something else
    Not the cartridge. There are O Rings around the spout that wear out. These need replacing. Call Rohl for replacement parts
    www.rohlhome.com/warranty.aspx
    Jul 07, 2014 | Rohl R77V3SPN Country Pull-Out Bar Faucet...
    Leaking faucet
    Remove the handles. See if the chrome slip nuts holding the stems in are corroded. If they are, the cartridges may not be fully seated or the o -rings that seal around the cartridges may need to be replaced. If either of these is the case you can tell for sure by turning the stems to the on position with the handles removed and looking for water seeping around the cartridge. If none of the above is the cause then check to see if the aerator (screen on the spout) is loose or corroded sending a light spray back towards the faucet body that looks like a leak. If this is the case remove and clean the aerator, then reinstall it making sure not to cross thread it. If none of the above, replace the faucet. Be sure to call Delta first before replacing because they have a lifetime warranty and you just might get your faucet for free!
    Apr 05, 2013 | Delta Faucet Delta 2530-24 Innovations...
    How to fix a leaky Moen faucet that leaks at the spout ,which is separate from the handle?
    These faucets can leak in three different places:
    1. Internally at the valve seat
      You'll see water dripping from the spout. This means the rubber washer is worn or damaged. To replace the washer, remove the decorative cap from the handle. Remove the retaining screw and pull off the handle. Remove the decorative cover, called an escutcheon, if there is one. Unscrew the packing nut counterclockwise. Unscrew the valve stem and remove it. Remove the screw that holds the rubber washer in place. Because these washers come in many shapes and sizes, you'll want to take the old one to the hardware store and buy an exact replacement. Be sure to buy two washers so you'll have one for the other valve. Replace the washer and reassemble the faucet.
    2. Around the handle
      If you see water coming from below the handle, the packing nut is leaking. Older faucets have a string-like graphite packing material wrapped around the stem. Newer faucets use an O-ring. First try tightening the packing nut clockwise... about one-half turn. If this doesn't stop the leak, remove the packing nut and replace the packing or O-ring; then reassemble the faucet. If the valve is using the graphite packing material, it might be a clue that you should shop for a new faucet.
    3. Between a pivoting spout and the body
      The spout might be held in place with a packing nut, similar to the faucet stem, or it might have a nut at the top of the spout. In either case, remove the spout and replace the packing material or the O-ring seal. Then reassemble the faucet.
    Single lever faucets also are known as "washerless" faucets. They are easier to repair than compression faucets after you determine what type of faucet you have. There are three types of washerless faucets: ball, ceramic disk and cartridge.
    Leaks are evident in two places... dripping from the spout and seeping from around the spout where it joins the body of the faucet.
    Leaks from the spout indicate that the ball, disk or cartridge is leaking. To repair, turn off the water to the faucet, then remove the handle. The handles on ball-type faucets are held in place with a setscrew that requires an Allen wrench to loosen. Ceramic disk and cartridge-type handles usually are held in place by a screw hidden beneath a cap.
    On ball and ceramic disk-type faucets, remove the ball or disk and replace the seals. You can buy replacement kits for these faucets at the hardware store or home center.
    On cartridge-type faucets, remove the spout and pull out the retainer clip that holds the cartridge in place. To remove the cartridge, pull on the cartridge stem with a twisting motion. If it resists, install the handle so you can a better grip on the cartridge to pull it out. Take the cartridge to the hardware store or home center and purchase an exact replacement kit.
    Reassemble the faucet according to directions.
    Leaks at the spout-to-body joint indicate an O-ring failure. Disassemble the faucet as described above. Remove the spout sleeve and replace the O-rings. It's a good idea to replace these seals if you have the faucet disassembled for repair of the ball, disk or cartridge.
    Sep 10, 2011 | Moen Plumbing
    I have replaced the cartridge on my single faucet single handle moen kitchen tap, but water still leaks out under the central area that holds the cartridge. Is there a schematic that shows where and what...
    did you replace the spout, -o- ring's. they would cause a leak to show up there as well.no need to pull cartridge again,just handle,and then pull up spout and that is it. there should be a small packet of lube w/ -o- ring kit,lube up around shaft and new -o- ring's.available at any good hrd ware store
    Apr 19, 2010 | Moen 7310 Legend Single-Handle Kitchen...
    Replacing Moen O kitchen faucet O ring
    if it is dripping from the spout then there is a cartridge that needs replaced...1225 for the single handle type and 1224 for the 2 handle type. Moen does not use O-rings in their valves. If it leaking around the base of the spout there is an oring kit that you will need and you will have to pull the spout off to access them. Most Moen faucets use a 117 kit for the spout but there are some different ones.
    Oct 19, 2009 | Moen & Replacement Cartridge
    Moen kitchen faucet model 7430 leak
    cartridge does not stop that type of leak. If it is leaking from around the base of the spout it is o-rings that are the problem that are onthe valve after you pull the spout all the way off.
    Oct 17, 2009 | Moen 87530 Touch Control Single Handle...
    Installed a new 88976 handle but still have a leak
    replacing just the handle cannot fix the leak and common sense should tell you that.... try turning off the water to the diverter (thru access panel on opposit wall or main water valve for the home) and then replacing the stem or cartridge inside the diverter -- this is what controls water temp, pressure, and is responsible for any leaks you may have...
    Aug 31, 2009 | Delta & Single Handle Shower Faucet
    Moen single lever kitchen faucet leaking at base and through spray. Can it be fixed? I lost my installation manual. Are there any online?
    base leak is from bad o ring or loose spout very easy fix you can get a washer kit at lowes all you need is a allen wrench(sometimes comes in kit) a pair of channel lock pliers
    May 09, 2009 | Moen 7840 Camerist Single-Handle Kitchen...
    Plumbing Logo
    656 people viewed this question
    Top American Standard Plumbing Experts
    john h
    Steve Wood Plumbing...
    Level 1 Expert
    Mike
    Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
